[Mapserver-users] WMS GetLegendGraphic and KEYIMAGE
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Thu Jul 8 16:09:47 EDT 2004
> -----Original Message-----
> From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
> Sent: Thursday, July 08, 2004 4:00 PM
> To: Kralidis,Tom [Burlington]
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] WMS GetLegendGraphic and KEYIMAGE
> Tom,
> I understand what you suggest but at the same time, the keyimage is
> just an additional way to generate icons beside the defaut way of
> generating them (using classes defined on the layer). Thus the use of
> the legend's keysizex and keysizey is the one that make more
> sense. If
> we add a specific size parameters for layers using a
> keyimage, we need
> to do the same for other types of layers so we can generate icons of
> diffrent siezes. What I propose as a compromise is to maybe use a
> metadata at the layer level that would be used by the
> LegendURL to fetch
> the width and height for that specific layer. By default the
> LegendURL
> would use the legend's keysizex/keysizey. Is this acceptable ?
Yes. Bottom line is, from an OGC client point of view, is that
Capabilities should provide me with everything I need to know about a
service without apriori knowledge (also hence the need for WMS
Capabilities to expose LegendURL, MetadataURL, and DataURL).
Cheers
..Tom
> Later,
> >>Sent: Wednesday, July 07, 2004 2:14 PM
> >>If it is for a specific layer, why not use the width and height
> >>parameters in the request ? Do you have other suggestions ?
> > I could explicitly, however if I'm a WMS client, my first
> inclination
> > is to do a GetCapabilities, and go from there. This is where
> > LegendURL would be useful.
> > I suggest a KEYIMAGESIZE be added so that when LegendURL does get
> > added to WMS GetCapabilities, that the width and height
> attributes are
> > taken from KEYIMAGESIZE (or, even better, if MapServer can
> figure out
> > the KEYIMAGE value extents :))
> > What do you think?
> > ..Tom
> >>>Right, but doesn't the legend object define a legend for
> >>the *entire*
> >>>WMS? This is a specific layer level legend KEYIMAGE --
> >>i.e. I don't
> >>>want all my legend image dimensions to be the size of the
> >>KEYIMAGE in
> >>>the one layer.
> >>>..Tom
> >>>>Sent: Wednesday, July 07, 2004 10:21 AM
> >>>>Tom,
> >>>> Here is how the size is determined :
> >>>> - If Width and Height parameter are passed in the
> >>>>GetLegendGraphic request , they will be used.
> >>>> - If not, it will use the size oparameters in the
> legend object
> >>>> - if none of the above is valid, the defaut size will
> be 20/20.
> >>>>Later,
> >>>>>Hi,
> >>>>>I've created a WMS, which has a layer, which defines
> >>>>KEYIMAGE in the
> >>>>>CLASS object.
> >>>>>>From what I understand, KEYIMAGE points to a static
> image file, so
> >>>>>>when
> >>>>>requesting a legend (either through OGC:WMS or classic mapserv
> >>>>>mode=legend), the static image is fed back.
> >>>>>When I request GetLegendGraphic from my WMS layer with
> >>>>KEYIMAGE, the
> >>>>>image comes back really small (i.e. 20 x 10). My legend
> >>>>image is like
> >>>>>300 x 50 -- the output image looks like it scrunched
> into 20 x 10.
> >>>>>Suggestions?
> >>>>>Thanks
> >>>>>..Tom
> >>>>>_______________________________________________
> >>>>>Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> >>>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> >>>>Assefa Yewondwossen
> >>>>Software Analyst
> >>>>Email: assefa at dmsolutions.ca
> >>>>http://www.dmsolutions.ca/
> >>>>Phone: (613) 565-5056 (ext 14)
> >>>>Fax: (613) 565-0925
> >>Assefa Yewondwossen
> >>Software Analyst
> >>Fax: (613) 565-0925
> Assefa Yewondwossen
> Software Analyst
> Fax: (613) 565-0925
