[Mapserver-users] mappostgis query
Markus Schnider
sp_ml at sourcepole.com
Mon Jul 5 07:52:58 EDT 2004
Hi all
I am perhaps in the wrong mailing list (it should be perhaps in the developer
mailinglist ...), but I could not run a query on a layer with more than
2'000'000 rows. So I tried to change the code. Than I had some results, and
the results comes faster!
mapserver 4.2 (mappostgis.c)
postgresql 7.4.2
postgis 0.8.1
Why is the following code (see below (1) ):
better than this (2)?
I've tried both versions and version (2) is faster.
(1)
if (strlen(user_srid) == 0)
sprintf(query_string_0_6,"DECLARE mycursor BINARY CURSOR FOR SELECT %s from
%s WHERE (%s) and (%s && setSRID( %s,find_srid('','%s','%s') ))",
columns_wanted,geom_table,layer->filter.string,geom_column,box3d,removeWhite(f_table_name),removeWhite(geom_column));
else
%s WHERE (%s) and (%s && setSRID( %s,%s) )",
columns_wanted,geom_table,layer->filter.string,geom_column,box3d,user_srid);
(2)
%s WHERE (%s)", columns_wanted,geom_table,layer->filter.string);
else
Thanks in advance
Markus Schnider
