[Mapserver-users] Re: [Mapserver-dev] labels generated upside down
Steve Lime
steve.lime at dnr.state.mn.us
Mon Jan 26 10:59:04 EST 2004
I'll look for the bug. I've got enough systems available to me that I
can narrow it
down a bit. In the past these types of problems have always been
attributed to
bad GD/Freetype combinations.
Steve
>>> <woodbri at swoodbridge.com> 1/25/2004 5:07:01 PM >>>
So, I take it no one else has seen this problem.
I could NOT find anything in bugzilla.
And I have not been able to narrow down an example that is small
enough to submit to bugzilla because removing data changes the
labelling enough to cause the problem labels to shift around and
removes the problem but it is easily reproduced on our servers ....
-Steve
On 14 Jan 2004 at 16:20, woodbri at swoodbridge.com wrote:
> Hi all,
> Labelling streets I get occasional labels the are placed upside down.
> Using ANGLE AUTO
> This happens with two different builds using similar but slightly
> different versions of libraries. Is this a know bug? I could find it
> in bugzilla.
> Linux build
> MS 4.0
> later/latest copies of GD 2
> later/latest copies of freetype
> GDAL, proj, etc
> -Steve W.
> Mapserver-dev mailing list
> Mapserver-dev at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
