[Mapserver-users] RE: Mapserver-users digest, Vol 1 #581 - 53 msgs
Taha Al Sayed
t_alsayed at thuraya.com
Wed Jul 14 11:23:30 EDT 2004
Frank and Norbert
Changing the projection did not solve the problem. But I have reconfigured the mapserver, but before reconfiguring I deleted the mapserv file. Only then I got the following using ldd mapserv:
[root at localhost cgi-bin]# ldd mapserv
libgd.so.2 => /usr/local/lib/libgd.so.2 (0x40031000)
libjpeg.so => /usr/lib/libjpeg.so (0x4006b000)
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x4008a000)
libz.so => /usr/lib/libz.so (0x400be000)
libtiff.so.3 => /usr/local/lib/libtiff.so.3 (0x400cc000)
libproj.so.0 => /usr/local/lib/libproj.so.0 (0x4010e000)
libgdal.so => /usr/local/lib/libgdal.so (0x40142000)
libm.so.6 => /lib/i686/libm.so.6 (0x409ba000)
libc.so.6 => /lib/i686/libc.so.6 (0x409dd000)
libpthread.so.0 => /lib/i686/libpthread.so.0 (0x40b19000)
libXpm.so.4 => /usr/X11R6/lib/libXpm.so.4 (0x40b2e000)
libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0x40b3d000)
libpng.so.2 => /usr/lib/libpng.so.2 (0x40c34000)
libpq.so.2 => /usr/lib/libpq.so.2 (0x40c55000)
libxerces-c1_6_0.so => /usr/local/lib/libxerces-c1_6_0.so (0x40c66000)
libogdi31.so => /usr/local/lib/libogdi31.so (0x40fbb000)
libdl.so.2 => /lib/libdl.so.2 (0x40fe2000)
libcurl.so.2 => /usr/local/lib/libcurl.so.2 (0x40fe6000)
libstdc++-libc6.2-2.so.3 => /usr/lib/libstdc++-libc6.2-2.so.3 (0x41006000)
/lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
libssl.so.2 => /lib/libssl.so.2 (0x41049000)
libcrypto.so.2 => /lib/libcrypto.so.2 (0x41076000)
libkrb5.so.3 => /usr/kerberos/lib/libkrb5.so.3 (0x4113a000)
libk5crypto.so.3 => /usr/kerberos/lib/libk5crypto.so.3 (0x41192000)
libcom_err.so.3 => /usr/kerberos/lib/libcom_err.so.3 (0x411a3000)
libcrypt.so.1 => /lib/libcrypt.so.1 (0x411a7000)
libresolv.so.2 => /lib/libresolv.so.2 (0x411d4000)
libnsl.so.1 => /lib/libnsl.so.1 (0x411e6000)
libexpat_ogdi31.so => /usr/local/lib/libexpat_ogdi31.so (0x411fc000)
..>It seems that this time I have all the libraries referenced. When I tried the file again I got the same error
loadProjection(): Projection library error. Projection support is not available.
I'll try to re-install redhat and start the installation on a fresh system. Maybe I can eliminate the problems.
Regards,
Taha
-----Original Message-----
From: mapserver-users-admin at lists.gis.umn.edu [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of mapserver-users-request at lists.gis.umn.edu
Sent: Tuesday, July 13, 2004 9:00 PM
To: mapserver-users at lists.gis.umn.edu
Subject: Mapserver-users digest, Vol 1 #581 - 53 msgs
Send Mapserver-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Mapserver-users digest..."
Today's Topics:
1. Fw: [Mapserver-users] symbol question (fx gamoy)
2. Re: Mapserver-users digest, Vol 1 #580 - 31 msgs (Ronald Kozlowski)
3. Re: Fw: [Mapserver-users] symbol question (Eric Bridger)
4. Re: Fw: [Mapserver-users] symbol question (Mathieu Parent)
5. getInteger(): Symbol definition error. (Williams John)
6. ms42pg.zip (Windows binary download) (Scott Meeks)
7. tileindex problems (Dion Duran)
8. Re: ms42pg.zip (Windows binary download) (Pericles S. Nacionales)
9. More info on strange mapserv - mode=map behavior (Davis Michael A DPW GIS TECH)
10. Re: tileindex problems (Frank Warmerdam)
11. Unable to download windows binaries (Richard Orchard)
12. Re: Your website (steve.lime at dnr.state.mn.us)
13. Re: PHP Mapscript processtemplate( ) problems (Daniel Morissette)
14. Re: changelog (Daniel Morissette)
15. Re: Unable to download windows binaries (Daniel Morissette)
16. Re: symbol question (Steve Lime)
17. Re: getInteger(): Symbol definition error. (Daniel Morissette)
18. Re: getInteger(): Symbol definition error. (Steve Lime)
19. Re: question about legendurl_href in the history.txt
file (Daniel Morissette)
20. Re: CreateLegendIcon and FAQ suggestion (Daniel Morissette)
21. MapServer 4.2.1 released (Daniel Morissette)
22. Re: using URL's in pixmap symbol (Daniel Morissette)
23. Re: Is there a problem with WMS getCapabilities
with VERSION=1.1.1? (Daniel Morissette)
24. Re: Road Labels (Michael Schulz)
25. RE Mapserver Windows Installation (VILLOIN Franck DSIC BMS)
26. RE: Problem in installing Proj4 and GDAL for Linux RH Advanced Server (Taha Al Sayed)
27. input using mapserver (Brian Russo)
28. bug report missing support (=?iso-8859-1?b?U+liYXN0aWVu?= DUBOIS)
