[Mapserver-users] cant install Arcims WMS ...
Ozan EMEM
oemem at yildiz.edu.tr
Wed Jul 7 05:24:22 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_0008_01C4641D.55FB7AB0
Content-Transfer-Encoding: 7bit
Content-Type: text/plain;
charset="us-ascii"
i am new to map servers...
nowadays trying to install arcims wms and wfs... but i can't achieve the
first step. I am following the help documents, instructions etc... all the
documents give the same info. I am using IIS with ServletExec, arcims 9 and
they are working perfectly. To install wms first i found and modified the
WMSEsrimap_prop file as described. I created a virtual directory for
capabilities. I restarted IIS
And i tried to open
http://server/servlet/com.esri.wms.Esrimap?Cmd=ping
and i stopped here. An error appeared on the browser
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
<!DOCTYPE ServiceExceptionReport (View Source for full doctype...)>
<http://194.27.97.251/servlet/com.esri.wms.Esrimap?Cmd=ping##> -
<ServiceExceptionReport version="1.1.0">
<ServiceException>Access to the specified service is not
available</ServiceException>
</ServiceExceptionReport>
If any of you could help out I would be very happy with that.
Thanks...
Ozan EMEM
Research Assistant
Yildiz Technical University,
Department of Geodesy and Photogrammetric Engineering
Yildiz, Istanbul, TURKEY
www.yildiz.edu.tr/~oemem
www.194.27.97.251/website
Tel : (90) 212 2597070 - 2784
Content-Transfer-Encoding: quoted-printable
Content-Type: text/html;
charset="us-ascii"
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DGenerator content=3D"Microsoft Word 11 (filtered medium)">
<style>
/* Font Definitions */
@font-face
{font-family:Verdana;
panose-1:2 11 6 4 3 5 4 4 2 4;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0cm;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal-compose;
font-family:Arial;
color:windowtext;}
span.m1
{color:blue;}
span.pi1
{color:blue;}
span.b1
{font-family:"Courier New";
color:red;
font-weight:bold;
text-decoration:none none;}
span.d1
{color:blue;}
span.t1
{color:#990000;}
span.tx1
{font-weight:bold;}
@page Section1
{size:595.3pt 841.9pt;
margin:70.85pt 70.85pt 70.85pt 70.85pt;}
div.Section1
{page:Section1;}
</style>
</head>
<body lang=3DTR link=3Dblue vlink=3Dpurple>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Hi,<o:p></o:p></span></font></p>
font-family:Arial'>i am new to map =
servers...<o:p></o:p></span></font></p>
font-family:Arial'>nowadays trying to install arcims wms and wfs... but =
i can’t
achieve the first step. I am following the help documents, instructions =
etc...
all the documents give the same info. I am using IIS with ServletExec, =
arcims 9
and they are working perfectly. To install wms first i found and =
modified the WMSEsrimap_prop
file as described. I created a virtual directory for capabilities. I =
restarted
IIS<o:p></o:p></span></font></p>
font-family:Arial'><o:p> </o:p></span></font></p>
font-family:Arial'>And i tried to open<o:p></o:p></span></font></p>
font-family:Arial'>http://server/servlet/com.esri.wms.Esrimap?Cmd=3Dping<=
font-family:Arial'>and i stopped here. An error appeared on the =
browser<o:p></o:p></span></font></p>
<p class=3DMsoNormal style=3D'text-indent:-12.0pt'><span =
class=3Dm1><font size=3D2
color=3Dblue face=3DVerdana><span =
style=3D'font-size:10.0pt;font-family:Verdana'><?</span></font></span>=
<span
class=3Dpi1><font size=3D2 color=3Dblue face=3DVerdana><span =
font-family:Verdana'>xml version=3D"1.0" =
encoding=3D"UTF-8"
standalone=3D"yes" </span></font></span><span class=3Dm1><font =
size=3D2
style=3D'font-size:10.0pt;font-family:Verdana'>?></span></font></span>=
<font
size=3D2 face=3DVerdana><span =
style=3D'font-size:10.0pt;font-family:Verdana'> =
class=3Db1><b><font size=3D2
color=3Dred face=3D"Courier New"><span =
style=3D'font-size:10.0pt'> </span></font></b></span><font
style=3D'font-size:10.0pt;font-family:Verdana'> <span
class=3Dd1><font color=3Dblue><!DOCTYPE =
ServiceExceptionReport<i><span
style=3D'font-style:italic'> (View Source for full =
doctype...)</span></i>></font></span>
<p class=3DMsoNormal style=3D'text-indent:-24.0pt'><font size=3D2 =
style=3D'font-size:10.0pt;font-family:Verdana'><a
href=3D"http://194.27.97.251/servlet/com.esri.wms.Esrimap?Cmd=3Dping##"
onfocus=3D"h()"><b><font color=3Dred face=3D"Courier New"><span =
style=3D'font-family:
"Courier New";color:red;font-weight:bold'>-</span></font></b></a> <span
class=3Dm1><font color=3Dblue><</font></span><span class=3Dt1><font =
color=3D"#990000">ServiceExceptionReport
version</font></span><span class=3Dm1><font =
color=3Dblue>=3D"</font></span><b><span
style=3D'font-weight:bold'>1.1.0</span></b><span class=3Dm1><font =
color=3Dblue>"></font></span><o:p></o:p></span></font></p>
<p class=3DMsoNormal style=3D'text-indent:-24.0pt'><span =
color=3D"#990000">ServiceException</font></span><span
class=3Dm1><font color=3Dblue>></font></span><span =
class=3Dtx1><b>Access to the
specified service is not available</b></span><span class=3Dm1><font =
color=3Dblue></</font></span><span
class=3Dt1><font color=3D"#990000">ServiceException</font></span><span =
class=3Dm1><font
color=3Dblue>></font></span> <o:p></o:p></span></font></p>
class=3Dm1><font color=3Dblue></</font></span><span class=3Dt1><font
color=3D"#990000">ServiceExceptionReport</font></span><span =
class=3Dm1><font
color=3Dblue>><o:p></o:p></font></span></span></font></p>
<p class=3DMsoNormal style=3D'text-indent:-12.0pt'><font size=3D2 =
style=3D'font-size:10.0pt;font-family:Verdana'><o:p> </o:p></span></=
font></p>
<p class=3DMsoNormal style=3D'text-autospace:none'><font size=3D2 =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>If any of you could help =
out I would
be very happy with that.<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'><o:p> </o:p></span></fo=
nt></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Thanks...<o:p></o:p></span><=
/font></p>
face=3DArial><span
nt></p>
font-family:Arial'>-----------------------------------------------------<=
br>
Ozan EMEM</span></font><o:p></o:p></p>
font-family:Arial'>Research Assistant <br>
Yildiz Technical University,<br>
Department of Geodesy and Photogrammetric Engineering<br>
Yildiz, Istanbul, TURKEY<br>
<a =
href=3D"http://www.yildiz.edu.tr/~oemem">www.yildiz.edu.tr/~oemem</a></sp=
font-family:Arial'><a =
href=3D"http://www.194.27.97.251/website">www.194.27.97.251/website</a>
<br>
Tel : (90) 212 2597070 - 2784</span></font><font size=3D2 =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'><o:p></o:p></span></font></p=
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span =
style=3D'font-size:
12.0pt'><o:p> </o:p></span></font></p>
</div>
</body>
</html>
------=_NextPart_000_0008_01C4641D.55FB7AB0--
