[Mapserver-users] why --> msQueryByAttributes():
Queryerror. No query expressiondefined
David Fawcett
David.Fawcett at state.mn.us
Wed Jul 7 09:49:37 EDT 2004
Javier,
The syntax for itemqueries changed after version 3.5 or so.
Queries no longer use a filter in the Map file. Instead, you need to
pass the variables 'qlayer', 'qitem', and 'qstring' in the URL. They
are documented here:
http://mapserver.gis.umn.edu/doc42/cgi-reference.html#qitem
It should look something like:
...&qlayer=layer1&qitem=FIELD2&qstring=('[FIELD2]'='10')
&qlayer=provin&qitem=NOMBRE&qstring='Juarez'
(This assumes that there is a 'provin' with the name 'Juarez'. If you
build this URL string dynamically in the form at the bottom of this
message, it should look something like this:
<td><img border="2"
src="[mapserv]?map=[map]&name=&mode=itemquerymap&mapext=shapes&qlayer=provin&qitem=NOMBRE&qstring='[name_esc]'
" height="300" width="300"></td>
David.
David J. Fawcett
MN Office of Environmental Assistance
>>> Javier Castillejo Montes <jcastil1 at tragsa.es> 7/7/2004 2:08:37 AM
mapserv_41.exe is the exe im using... the wrong thing could be my code,
that
is obsolete.
I took the code from a web page and translate it into my needs....
Javier
-----Mensaje original-----
De: David Fawcett [mailto:David.Fawcett at state.mn.us]
Enviado el: martes, 06 de julio de 2004 16:58
Para: mapserver-users at lists.gis.umn.edu; Javier Castillejo Montes
Asunto: Re: [Mapserver-users] why --> msQueryByAttributes():
Queryerror.
I may be mistaken, but the example looks a little old. What version
of
MapServer are you using?
David.
David J. Fawcett
>>> Javier Castillejo Montes <jcastil1 at tragsa.es> 7/6/2004 8:00:55 AM
Hi all,
Does anyone know why this code has an error. I'm just trying to use a
mapserver example from the internet, I copied the code made the
changes
necesaries and... ERROR!!!! :-(
### ERROR:
msQueryByAttributes(): Query error. No query expression defined.
### main html
<html>
<body>
<form name="mapserv" method="get"
action="//[host]/scripts/mapserv.exe">
<input type="text" name="mapserv" value="//[host]/scripts/mapserv.exe"
size=100%>
<input type="text" name="map" value="[path]/map/case1.map" size=100%>
<input type="text" name="map_web_imagepath" value="[path]/tmp/"
size=100%>
<input type="text" name="map_web_imageurl" value="[path]/tmp/">
<input type="text" name="mode" value="itemquery" size=100%>
<input type="text" name="qlayer" value="provin" size=100%>
<br><br><br><br><br><br>
Select
<input type="text" name="name" id="name" value="mad">
<br>
<input type="submit" value="Go!">
</form>
</body>
</html>
## map file
MAP
NAME case1
SHAPEPATH "../data"
SIZE 300 300
EXTENT -50000 4000000 1100000 4800000
WEB
IMAGEPATH '../data/tmp/'
IMAGEURL '../data/tmp/'
END
QUERYMAP
STATUS ON
STYLE HILITE
COLOR 255 255 0
END
LAYER
NAME provin
DATA provin
STATUS DEFAULT
TYPE POLYGON
FILTERITEM nombre
FILTER "%name%"
CLASS
COLOR 212 212 212
OUTLINECOLOR 0 0 0
TEMPLATE "../html/case1_template.html"
END
END
END
### template file
<html>
<head>
<title>MapServer Test Suite - ItemQuery</title>
</head>
<body bgcolor="#ffffff">
<font size="+2" face="arial,helvetica"><b>Case 1: Simple ItemQuery
With
QueryMap</b></font>
<p>
This is just a simple dump of a few attributes for an individual
polygon
in the test suites counties layer:
<p>
<b>Name:</b> [Name]<br>
<b>ID Provincia:</b> [prov]<br>
<b>Comunidad Code:</b> [Comunidadc]<br>
<p>
and here's the map of the query results (you can zoom to a set of
results as
well):
<p>
<table cellpadding="5">
<tr>
<td><img border="2" src="[img]" height="300" width="300"></td>
<td><img border="2"
src="[mapserv]?map=[map]&name=[name_esc]&mode=itemquerymap&mapext=shapes&qla
yer=[qlayer]" height="300" width="300"></td>
</tr>
</table>
</body>
</html>
thanks in advance