29. Spanish Wiki - New Documentation (Merlos)
30. Unable to access the windows binaries for mapserver (Render, Kathy S.)
31. Re: Problem in installing Proj4 and GDAL for Linux
RH Advanced Server (Frank Warmerdam)
32. RE: Change Projection (e.g. Geographic to Robinson) (Pagurek, Debbie)
33. about 2nd MUM (Eduardo Patto Kanegae)
34. RES: [Mapserver-users] CreateLegendIcon and FAQ suggestion (Murilo Lacerda Yoshida)
35. Re: about 2nd MUM (Jeff McKenna)
36. RE: Change Projection (e.g. Geographic to
Robinson) (Stefan Schwarzer)
37. Map of MapServer Users (Eduardo Patto Kanegae)
38. adding dynamic charts on the map (eric.belenfant)
39. Re: tileindex problems (Tyler Mitchell)
40. Mr. SID to GeoTIFF (bean at vt.edu)
41. Using a polygon instead of a bounding box? (Timothy Rupe)
42. Re: Mr. SID to GeoTIFF (Jerrad Pierce)
43. Re: adding dynamic charts on the map (Eric Bridger)
44. JOIN problems (BONNER S KARGER)
45. Re: Using a polygon instead of a bounding box? (Jerl Simpson)
46. Source Shape data in 3 dimension (Trent Burton)
47. Brazillian maps (Jerl Simpson)
48. RE: getInteger(): Symbol definition error. (Howard Mark)
49. RE: Mr. SID to GeoTIFF (Ed McNierney)
--__--__--
Message: 1
To: <mapserver-users at lists.gis.umn.edu>
Subject: Fw: [Mapserver-users] symbol question
Date: Mon, 12 Jul 2004 19:19:28 +0200
This is a multi-part message in MIME format.
------=_NextPart_000_00D0_01C46845.26B0CE50
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
hello
Thanks for your post
but i can't find any parameter CHAR in the label object...
and mapserver don't want it.
Do you have special configuration? ( i am running a maperver 3.6.3 =
release on win2000)
thanks
fx
----- Original Message -----=20
To: mapserver-users at lists.gis.umn.edu=20
Sent: Saturday, July 10, 2004 1:28 PM
Subject: Re: [Mapserver-users] symbol question
fx gamoy a =E9crit :
Hello world,
i'd like to obtain lines with oriented triangle in order to show the =
direction of a track.
I have made several test but nothing very interesting..
thanks in advance..
fx
Try to use a label and the "labelangleitem" attribute of the layer =
object.
Use a font with an arrow as char (Windings for example).
LAYER
LABELANGLEITEM arrow_angle
LABEL
TYPE TRUETYPE
FONT windings
CHAR =E9
END
END
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD><TITLE></TITLE>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.2600.0" name=3DGENERATOR></HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>hello</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks for your post</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>but i can't find any parameter CHAR in =
the label=20
object...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>and mapserver don't want =
it.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Do you have special configuration? ( i =
am running a=20
maperver 3.6.3 release on win2000)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>thanks</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>fx</FONT></DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV style=3D"FONT: 10pt arial">----- Original Message ----- </DIV>
<DIV=20
style=3D"BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: =
black"><B>From:</B>=20
<A title=3Dmathieuparent at infonie.fr=20
href=3D"mailto:mathieuparent at infonie.fr">Mathieu Parent</A> </DIV>
<DIV style=3D"FONT: 10pt arial"><B>To:</B> <A=20
title=3Dmapserver-users at lists.gis.umn.edu=20
href=3D"mailto:mapserver-users at lists.gis.umn.edu">mapserver-users at lists.g=
is.umn.edu</A>=20
</DIV>
<DIV style=3D"FONT: 10pt arial"><B>Sent:</B> Saturday, July 10, 2004 =
1:28=20
PM</DIV>
<DIV style=3D"FONT: 10pt arial"><B>Subject:</B> Re: [Mapserver-users] =
symbol=20
question</DIV>
<DIV><BR></DIV>fx gamoy a =E9crit :<BR>
<BLOCKQUOTE cite=3Dmid017601c465cf$587fc260$0102a8c0 at geomatika =
type=3D"cite">
<STYLE></STYLE>
<DIV><FONT face=3DArial size=3D2>Hello world,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>i'd like to obtain lines with =
oriented triangle=20
in order to show the direction of a track.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I have made several test but =
nothing very=20
interesting..</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>thanks in advance..</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>fx</FONT></DIV></BLOCKQUOTE>Try to =
use a label=20
and the "labelangleitem" attribute of the layer object.<BR>Use a font =
with an=20
arrow as char (Windings for =
example).<BR><BR>LAYER<BR> =20
...<BR> LABELANGLEITEM=20
arrow_angle<BR> =20
LABEL<BR> TYPE=20
TRUETYPE<BR> =20
...<BR> FONT=20
windings<BR> =
CHAR=20
=E9<BR> =
END<BR>END<BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_00D0_01C46845.26B0CE50--
--__--__--
Message: 2
Date: Mon, 12 Jul 2004 13:38:24 -0400
Subject: [Mapserver-users] Re: Mapserver-users digest, Vol 1 #580 - 31 msgs
I am attending a Conference and will be out of the office till the 19th.
