[Mapserver-users] WMS client re-projection errors
Matthew Perry
mtperry78 at sbcglobal.net
Tue Jul 13 17:20:10 EDT 2004
Tyler,
The area is all in zone 10. And the nad83->nad27
datum shifts are certainly working. Maybe it's just
wgs84->nad27??
- matt
--- Tyler Mitchell <tjmitchell at riverside.bc.ca> wrote:
> Is the image crossing UTM zones?
> I recall reading something very recently that says
> Proj couldn't handle
> datum shifts, but may now. I'm not sure that's the
> issue though.
> mapserver-users-admin at lists.gis.umn.edu wrote on
> 07/13/2004 12:31:20 PM:
> > Hi folks,
> > I have some shapefiles in UTM, NAD27, Zone 10
> > (epsg:26710) which I'm trying to overlay on a WMS
> > shaded relief layer from the USGS in Geographic,
> WGS84
> > (epsg:4326). The problem is a noticable distortion
> on
> > the y axis. Features line up at the center of the
> > image, but become more and more distorted as you
> move
> > above or below the center-line.
> > These three images should capture the idea (keep
> your
> > eye on the peak in relation to the roads around
> it):
> > http://darkstar.rr.nu/download/mapserv1.jpg
> > http://darkstar.rr.nu/download/mapserv2.jpg
> > http://darkstar.rr.nu/download/mapserv3.jpg
> > It is almost as though the WMS image is vertically
> > compressed. However, when using a WMS image from
> > terraserver (nad83), the map is aligned properly.
> I am
> > running mapserver 4.2.0 on slackware linux with
> proj
> > 4.4.7 & the datum shift files. Perhaps the
> requested
> > WMS extents are not accurate because of the datum
> > shift?? Is there something unique to shifting from
> > wgs84 to nad27?? Anyone have any ideas?
> > The abbreviated mapfile is as follows:
> > MAP
> > PROJECTION
> > "init=epsg:26710"
> > # UTM zone 10, Nad27, meters
> > END
> > LAYER
> > NAME "Shaded_relief"
> > GROUP "bg"
> > STATUS OFF
> > TYPE RASTER
> > CONNECTIONTYPE WMS
> > CONNECTION
"http://gisdata.usgs.net:80/servlet/com.esri.wms.Esrimap?
> > servicename=USGS_WMS_NED&"
> > METADATA
> > "wms_srs" "EPSG:4326"
> > "wms_title" "Shaded Relief"
> > "wms_name" "US_NED_Shaded_Relief"
> > "wms_server_version" "1.0.0"
> > "wms_format" "image/png"
> > "wms_group_title" "background"
> > END
> > PROJECTION
> > "init=epsg:4326"
> > END
> > END
> > LAYER
> > NAME "Roads"
> > STATUS OFF
> > DATA "clip1"
> > TYPE LINE
> > TOLERANCE 2
> > DUMP true
> > METADATA
> > "wms_title" "Klamath Basin Roads"
> > "wms_srs" "EPSG:26710"
> > "wms_abstract" ""
> > "wfs_title" "Klamath Basin Roads"
> > "wfs_srs" "EPSG:26710"
> > "wfs_abstract" ""
> > END
> > CLASS
> > NAME "Roads"
> > STYLE
> > SYMBOL 1
> > SIZE 2
> > COLOR 0 0 0
> > END
> > END
> > END
> > END
> > Here is a link to a small, clipped shapefile if
> anyone
> > feels inclined to try it out...
> > http://darkstar.rr.nu/download/clip1.zip
> > ... and the urls to recreate the three sample
> images
> > are:
> > http://localhost/cgi-bin/mapserv?
mode=map&map=/var/www/htdocs/klamath2/klamath2.map&mapext=594418.
2128140883+4727975.646318736+602962.0885061937+4733853.
> 945029724&mapsize=610+420&layers=Roads+Shaded_relief
mode=map&map=/var/www/htdocs/klamath2/klamath2.map&mapext=594411.
1981378223+4730115.122579895+602955.0738299277+4735993.
> 421290884&mapsize=610+420&layers=Roads+Shaded_relief
1981378224+4726172.874518348+602955.0738299278+4732051.
> 173229337&mapsize=610+420&layers=Roads+Shaded_relief
> > Thanks... Any ideas are greatly appreciated!!
> > Matthew Perry
> > Humboldt State University
> > Natural Resources Planning
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
