[Mapserver-users] Itasca Demo DHTML Help?
Inge Keckeisen
inke03 at gmx.net
Wed Jul 7 02:38:04 EDT 2004
Hi Jerod,
I did the dhtml demo without frames in replacing the frames.html with a
html file without frameset but a normal body. In this new file the
javascript function "load_map()" is modified:
function load_map() {
var template;
var query = location.search.substring(1);
var pairs = query.split("&");
for(var i = 0; i < pairs.length; i++) {
var pos = pairs[i].indexOf('=');
if (pos == -1) continue;
var name = pairs[i].substring(0,pos);
if(name == 'map_web_template') {
template = pairs[i].substring(pos+1);
template = unescape(template.replace(/\+/g, " "));
break;
window.location.href = template + "?" + query;
You can call this function in the body tag of the new file -->
onLoad="load_map()".
Of course you have to modify the function "submit_form()" in the
index.html, so the new html file will be called instead of the frames.html:
function submit_form() {
var template =
document.demo.map_web_template.options[document.demo.map_web_template.selectedIndex].value;
if(template.indexOf("PART OF YOUR TEMPLATE NAME") != -1)
document.demo.action = "NEW.html";
Hope this was understandable, if not, send me a note and I send you my
modified files.
Regards,
Inge
>From: Jerod Clabaugh <jclabaugh at mac.com>
>Subject: [Mapserver-users] Itasca Demo DHTML Help?
>hello all:
>I have been able to modify the MS 4 Itasca demo to use my map file
>and data. Basically I want the use of the DHTML rubber band zoom box
>(dbox) but without using frames. I have been struggling and haven't
>been able to modify the code to not use frames. I want the query
>section to use a popup window instead of a lower frame. I'm not so
>concerned with the actually scripting necessary for the popup action
>itself but rather how to modify Steve Lime's code to remove the
>frames in the demo while still providing a functional zoom box.
>Does anyone have a simple solution for this using this DHTML zoom
>box without frames?