--__--__--
Message: 3
Subject: Re: Fw: [Mapserver-users] symbol question
To: fx gamoy <fx.gamoy at mapxplore.com>
Cc: Mapserver List <mapserver-users at lists.gis.umn.edu>
Date: 12 Jul 2004 14:32:02 -0400
On Mon, 2004-07-12 at 13:19, fx gamoy wrote:
> hello
> Do you have special configuration? ( i am running a maperver 3.6.3 release on win2000)
> thanks
> fx
> From: Mathieu Parent
> fx gamoy a écrit :
> Hello world,
> i'd like to obtain lines with oriented triangle in order to show the direction of a track.
> thanks in advance..
> fx
> Try to use a label and the "labelangleitem" attribute of the layer object.
> LAYER
> LABEL
> TYPE TRUETYPE
> FONT windings
> CHAR é
> END
> END
You can use the CLASS TEXT object.
For TrueType symbols you'd use CHARACTER in the SYMBOL object.
--__--__--
Message: 4
Date: Mon, 12 Jul 2004 20:32:19 +0200
--------------090006090605090308080000
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Content-Transfer-Encoding: 8bit
I'm sorry, i have no CHAR parameter.
I was just trying to use LABEL object, which have a dynamic angle.
If you have a column in your dbf with 'é' in it for each row, you can use
LAYER
LABELITEM the_column
LABEL
TYPE TRUETYPE
FONT windings
END
END
that's the idea but
it's not really nice !!!
fx gamoy a écrit :
> hello
> release on win2000)
> thanks
> fx
> *From:* Mathieu Parent <mailto:mathieuparent at infonie.fr>
> *To:* mapserver-users at lists.gis.umn.edu
> <mailto:mapserver-users at lists.gis.umn.edu>
> *Sent:* Saturday, July 10, 2004 1:28 PM
> *Subject:* Re: [Mapserver-users] symbol question
> fx gamoy a écrit :
>> Hello world,
>> thanks in advance..
>> fx
> object.
> LAYER
> LABEL
> TYPE TRUETYPE
> FONT windings
> CHAR é
> END
> END
Content-Type: text/html; charset=us-ascii
Content-Transfer-Encoding: 7bit
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html;charset=ISO-8859-1" http-equiv="Content-Type">
<title></title>
</head>
<body bgcolor="#ffffff" text="#000000">
I'm sorry, i have no CHAR parameter.<br>
I was just trying to use LABEL object, which have a dynamic angle.<br>
<br>
use<br>
LAYER<br>
...<br>
LABELITEM the_column<br>
LABELANGLEITEM arrow_angle<br>
LABEL<br>
TYPE TRUETYPE<br>
...<br>
FONT windings<br>
END<br>
END<br>
<br>
that's the idea but<br>
it's not really nice !!!<br>
<br>
<br>
<br>
fx gamoy a écrit :<br>
<blockquote cite="mid00d301c46834$6365f1b0$0102a8c0 at geomatika"
type="cite">
<title></title>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.2600.0" name="GENERATOR">
<div> </div>
<div><font face="Arial" size="2">hello</font></div>
<div><font face="Arial" size="2">Thanks for your post</font></div>
<div><font face="Arial" size="2">but i can't find any parameter CHAR
in the label object...</font></div>
<div><font face="Arial" size="2">and mapserver don't want it.</font></div>
<div><font face="Arial" size="2">Do you have special configuration? (
i am running a maperver 3.6.3 release on win2000)</font></div>
<div><font face="Arial" size="2">thanks</font></div>
<div><font face="Arial" size="2">fx</font></div>
<blockquote
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div
style="font-family: arial; font-style: normal; font-variant: normal; font-weight: normal; font-size: 10pt; line-height: normal; font-size-adjust: none; font-stretch: normal;">-----
Original Message ----- </div>
<div
style="background: rgb(228, 228, 228) none repeat scroll 0%; -moz-background-clip: initial; -moz-background-origin: initial; -moz-background-inline-policy: initial; font-family: arial; font-style: normal; font-variant: normal; font-weight: normal; font-size: 10pt; line-height: normal; font-size-adjust: none; font-stretch: normal;"><b>From:</b>
