[Mapserver-users] ArcView Line Theme + GPS tracking
Howard Mark
MHoward at spaceimaging.com
Wed Jan 28 12:28:31 EST 2004
This is a multi-part message in MIME format.
------_=_NextPart_001_01C3E5C4.26631882
Content-Type: text/plain; charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Kieran,
=20
Thanks for sharing the script. I'm sorry I did not have time to write somet=
hing for you myself. I may write a routine soon to convert point data to si=
mple lines. I'm doing a fun project tracking a model sailplane with GPS in =
ArcView. If anyone needs GPS tracking in ArcView, I can supply VB routines =
that will poll the serial port and write a file (NMEA format). I have an A=
rcView project that reads the file and plots the track. I'm thinking about =
saving the point data to a file and later creating a shapefile - which is w=
hat you wanted to do. I already have tracking logs that can be used for tha=
t purpose.
=20
Mark
=20
-----Original Message-----
From: mapserver-users-admin at lists.gis.umn.edu [mailto:mapserver-users-admin=
@lists.gis.umn.edu]On Behalf Of Kieran J. Ames
Sent: Wednesday, January 28, 2004 6:08 AM
To: mapserver list
Subject: Re: [Mapserver-users] OT: ArcView Line Theme
=20
Many thanks to all for your help=20
I ended up using a script called pt_ln_pl.ave=20
While heavy on the processing time (making straight polylines from about 1,=
500 definitions took about 10 minutes and 100% cpu), this script did everyt=
hing I needed.=20
I include it here since finding it again was quite a task.=20
Kieran=20
This message is intended only for the use of the Addressee and may
contain information that is PRIVILEGED and CONFIDENTIAL.
If you are not the intended recipient, you are hereby notified that any
dissemination of this communication is strictly prohibited. If you have
received this communication in error, please erase all copies of the
message and its attachments and notify Space Imaging immediately.
Content-Type: text/html; charset="iso-8859-1"
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" xmlns:w=3D"urn:sc=
hemas-microsoft-com:office:word" xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; charset=3Diso-8859-=
1">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 9">
<meta name=3DOriginator content=3D"Microsoft Word 9">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C3E589.7A1591A0">
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:Zoom>0</w:Zoom>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:ForgetLastTabAlignment/>
<w:DoNotUseHTMLParagraphAutoSpacing/>
</w:Compatibility>
</w:WordDocument>
</xml><![endif]-->
<style>
/* Font Definitions */
@font-face
{font-family:Tahoma;
panose-1:2 11 6 4 3 5 4 4 2 4;
mso-font-charset:0;
mso-generic-font-family:swiss;
mso-font-pitch:variable;
mso-font-signature:553679495 -2147483648 8 0 66047 0;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0in;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
p.MsoToc1, li.MsoToc1, div.MsoToc1
{mso-style-update:auto;
mso-style-next:Normal;
margin-top:6.0pt;
margin-right:0in;
margin-bottom:0in;
margin-left:0in;
text-indent:.2in;
font-size:12.0pt;
font-weight:bold;
mso-bidi-font-weight:normal;
font-style:italic;
mso-bidi-font-style:normal;}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:blue;
p.MsoAutoSig, li.MsoAutoSig, div.MsoAutoSig
{margin:0in;
font-size:12.0pt;
p
{margin-right:0in;
mso-margin-top-alt:auto;
mso-margin-bottom-alt:auto;
margin-left:0in;
font-size:12.0pt;
pre
{margin:0in;
tab-stops:45.8pt 91.6pt 137.4pt 183.2pt 229.0pt 274.8pt 320.6pt 366.4pt 41=
2.2pt 458.0pt 503.8pt 549.6pt 595.4pt 641.2pt 687.0pt 732.8pt;
font-size:10.0pt;
font-family:"Courier New";
