[Mapserver-users] (newbie): Win32 Apache error when
calling Mapserv.exe
Pericles S. Nacionales
nacional at cbs.umn.edu
Mon Jan 26 16:54:40 EST 2004
Tyler,
Thanks for coming back to this. I found a few more inconsistencies with
the configuration file. Those last two lines might actually be
ok--there might be a beginning <IfModule mod_alias.c> tag somewhere
above the beginning of the snippet Yuri sent us.
What I would try then, Yuri, is comment out the <IfModule
mod_perl.c></IfModule> block:
<Directory "C:/phpdev/www/cgi-bin">
#<IfModule mod_perl.c>
# Sethandler perl-script
# PerlHandler Apache::Registry
# PerlSendHeader On
# </IfModule>
Options All MultiViews
AllowOverride None
Order deny,allow
Allow from all
</Directory>
Oh, one more thing... Perhaps this is all you need to do. Change
"Options All MultiViews" to "Options ExecCGI". Hah! I just saw the
line above. I bet that's all you need to do.
-Perry
On Mon, 2004-01-26 at 14:10, Tyler Mitchell wrote:
> I'm always cutting/pasting apache.conf directory code, do his cgi-bin
> properties look good to go with executables?
> mapserver-users-admin at lists.gis.umn.edu wrote on 01/23/2004 12:09:29 AM:
> > Yuri,
> > Check the last two lines of your apache config snippet...
> > > </Directory>
> > > </IfModule>
> > If this is how they appear in your config file, switch them.
> > </IfModule>
> > </Directory>
> > This could be the cause of your problem.
> > > If not, something is wrong with your executable. But then again it
> could
> > > just
> > > be permission problems. Or perhaps you've locked down your CGI-BIN
> > > directory
> > > so that only scripts with certain extensions would run?
> > -Perry N.
> > "He's no geek.His tan's too good." -Benjamin Choate
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
