[Mapserver-users] (no subject)
Frans Knibbe
frans at geodan.nl
Mon Jul 12 08:53:51 EDT 2004
Hello people,
I am still trying to get MapServer 4.2 to produce SWF output. So far, I
have not succeeded so I would like to explain what I am doing, hoping that
someone spots the problem.
I have a simple map file:
MAP
DEBUG ON
NAME "Test"
EXTENT -180 -90 180 90
SIZE 800 600
SHAPEPATH "E:\geodata\world\"
UNITS dd
PROJECTION
"init=epsg:4326"
END
WEB
METADATA
"wms_title" "Test"
"wms_onlineresource"
"http://frans:92/srdag/frans/mapserv.exe?map=test2.map&"
"wms_srs" "EPSG:4326"
END
IMAGEPATH "E:\temp\"
IMAGEURL "/temp/"
LOG "E:/temp/mapserv.log"
END
OUTPUTFORMAT
NAME png
MIMETYPE image/png
DRIVER GD/PNG
EXTENSION png
IMAGEMODE PC256
TRANSPARENT TRUE
END
OUTPUTFORMAT
NAME swf
MIMETYPE "application/x-shockwave-flash"
DRIVER swf
IMAGEMODE PC256
FORMATOPTION "OUTPUT_MOVIE=SINGLE"
END
LAYER
NAME "cities"
DATA "cities"
TYPE POINT
CLASS
COLOR 255 0 0
END
END
END
As you can see, the data source is a shapefile containing only points. When
I request a PNG image, I get a map. In the error log file, the message
"msBuildPath: Unable to access file" is written, however. I presume this is
not a serious error, because I do get a map. The same error is written if
I request a SWF file, but in this case I don't see a map. The flash player
*is* started, because if I right click in the browser window I get a flash
player menu. An example of the map request:
http://frans:92/srdag/frans/mapserv.exe?map=test2.map&version=1.1.0&request=GetMap&layers=cities&styles=&SRS=epsg:4326&bbox=-150,-90,150,90&width=800&height=600&format=application/x-shockwave-flash
The imagepath is writable by the web server user, as is proven by the fact
that the mapserver log file is in the same directory, and this file gets
updated with every request.
In this thread:
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0402/msg00063.html
, Perry N. writes that HTML templates are needed for SWF output, at least,
that is how I understand it. Can anyone confirm if this is true? If so,
what should be in the template file?
Using: MapServer 4.2, precompiled for windows with Oracle support (and SWF
of course), windows XP, Apache 2.50, flash plugin 7.
Greetings,
Frans Knibbe
