[Mapserver-users] Itemquery - zooming to features
Mike Reilly
mikereilly_7 at hotmail.com
Wed Jul 7 18:37:38 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_3fbc_7fb0_6d45
Content-Type: text/plain; format=flowed
I have a mapserver application running quite nicely and now want to add the
ability to create a link that brings up a map zoomed in to a feature based
on that features SITEID field in a dbf file. This feature is similar to
that shown at this tutorial in case 1:
http://maps.dnr.state.mn.us/mapserver_demos/tests40/itemquery/test.html
To that effect, I've basically copied the tutorial and placed in my own
customisations to make it work with my data. So far I've not been terribly
succesful and get the following error:
msQueryByAttributes(): Query error. No query expression defined.
There is most definitely a field called SITEID in the dbf file for the
mergeplys layer. There is also a record with a SITEID of 1003.
I am using mapserver 4.0 windows binary distribution.
The URL that gets generated looks like this:
http://192.168.0.3/cgi-bin/mapserv.exe?mapserv=f%3A%2Fprogram+files%2Fapache+group%2Fapache2%2Fcgi-bin%2Fmapserv.exe&map=f%3A%2Fprogram+files%2Fapache+group%2Fapache2%2Fhtdocs%2FKitasoo%2Fquerytest.map&map_web_imagepath=f%3A%2Fprogram+files%2Fapache+group%2Fapache2%2Ftmp&map_web_imageurl=%2Ftmp%2F&mode=itemquery&qlayer=tuspoly&site_id=1003
I'm pretty sure I'm missing something basic somewhere. One issue (I don't
think this is what is causing the error message) is found in the template
file. I'm not quite sure what to do with some of the variables in this
spot:
src="[mapserv]?map=[map]&name=[name_esc]&mode=itemquerymap&mapext=shapes&qlayer=[qlayer]"
- I assume I need to change some of the values here. Any advice or
pointers to documentation greatly appreciated.
The mapfile I created looks like this:
MAP
NAME case1
SHAPEPATH tus
SIZE 300 300
EXTENT 768897.25886 810841.50306 876598.91242 913853.62854
WEB
IMAGEPATH 'f:/program files/apache group/apache2/htdocs/tmp/'
IMAGEURL 'http://192.168.0.3/tmp/'
END
QUERYMAP
STATUS ON
STYLE HILITE
COLOR 255 255 0
END
LAYER
NAME "landpl"
DATA "landpl"
STATUS DEFAULT
TYPE POLYGON
CLASS
COLOR 212 212 212
OUTLINECOLOR 0 0 0
END
END
LAYER
NAME tuspoly
DATA "mergeplys"
STATUS ON
TYPE POLYGON
FILTERITEM SITEID
FILTER "%site_id%"
CLASS
COLOR 160 160 255
OUTLINECOLOR 0 200 0
TEMPLATE case1_template.html
END
END
END
My HTML file used to generate the URL should be attached (I hope!).
_________________________________________________________________
Add photos to your e-mail with MSN Premium. Get 2 months FREE*
http://join.msn.com/?pgmarket=en-ca&page=byoa/prem&xAPID=1994&DI=1034&SU=http://hotmail.com/enca&HL=Market_MSNIS_Taglines
Content-Type: text/html; name="testquery.html"
Content-Transfer-Encoding: 8bit
Content-Disposition: attachment; filename="testquery.html"
<html>
<head>
<title>MapServer Test Suite - ItemQuery</title>
<script language="javascript" src="config.js"></script>
<script language="javascript">
var id = new Array('1001','1002','1003','1004','1005');
function write_counties() {
var i;
for(i=0; i<id.length; i++)
document.write("<option> " + id[i] + "\n");
function submit_case2() {
var i, sep='';
document.case2.map_county_filter.value = '/'; // start of a regex
for(i=0; i<document.case2.id.length; i++) {
if(document.case2.name.options[i].selected)
document.case2.map_county_filter.value = document.case2.map_county_filter.value + sep + document.case2.name.options[i].text;
sep = '|';
document.case2.map_county_filter.value += '/'; // end of a regex
</script>
</head>
<body bgcolor="#ffffff">
document.write("<font size=\"+2\" face=\"arial,helvetica\"><b>MapServer <a href=\"" + htmlroot + "\">Test Suite</a> - ItemQuery</b></font>");
</script>
<p>
<font size="+1" face="arial,helvetica"><b>Case 1: Simple ItemQuery With QueryMap</b></font>
<p>
<a href="querytest.map"><i>map file</i></a><br>
<a href="case1_template.html"><i>query template file</i></a>
<p>
document.write("<form name=\"case1\" method=\"get\" action=\"../../cgi-bin/mapserv.exe\">\n\n");
document.write("<input type=\"hidden\" name=\"mapserv\" value=\"" + mapserv + "\">\n");
document.write("<input type=\"hidden\" name=\"map\" value=\"" + root + "querytest.map\">\n");
document.write("<input type=\"hidden\" name=\"map_web_imagepath\" value=\"" + imagepath + "\">\n");
document.write("<input type=\"hidden\" name=\"map_web_imageurl\" value=\"" + imageurl + "\">\n");
</script>
<input type="hidden" name="mode" value="itemquery">
<input type="hidden" name="qlayer" value="tuspoly">
Pick one:
<select name="id" size="1">
<script language="javascript">write_counties()</script>
</select>
<input type="submit" value="Go!">
</form>
<p><hr noshade><p>
</body>
</html>
------=_NextPart_000_3fbc_7fb0_6d45--
