[Mapserver-users] normal behaviour of line drawing?
Michael Schulz
mschulz at webgis.de
Thu Jul 8 11:24:26 EDT 2004
This is a multi-part message in MIME format.
--------------070502080007010301050308
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Content-Transfer-Encoding: 8bit
i have attached an image which shows some line crossings drawn with mapserver-4.2beta (i know it's a
bit old ...). But i found this problems with other (only older) versions too.
The layer with the 3 classes (Autobahn, Bundesstrasse, Landstrasse) has overlapping lines. But as
you can see in the picture not one class gets drawn over the other, but line symbols are sometimes
over, sometimes under another class. I thought the order of the classes in a layer effects also the
drawing, but i might be mistaken.
Has the line drawing been updated in the latest versions? If so, i will try it with a newer version.
Or should i file a bug?
Cheers, Michael
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de/www.zopecms.de
Content-Type: image/gif;
name="overlap_classes.gif"
Content-Transfer-Encoding: base64
Content-Disposition: inline;
filename="overlap_classes.gif"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--------------070502080007010301050308--
