[Mapserver-users] PHP/Mapscript imageObj
Sean Gillies
sgillies at frii.com
Tue Jul 13 16:27:42 EDT 2004
On Jul 13, 2004, at 1:35 PM, Don Drake wrote:
> I was wondering if there are any plans to update the PHP/Mapscript
> libraries to get them more in sync with the Perl/Python versions.
> I was trying to generate GeoTiffs with PHP/Mapscript and ran into some
> troubles. It would generate the .tiff file just fine, but there was
> no geo-information embedded when inspecting with gdalinfo.
> I tracked the problem down to the imageObj not taking a map reference
> as a parameter when saving. The Perl module does, and uses the
> projection information of the map as a data source for the GeoTifff's
> reference points and datum.
> I was able to convert my PHP code to Perl/Mapscript to get this to
> work, but would really like a single-code base (language) for my
> project.
> Thanks.
> -Don Drake
Enter a new issue in the tracker under mapscript-PHP
http://mapserver.gis.umn.edu/bugs/enter_bug.cgi
and the PHP developers will get to it when they can, and that's
usually very promptly. This is the only sure way to get attention
to an issue.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
