[Mapserver-users] How to add text to a legend
Attri, Abhishek
aattri at cba.ua.edu
Fri Jul 9 16:18:29 EDT 2004
Thanks a lot Eric! You were right, and everything works fine now.
-Abhishek
-----Original Message-----
Sent: Friday, July 09, 2004 3:02 PM
To: Attri, Abhishek
Cc: Mapserver List
Subject: RE: [Mapserver-users] How to add text to a legend
On Fri, 2004-07-09 at 15:50, Attri, Abhishek wrote:
> There is one layer, and two classes. All are set to "ON". Everything
> works right except the legend. I get only one legend image for two
> classes, and also the legend text is missing.
> Here is a sample of the code I am using to create layer, legend, and
> classes:-
> // create a legend
> $map->legend->set(keysizex, 12);
> $map->legend->set(keysizey, 12);
> //$map->legend->imagecolor->setRGB(200, 225, 124);
> $map->legend->label->set(type, MS_BITMAP);
> $map->legend->label->set(size, MS_MEDIUM);
> //$map->legend->label->set(font, test);
> $map->legend->label->color->setRGB(0, 0, 89);
> $map->legend->set(status, MS_ON);
> $image2 = $map->drawLegend();
> $image_url2=$image2->saveWebImage();
> // create layer
> $layer = ms_newLayerObj($map);
> $layer->set(name,"county");
> $layer->set(type,MS_LAYER_POLYGON);
> $layer->set(status,MS_ON);
> $layer->set(data,"counties");
> $layer->set(tolerance,10);
> $layer->set(classitem,"POP_2000");
> // create class1
> $class1 = ms_newClassObj($layer);
> $class1->set(status, MS_ON);
> $class1->set(name, 'myclass');
> //$class1->set(title, test1);
> $class1->setexpression('([POP_2000]<50000)');
> // create style
> $style = ms_newStyleObj($class1);
> $style->color->setRGB(255, 185, 15);
> $style->outlinecolor->setRGB(0, 0, 0);
> // create class2
> $class2 = ms_newClassObj($layer);
> $class2->set(status, MS_ON);
> $class2->set(name, 'myclass2');
> //$class2->set(title, test2);
> $class2->setexpression('([POP_2000]>50000)');
> $style = ms_newStyleObj($class2);
> $style->color->setRGB(139, 0, 0);
> Please help me understand what I am missing here.
I think you will need to draw your legend after you have created your 2
classes, not before.
Eric
