[Mapserver-users] Another question about DGN attribute query
Emil Zegers
EZS at DeStraat.NL
Mon Jan 26 10:46:59 EST 2004
Hello list,
At the moment I'm struggling with querying DGN attribute data which is not working out.
I've found messages about this subject posted on the list before and they helped me to come where I am now: I can display the DGN with/without using the STYLEITEM "AUTO" and I can show the values from the Text field.
But I cannot query any of the fields in the DGN, no matter what field (Text, level, Layer) for a certain LAYER TYPE (ANNOTATION, POINT, LINE, POLYGON) I query.
This is the LAYER definition:
# GROENNAALDWIJK_dgn
LAYER
METADATA
wms_title "GROENNAALDWIJK_dgn"
END
NAME "GROENNAALDWIJK_dgn"
TYPE POINT
DEBUG ON
CONNECTIONTYPE OGR
CONNECTION "D:/websites/DemoData/Naaldwijk/Data/Basis/dgn/GROENNAALDWIJK.DGN"
DATA "0"
STATUS ON
TOLERANCE 10
STYLEITEM "AUTO"
CLASSITEM "Text"
CLASS
END
TEMPLATE "xmlqueries/dgn_xml.html"
END
This is the dgn_xml.html template defintion:
<dgn>
<Text>[Text]</Text>
</dgn>
It all ends in the following message:
msOGRLayerGetShape(): OGR error. Requested feature is incompatible with layer type
Now I'm looking for working examples of DGN attribute querying, has anyone been able to do so?
And if yes, are you willing to share your knowledge and/or example MAP and TEMPLATE files?
Best regards,
Emil Zegers
______________________________________________________
This message has been checked for all known viruses
