[Mapserver-users] Timeout for wms layer
Pericles Nacionales
nacional at cbs.umn.edu
Thu Jul 1 12:27:08 EDT 2004
Martin,
First, remove "http://localhost" from your client's IMAGEURL value. It
should be like this: IMAGEURL "/wms/ms_tmp/"
Also, remove "http://http://www.moeldrup.dk" from your server's IMAGEURL
path. It should be: IMAGEURL "/ms_tmp"
If that still doesn't work, review
http://mapserver.gis.umn.edu/doc42/wms-server-howto.html and
http://mapserver.gis.umn.edu/doc42/wms-client-howto.html.
Good luck!
-Perry
Pericles S. Nacionales
nacional at biosci.umn.edu
On Thu, 1 Jul 2004, [ISO-8859-1] Martin Høgh wrote:
> Dear List
> I've posted this message
> http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0406/msg00759.html
> earlier without much luck., so I'll try again.
> I'm trying to use Mapserver as a wms client for this server
> http://www.moeldrup.dk/scripts/mapserv.exe?map=d:/www/website/Ortofoto/moeldrup.map
> I am administrating this server so I can alter the settings if necessary.
> The problem is that when the layer from this server is requested by a
> Mapserver client it will timeout. A .img.tmp of 0k file is created and
> no errors from the client.
> I've tested with ms3.6.6 (both php/mapscript and cgi) on linux and ms4.0
> on winxp with same result
> The projection for all is set to "epsg:32632". But actually the data
> projected in a odd Danish system which can not be reprojected. But I
> believe that an epsg or auto code must be specified.
> My map-file (client)
> # Start of map file
> NAME Province
> STATUS ON
> SIZE 700 440
> EXTENT -277553.292530 232924.427400 -252200.662530 251396.532600
> UNITS METERS
> #SHAPEPATH "../data/grundkort"
> IMAGECOLOR 215 226 233
> FONTSET "../etc/fonts.txt"
> IMAGETYPE png
> PROJECTION
> "init=epsg:32632"
> END
> WEB
> # On Windows systems, /tmp and /tmp/ms_tmp/ should be created at the root
> # of the drive where the .MAP file resides.
> IMAGEPATH "C:\Programmer\EasyPHP1-7\www\wms\ms_tmp\"
> IMAGEURL "http://localhost/wms/ms_tmp/"
> LOG "C:\Programmer\EasyPHP1-7\www\wms\map.log"
> END
> LAYER
> NAME orto
> METADATA
> "wms_srs" "EPSG:32632"
> "wms_connectiontimeout" "15"
> END
> TYPE RASTER
> STATUS default
> CONNECTIONTYPE WMS
> CONNECTION
> "http://www.moeldrup.dk/scripts/mapserv.exe?map=d:/www/website/Ortofoto/moeldrup.map&WMTVER=1.0.0&FORMAT=image/jpeg&"
> END
> end #mapfile
> mapfile (server)
> # Start of map file
> NAME Moeldrup_WMS
> STATUS ON
> UNITS METERS
> IMAGECOLOR 255 255 255
> IMAGETYPE png
> PROJECTION
> "init=epsg:32632"
> END
> SIZE 700 440
> # Start of web interface definition
> web
> IMAGEPATH "D:\www\website\ms_tmp\"
> IMAGEURL "http://http://www.moeldrup.dk/ms_tmp/"
> LOG "map.log"
> METADATA
> "wms_title" "Møldrup ortofoto WMS server"
> "wms_onlineresource"
> "http://www.moeldrup.dk/scripts/mapserv.exe?map=d:/www/website/Ortofoto/moeldrup.map&WMTVER=1.0.0&"
> END
> END
> # Start of layer definitions
> LAYER
> NAME "Ortofoto"
> STATUS default
> TILEINDEX "KX-1569_Index.shp"
> TILEITEM "location"
> TYPE RASTER
> PROJECTION
> "init=epsg:32632"
> END
> END
> END # Map File
> Best regards
> Martin
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
