[Mapserver-users] Re: jBox - setcursor() etc..
Wim Blanken PI
wim.blanken at planet.nl
Fri Jan 30 14:42:02 EST 2004
Hello Steve,
I assume you are using a Microsoft VM. I have also problems with the
visualisation of the the cursor type on this VM. On the SUN VM it works OK.
I'll have a look at the specific java code to see if anything can be done
about it......
Regards,
Wim
----- Original Message -----
To: "Wim Blanken (PI)" <wim.blanken at planet.nl>
Sent: Friday, January 30, 2004 1:25 AM
Subject: jBox - setcursor() etc..
> Hi Wim,
> I've posted a question about setcursor(). I have no idea why the cursor
does
> not change to a hand etc. It does not casue an error. Just wondering if
you
> got this to work. By the way, I did get my setimage(url) (for zoom-in) to
> work but it takes an awful lot of code, since I must build the url with
alll
> of the text, plus the mapext. Now, I also believe that I must build my own
> url for zoom-out and pan :-(
> Do you use the setimage() or just submit the page?
> Thanks,
> Steve
