[Mapserver-users] using URL's in pixmap symbol
Daniel Morissette
dmorissette at dmsolutions.ca
Tue Jul 13 01:37:14 EDT 2004
Steve Lime wrote:
> It shouldn't work, but it shouldn't blow up either. If you do get a segfault or something particularly nasty then please file a bug so that it gets addressed.
> There are not immediate plans to add this functionality, so only local images may be accessed. The place to add this is in mapsymbol.c in the function msAddImageSymbol(). One would need to leverage lubcurl to read the image and somehow turn it into a GD image internally. It's be really nice if GD supported this itself!
Hint: you'd want to call msHTTPGetFile() (maphttp.c) to fetch the image
before passing it to GD.
Note that doing this will slow down you map draws if you fetch the image
on every request, so you should pass the parameter
bCheckLocalCache=MS_TRUE to msHTTPGetFile(). If CheckLocalCache==MS_TRUE
then if the output file already exists then is is not downloaded again,
and status 242 is returned.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
