[Mapserver-users] Globe View with Orthographic Projection
    Harald Wehr
    hwehr at hs-harz.de
    Wed Jan 28 23:30:34 PST 2004
Many thanks for the changes you have made! Things become better and
better but I have discovered other things that seem to be strange too.
As in my first mail, I put the example under this url:
http://www2.hs-harz.de/~hwehr/mapserver/
Picture 4 is well, with the extent of test4.mapfile:
EXTENT  -6300000 -6300000 6300000 6300000
When I change the extent to something near the radius of the earth the
output is really strange (picture 5).
Same happens when I try to display the polar region. Picture 6 is well
for the extent of: EXTENT  -6500000 -6500000 6500000 6500000
Changing this to EXTENT  -6300000 -6300000 6300000 6300000 results in
picture 7 which is almost all blank.
So what do you think happens here? As my programming skills in C are
really bad I cant support you with some code. But of course I will be
able to do further tests if you wish.
Thanks in advance!
Harald
More information about the MapServer-users
