[Mapserver-users] Question about Arc Explorer 4 as a client for
WMS Mapserver(WIKI page)
Dean Gadoury
dgadoury at dmsolutions.ca
Thu Jan 29 16:31:06 EST 2004
I'm not sure if this will help, but I saw an error message in the
getcapabilities document:
<!-- WARNING: Mandatory metadata 'wms_title' was missing in this
context. -->
Are you missing 'wms_title' in your layer metadata? If so, try adding
that and see if it helps.
Ling-Yen Liao wrote:
>Hi all,
>I installed Mapserver and the two WMS requests work on our machine.
>1 GetCapabilities
>http://stats15.ndlab.its.nyu.edu/cgi-bin/mapserv?map=/var/www/html/mapserver/map-script/wms.map&REQUEST=GetCapabilities
>2 GetMap
>http://stats15.ndlab.its.nyu.edu/cgi-bin/mapserv?map=/var/www/html/mapserver/map-script/wms.map&VERSION=1.1.0&REQUEST=GetMap
>Then I followed the WIKI page's steps and made a php file.
>But when I go to Arc Explorer's "Interoperability->connect to WMS"
>and insert
>http://stats15.ndlab.its.nyu.edu/mapserver/map-script/wms.php
>as the URL and left the server name blank
>it returned "Invalid Capability File. Check ServerURL"
>Anyone has the same problem before?
>Any help?
>Thanks in advance.
>-Lingyen
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Dean Gadoury
DM Solutions Group
30 Rosemount Ave. Suite 200
Ottawa, Ontario. K1Y 1P4
613.565.5056 ext. 24
www.dmsolutions.ca
