[Mapserver-users] wms server projection
Tyler Mitchell
tjmitchell at riverside.bc.ca
Thu Jul 1 19:04:01 EDT 2004
I'm not exactly sure what you mean, but maybe this will help.
Are you only using EPSG codes in your PROJECTION objects of the map file?
You don't have to! You can use all the parameters that an EPSG
encapsulates. For example, these two entries are identical:
PROJECTION
"proj=omerc"
"lat_0=46.9524056"
"lon_c=7.4395833"
"alpha=90"
"k=1"
"x_0=600000"
"y_0=200000"
"ellps=bessel"
"units=m"
"no_defs"
END
PROJECTION
"init=EPSG:21781"
END
You can see why the later is often used :)
You should then be able to modify any of those parameters to suit your
likings.
Hope that helps.
Tyler
mapserver-users-admin at lists.gis.umn.edu wrote on 07/01/2004 12:48:14 AM:
> Hi all
> I have a umn mapserver 4.2 wms-server and chameleon.
> I would include a layer of this wms server. The projection of the
> layer has an
> alpha value of 90 (init=epsg:21781), which produces an error.
> <21781> +proj=omerc +lat_0=46.95240555555556
+lonc=7.439583333333333+alpha=90
> +k=1 +x_0=600000 +y_0=200000 +ellps=bessel +units=m +no_defs no_defs <>
> so I would change the alpha value to 89, but how can I include the
> projection
> in the mapfile withaout an entry like
> "init=epsg:21781"
> Is it possible to create my own projection in the web part of the
mapfile?
> Should I create an own file with my own projection like a 'epsg',
'esri', ...
> file (the server and the client could then use the same projection
file)?
> Which is the best way?
> Thanks in advance
> Markus Schnider
> PS: Chameleon or the wms-server works at this time only if the
alphavalue is
> different of 90. So I changed the projection to this values.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
