[Mapserver-users] WMS server image black padding and aspect
ratio
Eric Sokolowsky
eric.sokolowsky at gsfc.nasa.gov
Wed Jan 28 16:48:36 EST 2004
On Wed, 28 Jan 2004, Ed McNierney wrote:
> Eric -
> You may be slightly misunderstanding the WMS problem. The WMS
> specification states that if an image request specifies an OUTPUT image
> size (WIDTH= and HEIGHT=) and a geographic bounding box (BBOX=) that are
> not consistent with one another (for example, WIDTH=200,HEIGHT=100 and
> BBOX=0,0,100,100, so a 100x100 area is being requested in a 200x100
> image) that the 100x100 geographic area be stretched in the X direction
> so it's 200 pixels wide. MapServer does not do this, but instead
> renders a 200x100 geographic area to fill the box without stretching the
> OUTPUT image.
Yes, this is my understanding of the problem. This is a show stopper for
me. If I'm able to fix this problem, would others be interested in my
changes?
> Your comment makes it sound like you have INPUT images with different X
> and Y resolutions/scales. This is completely unrelated to the problem
> with the WMS interface, and MapServer can handle those images with no
> problems - assuming of course that the metadata correctly describes the
> input images.
I see. This is good. Thanks for the response.
> -----Original Message-----
> From: Eric Sokolowsky [mailto:eric.sokolowsky at gsfc.nasa.gov]
> Sent: Wednesday, January 28, 2004 2:29 PM
> To: Daniel Morissette
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] WMS server image black padding and aspect
> ratio
> On Fri, 23 Jan 2004, Daniel Morissette wrote:
> > Eric Sokolowsky wrote:
> > > I am running mapserver 4.0.1 but this aspect also appears with the
> > > version in CVS. I am using mapserver as a WMS server on a Red Hat
> > > Linux 9 system. When I request an image that is not the same aspect
> > > ratio as the original image on the server, it seems that the image I
> > > get is not stretched so that it fills the entire frame. The aspect
> > > ratio of the original source is maintained and black bars either
> > > appear above and below or else on both sides, similar to the effect
> > > of watching widescreen movies on a regular TV. Is this the intended
> > > behavior, and if so, is there a way to turn it off?
> > The short answer is that MapServer doesn't support rendering maps with
> > different X and Y scales. This is one of the only issues with
> > MapServer before it passes all the OGC WMS tests.
> This is most unfortunate. It is absolutely critical for my application
> to allow this. Most of the images that I want to serve have different X
> and Y scales, and it would be very difficult to rescale all of them.
> Also, even if I rescaled all of the images, it would not solve the
> problem of requesting a different aspect ratio bounding box.
> Is there work being done to fix this problem? I am willing to jump into
> the code to try and find a way to solve it, but I am not familiar with
> the code and it may take me a while to get up to speed with it.
> > For the long story, see the following thread in the archives:
> > http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0401/msg00105
> > .html
> > Daniel
____ __ Eric Sokolowsky (GST) NASA Goddard Space Flight Center
/ __/__/_/__ Visualization Programmer Scientific Visualization Studio
/ __/ _/ / _/ 301.286.3751 Mailstop 935.0 Bldg 28 Rm E102
/___/_//_/__/ eric.sokolowsky at gsfc.nasa.gov Greenbelt, MD 20771
