[Mapserver-users] RE: sid images
Swaminathan, Gayathri
gayathri at ou.edu
Thu Jul 8 16:08:19 EDT 2004
Hi Alexandre:
Yup. Mapserver can be used with Mr.SID files., but you need to purchase the Mr.SID DSDK from Lizard Tech.
Here is how to do it..(http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0402/msg00699.html)
Contents of the above link:
1)Here is a link to GDAL building instructions..."Under External
Libaries"
http://www.remotesensing.org/gdal/gdal_building.html
You need the decoder SDK from Lizardtech
2) Attached is the contact of the person to obtain this DSDK from for
Midwest, but if you contacted Lizardtech they can give a local contact.
3) Cost of DSDK is $500
4) One problem I ran into when using this option. Use the cvs-daily.
Let me know if you run into any other issues..and need help.
Thanks,
Gayathri
PS: There are some archives in mapserver list on the build-errors and shortcoming in
mapserver-user list archive...for your reference
> -----Original Message-----
> From: Alexandre Marino [mailto:marino at cria.org.br]
> Sent: Thursday, July 08, 2004 2:17 PM
> To: Swaminathan, Gayathri
> Subject: sid images
> Hello Gayathri, I saw a message from you in the mapserver
> list trying to
> use Mr.Sid images.
> I have some SID's images downloaded from NASA site and I'd
> like to use
> in MapServer.
> Did you find anything about it ?
> My GDAL don't support SID, what I need to use this kind of
> file ? Do you know if I can convert SID in TIFF using a free
> software ? Here we
> have only arcMap and I don't know if it can.
> Any ideas on this? Please!
> Alexandre Marino - Analista de Sistemas
> CRIA - Centro de Referência em Informação Ambiental
http://www.cria.org.br
