[Mapserver-users] query by record num
Eric Bridger
eric at gomoos.org
Tue Jul 13 15:58:35 EDT 2004
On Tue, 2004-07-13 at 13:41, Nikolai Vladychevski wrote:
> Hello,
> I have a shapefiles with lines or polygons and I want to query an item by
> its sequencial number in the shapefile, for example, I want to select the
> polygon number 239 on the map. I don't have any unique identifier in the DBF
> file. Can be a shape queried by its record number? If so how? I supose I
> need to use queryByAttributes(string qitem, string qstring, int mode) call,
> but how do I tell it to search by record number?
I'm assuming you're using mapscript.
The Layer object has a getShape(tileindex, shapeindex) method so you
could do: $shape = $layer->getShape(-1, 239). But I guess the real
question is how to change the attributes on that shape? You could try
getting the Layer's Class's Style object and setting its color
attributes then calling $shape->draw(). After you've already drawn the
layer.
Eric
