[Mapserver-users] wms server projection
Markus Schnider
sp_ml at sourcepole.com
Fri Jul 2 02:09:50 EDT 2004
Thanks
This works fine.
The it exists also a WEB part. I would write the projection like you wrote in
the WEB part:
WEB
IMAGEPATH "/var/lib/gisdata/ms_tmp/"
IMAGEURL "/ms_tmp/"
MINSCALE 25000
METADATA
"WMS_TITLE" "WMS test"
"WMS_ABSTRACT" "test on postgis"
"WMS_ACCESSCONSTRAINTS" none
"wms_onlineresource" "http://something/cgi-bin/wms?"
"wms_srs" "EPSG:4326 AUTO:42001"
END
#QUERYFORMAT text/html # version 4.2 of mapserver
END
I mean: How could I write my own projection with the variabel WMS_SRS?
Or: Do I need this entry?
Thanks
Markus Schnider
On Friday 02 July 2004 01:04, Tyler Mitchell wrote:
> I'm not exactly sure what you mean, but maybe this will help.
> Are you only using EPSG codes in your PROJECTION objects of the map file?
> You don't have to! You can use all the parameters that an EPSG
> encapsulates. For example, these two entries are identical:
> PROJECTION
> "proj=omerc"
> "lat_0=46.9524056"
> "lon_c=7.4395833"
> "alpha=90"
> "k=1"
> "x_0=600000"
> "y_0=200000"
> "ellps=bessel"
> "units=m"
> "no_defs"
> END
> PROJECTION
> "init=EPSG:21781"
> END
> You can see why the later is often used :)
> You should then be able to modify any of those parameters to suit your
> likings.
> Hope that helps.
> Tyler
> mapserver-users-admin at lists.gis.umn.edu wrote on 07/01/2004 12:48:14 AM:
> > Hi all
> > I have a umn mapserver 4.2 wms-server and chameleon.
> > I would include a layer of this wms server. The projection of the
> > layer has an
> > alpha value of 90 (init=epsg:21781), which produces an error.
> > <21781> +proj=omerc +lat_0=46.95240555555556
> +lonc=7.439583333333333+alpha=90
> > +k=1 +x_0=600000 +y_0=200000 +ellps=bessel +units=m +no_defs no_defs <>
> > so I would change the alpha value to 89, but how can I include the
> > projection
> > in the mapfile withaout an entry like
> > "init=epsg:21781"
> > Is it possible to create my own projection in the web part of the
> mapfile?
> > Should I create an own file with my own projection like a 'epsg',
> 'esri', ...
> > file (the server and the client could then use the same projection
> file)?
> > Which is the best way?
> > Thanks in advance
> > Markus Schnider
> > PS: Chameleon or the wms-server works at this time only if the
> alphavalue is
> > different of 90. So I changed the projection to this values.
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
