[Mapserver-users] Q: ArcIMS style dynamic layers
Eduardo Spremolla
edspremolla at antel.com.uy
Wed Jul 7 08:18:41 EDT 2004
Bob:
You must include all the layers in the .map file, but only the ones you
always want with STATUS DEFAULT, the others ones may be turned on by
adding layer=LAYER_NAME to the cgi query parameters.
LALO
El mar, 06-07-2004 a las 20:38, bob man escribió:
> I've got a (what is probably a newbie) question. I'm
> coming from an ArcIMS background -- after reading over
> the mailing list archives I'm certainly not the only
> one ;) -- and that should explain the frame of
> reference for this question.
> One of the things I'd like to do is generate dynamic
> layers. From what I've read, it seems as though you
> need to use PHP (or some other scripting language) to
> do so. With ArcIMS, you can create a ".axl" file (a
> map file, more or less). Then, when querying a map
> service, you can include additional layers inside the
> ArcXML request. Does mapserv (the CGI app) have
> support for a similar request mechanism? Based on
> what I've read the answer is no, but I'd like to
> confim that.
> Thanks,
> Dave
> __________________________________
> Do you Yahoo!?
> Yahoo! Mail - Helps protect you from nasty viruses.
> http://promotions.yahoo.com/new_mail
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Eduardo Spremolla <edspremolla at antel.com.uy>
Antel I+D
