[Mapserver-users] problem QueryByPoint
passera
passera.ext at culture.gouv.fr
Thu Jul 8 04:42:10 EDT 2004
passera a écrit :
> Norbert Thieme a écrit :
>> passera schrieb:
>>> Hello,
>>> I'm a student french and my english is very bad.
>>> My problem are the function QueryByPoint and QueryByRect.
>>> I do not manage to recover information in the .dbf .
>>> My mapfile is:
>>> LAYER
>>> NAME immeuble
>>> TYPE polygon
>>> STATUS ON
>>> DATA IMMEUBLE41
>>> CLASSITEM "SDAP_X"
>>> * * CLASS
>>> COLOR 0 0 0
>>> OUTLINECOLOR 0 0 0
>>> NAME "Immeuble"
>>> SYMBOL 0
>>> TEMPLATE "query.html"
>>> END
>>> END
>>> My .php is:
>>> $layer = $map->getlayerbyname("immeuble");
>>> $point =
>>> pixeltogeo($map,$HTTP_POST_VARS["mapa_x"],$HTTP_POST_VARS["mapa_y"]);
>>> $queryfound = $map->querybypoint($point,MS_SINGLE,-1);
>>> if ($queryfound == MS_SUCESS){
>>> $count_results = $layer->getnumresults();
>>> print($count_results);
>>> if ($queryfound == MS_FAILURE){
>>> print("failure");
>>> // $queryfound is every time equal MS_FAILURE
>>> Please help
>>> Mapserver-users mailing list
>>> Mapserver-users at lists.gis.umn.edu
>>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
>> Hi,
>> Try something like this:
>> if (@$layer->queryByPoint($q_point, $q_mode, 0) == MS_SUCCESS) // you
>> can leave the @ to see the messages
>> $res_count = $layer->getnumresults();
>> for ($i = 0; $i < $res_count; $i++)
>> $result = $layer->getResult($i);
>> $layer->open();
>> $items = $layer->getitems(); // get the names of the fields - you
>> only need this once per layer
>> $data_shp = $layer->getshape($result->tileindex,
>> $result->shapeindex); // get the shapeobj - each result has a shape-,
>> tile- and classindex
>> $layer->close();
>> $data_val = $data_shp->values; // get the values from the shapeobj
>> Regards,
>> Norbert
> Thank you very much. My problem was : $layer->queryByPoint($q_point,
> $q_mode, 0) and me I wrote $map->queryByPoint($q_point, $q_mode, 0).
> $layer = layerObj --> right for use querybypoint
> $map = mapObj --> wrong for use querybypoint
Correction I had forgotten to put $layer->set("status",1); Sorry
