[Mapserver-users] Different colors in different layers
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Jul 2 08:48:30 EDT 2004
Same idea, but you have to know the range of colors that are possible
and create a CLASS for each COLOR then use an EXPRESSION to select the
color instead of the "divi" so if your values were like 1 .. 100 and you
wanted assign colors based on 1-10, 11-20, 21-30, ..., 91-100
CLASS
EXPRESSION ([divi] < 11)
STYLE
COLOR ...
END
END
CLASS
EXPRESSION ([divi] < 21)
STYLE
COLOR ...
END
END
CLASS
# no expression is like an default: and will catch
# anything not caught above.
STYLE
COLOR ...
END
END
CLASS is like a CASE statement, it will stop after one is selected.
-Steve W.
Javier Castillejo Montes wrote:
> Oh thanks that looks fine...
> and... how about do it dinamically (i think it's said "on the fly"), I mean,
> I have the color I need on a database field... how can I assign the "divi"
> to his color at runtime.
> Javier C.
> -----Mensaje original-----
> De: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
> Enviado el: viernes, 02 de julio de 2004 14:14
> Para: Javier Castillejo Montes
> CC: Mapserver-users at lists.gis.umn.edu
> Asunto: Re: [Mapserver-users] Different colors in different layers
>>Hi!
>>First of all Im very bad english writer (its not my language so please
>>forgive my mistakes
>>and im really new at mapserver
>>I'll try to make myself clear
>>I have differents layers and one of then is a layer a field , this field
> has
>>various divisions(layer 1) and inside each division(divi A) there is one
>>more division (layer 1) (divi AA,AB,AC). Can anybody tell me how can I put
> a
>>different color for each diviA and a different color for divi AA,AB,AC
> Javier,
> You will need to know what all the possible divi are then you can try
> something like the following:
> LAYER
> NAME "your_layer"
> CLASSEXPRESSION "divi" # set the attribute field name here
> DATA ...
> CLASS
> EXPRESSION "A"
> STYLE
> COLOR 255 0 0 # red
> END
> END
> CLASS
> EXPRESSION "AA"
> STYLE
> COLOR 0 255 0 # green
> END
> END
> END
> You will have to add the other stuff you need in the layers, classes and
> styles to make them complete, but this should give you the idea of how
> to do it.
> EXPRESSION /^A/ # will select all "divi" starting with "A..."
> EXPRESSION /^A|^B/ # will select all "divi" starting with "A..." or "B..."
> -Steve W.