mso-fareast-font-family:"Courier New";}
span.EmailStyle20
{mso-style-type:personal-reply;
mso-ansi-font-size:10.0pt;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:navy;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dblue style=3D'tab-interval:.5in'>
<div class=3DSection1>
<p class=3DMsoNormal><span class=3DEmailStyle20><font size=3D2 color=3Dnavy=
face=3DArial><span
style=3D'font-size:10.0pt;mso-bidi-font-size:12.0pt;font-family:Arial'>Kier=
an,<o:p></o:p></span></font></span></p>
face=3DArial><span
style=3D'font-size:10.0pt;mso-bidi-font-size:12.0pt;font-family:Arial'><![i=
f !supportEmptyParas]> <![endif]><o:p></o:p></span></font></span></p>
<p class=3DMsoNormal style=3D'text-indent:.5in'><span class=3DEmailStyle20>=
<font
size=3D2 color=3Dnavy face=3DArial><span style=3D'font-size:10.0pt;mso-bidi=
-font-size:
12.0pt;font-family:Arial'>Thanks for sharing the script. I’m sorry I =
did not
have time to write something for you myself. I may write a routine soon to
convert point data to simple lines. I’m doing a fun project tracking =
a model
sailplane with GPS in ArcView. If anyone needs GPS tracking in ArcView, I c=
an supply
VB routines that will poll the serial port and write a file (NMEA format). =
<span
style=3D"mso-spacerun: yes"> </span>I have an ArcView project that rea=
ds the
file and plots the track. I’m thinking about saving the point data to=
a file
and later creating a shapefile – which is what you wanted to do. I al=
ready have
tracking logs that can be used for that purpose.<o:p></o:p></span></font></=
span></p>
face=3DArial><span
face=3DArial><span
style=3D'font-size:10.0pt;mso-bidi-font-size:12.0pt;font-family:Arial'>Mark=
face=3DArial><span
<p class=3DMsoNormal style=3D'margin-left:.5in'><font size=3D2 color=3Dblack
face=3DTahoma><span style=3D'font-size:10.0pt;font-family:Tahoma;color:blac=
k'>-----Original
Message-----<br>
<b><span style=3D'font-weight:bold'>From:</span></b>
[mailto:mapserver-users-admin at lists.gis.umn.edu]<b><span style=3D'font-weig=
ht:
bold'>On Behalf Of </span></b>Kieran J. Ames<br>
<b><span style=3D'font-weight:bold'>Sent:</span></b> Wednesday, January 28,=
2004
6:08 AM<br>
<b><span style=3D'font-weight:bold'>To:</span></b> mapserver list<br>
<b><span style=3D'font-weight:bold'>Subject:</span></b> Re: [Mapserver-user=
s] OT:
ArcView Line Theme</span></font></p>
<p class=3DMsoNormal style=3D'margin-left:.5in'><font size=3D3 face=3D"Time=
s New Roman"><span
style=3D'font-size:12.0pt'><![if !supportEmptyParas]> <![endif]><o:p><=
/o:p></span></font></p>
<p class=3DMsoNormal style=3D'margin-left:.5in'><font size=3D3 color=3Dblack
face=3D"Times New Roman"><span style=3D'font-size:12.0pt;color:black'>Many =
thanks
to all for your help <br>
I ended up using a script called pt_ln_pl.ave <br>
500
definitions took about 10 minutes and 100% cpu), this script did everything=
I
needed. <br>
I include it here since finding it again was quite a task. <br>
Kieran <br>
</span></font><font color=3Dnavy><span style=3D'color:navy'>……&=
#8230;……..</span></font><font
color=3Dblack><span style=3D'color:black;mso-color-alt:windowtext'><o:p></o=
</div>
<FONT SIZE=3D3><BR>
<BR>
*****<BR>
This message is intended only for the use of the Addressee and may<BR>
contain information that is PRIVILEGED and CONFIDENTIAL.<BR>
<BR>
If you are not the intended recipient, you are hereby notified that any<BR>
dissemination of this communication is strictly prohibited. If you have<BR>
received this communication in error, please erase all copies of the<BR>
message and its attachments and notify Space Imaging immediately.<BR>
*****<BR>
</FONT>
</body>
</html>
------_=_NextPart_001_01C3E5C4.26631882--
