[Mapserver-users] A STYLE with no COLOR is hardly a STYLE
Pericles S. Nacionales
nacional at cbs.umn.edu
Fri Jul 2 22:17:59 EDT 2004
Ryan,
I see your point but in Tyler's defense, he did say workaround. Perhaps
you should file a feature request/bug report in bugzilla. If you can
convince Steve and the other developers then you might have it quickly.
I do like the idea of being able to define the polygon outline style in
the same style as the polygon fill.
But here's another work around. Or, as I'd prefer to call, an
alternative method: 1. Define your layer as polygon but don't define an
outline color. 2. Create another layer from the same data but define
TYPE as line, also call it the same layer name (or define a GROUP name
for the two layers). Define your line STYLE on this layer.
Now, when you select the layer name, both of the layers are drawn.
So, while I like your idea I think the alternative I just showed you is
pretty flexible.
Cheers!
-Perry
On Fri, 2004-07-02 at 16:30, Ryan, Adam wrote:
> Sean,
> Thanks for the reply. Using multiple layers for stylistic reasons runs
> counter to the concept of the STYLE object.
> I'll just put this out again...why not have a TYPE parameter in the STYLE
> object?
> Thanks again,
> Adam
> -----Original Message-----
> From: Sean Gillies [mailto:sgillies at frii.com]
> Sent: Friday, July 02, 2004 11:57 AM
> To: Ryan, Adam
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] A STYLE with no COLOR is hardly a STYLE
> On Jul 2, 2004, at 10:29 AM, Ryan, Adam wrote:
> > Dear List,
> > I'm having a hard time with the concept of treating polygons as lines
> > when
> > there is no COLOR parameter in a STYLE object. This seriously limits
> > the
> > great improvement that stacked STYLE objects provide by essentially
> > forbidding a foreground color of a line-type STYLE. Many STYLE
> > objects that
> > render wonderfully in line-type LAYERs are simply not reproducible in
> > polygon-type LAYERs.
> > For example, if I want to use a 'railroad tie' style as an outline of
> > a simple fill style in a polygon-type layer, I'd want to use a symbol
> > like this that works in line-type layers:
> > SYMBOL
> > NAME "tie"
> > TYPE truetype
> > FONT "arial"
> > CHARACTER "|"
> > GAP 10
> > END
> > Problem is, with no COLOR parameter (which I can't use because it
> > would cause the features to be filled by this symbol) all I can get is
> > a 3 pixel wide outlined character if I use OUTLINECOLOR, or nothing at
> > all.
> > Is this correct or am I missing something here?
> > The push toward STYLE objects is right on, so why not put a TYPE
> > parameter
> > in the STYLE object?
> > Adam Ryan
> Adam,
> You have a good point. The current work-around is to
> 1) define a polygon-type layer for the fill
> 2) define a line-type layer for the polygon boundary using the very
> same data as the polygon fill layer.
> That you can render polygons as lines is a poorly documented and explained
> feature.
> cheers,
> Sean
> Sean Gillies
> sgillies at frii dot com
> http://users.frii.com/sgillies
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
"He's no geek.His tan's too good." -Benjamin Choate