<a title="mathieuparent at infonie.fr"
href="mailto:mathieuparent at infonie.fr">Mathieu Parent</a> </div>
<div
style="font-family: arial; font-style: normal; font-variant: normal; font-weight: normal; font-size: 10pt; line-height: normal; font-size-adjust: none; font-stretch: normal;"><b>To:</b>
<a title="mapserver-users at lists.gis.umn.edu"
href="mailto:mapserver-users at lists.gis.umn.edu">mapserver-users at lists.gis.umn.edu</a>
</div>
<div
style="font-family: arial; font-style: normal; font-variant: normal; font-weight: normal; font-size: 10pt; line-height: normal; font-size-adjust: none; font-stretch: normal;"><b>Sent:</b>
Saturday, July 10, 2004 1:28 PM</div>
<div
style="font-family: arial; font-style: normal; font-variant: normal; font-weight: normal; font-size: 10pt; line-height: normal; font-size-adjust: none; font-stretch: normal;"><b>Subject:</b>
Re: [Mapserver-users] symbol question</div>
<div><br>
</div>
<blockquote cite="mid017601c465cf$587fc260$0102a8c0 at geomatika"
type="cite">
<style></style>
<div><font face="Arial" size="2">Hello world,</font></div>
<div><font face="Arial" size="2">i'd like to obtain lines with
oriented triangle in order to show the direction of a track.</font></div>
<div><font face="Arial" size="2">I have made several test but
nothing very interesting..</font></div>
<div><font face="Arial" size="2">thanks in advance..</font></div>
</blockquote>
object.<br>
Use a font with an arrow as char (Windings for example).<br>
<br>
LAYER<br>
...<br>
LABEL<br>
TYPE TRUETYPE<br>
...<br>
FONT windings<br>
CHAR é<br>
END<br>
END<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------090006090605090308080000--
--__--__--
Message: 5
Date: Mon, 12 Jul 2004 13:02:40 -0600
From: "Williams John" <JRWilliams at spaceimaging.com>
Subject: [Mapserver-users] getInteger(): Symbol definition error.
------_=_NextPart_001_01C46842.CE113B29
Content-Type: text/plain; charset="iso-8859-1"
I am receiving this error
getInteger(): Symbol definition error. Parsing error near (END):(line 170)
upon implementing this block of code. All vector layers are working fine. H=
owever this raster layer does not.=20
LAYER
MINSCALE 1
MAXSCALE 150000=20
NAME world_best
TYPE RASTER
TILEINDEX "C:\__MAPSERVER_SHAPEFILES\world_best_sort"
TILEITEM "location"
STATUS OFF
#FILTERITEM "location"
#FILTER "lk"
OFFSITE 0
END
I have this support:
mapserv -v
MapServer version 4.0.2 OUTPUT=3DGIF OUTPUT=3DPNG OUTPUT=3DJPEG OUTPUT=3DWB=
MP OUTPUT=3DPDF OUTPUT=3DSWF SUPPORTS=3DPROJ SUPPORTS=3DFREETYPE SUPPORTS=
=3DWMS_SERVER SUPPORTS=3DWMS_CLIENT SUPPORTS=3DWFS_SERVER SUPPORTS WFS_CLIE=
NT INPUT=3DEPPL7 INPUT=3DPOSTGIS INPUT=3DOGR INPUT=3DGDAL INPUT=3DSHAPEFILE
Any ideas on why I'm encountering this error?
John
This message is intended only for the use of the Addressee and may
contain information that is PRIVILEGED and CONFIDENTIAL.
If you are not the intended recipient, you are hereby notified that any
dissemination of this communication is strictly prohibited. If you have
received this communication in error, please erase all copies of the
message and its attachments and notify Space Imaging immediately.
Content-Type: text/html; charset="iso-8859-1"
<HTML><HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; charset=3Diso-8859-=
1">
<META content=3D"MSHTML 6.00.2800.1106" name=3DGENERATOR></HEAD>
<BODY>
<DIV><SPAN class=3D893485418-12072004><FONT face=3DArial size=3D2>I am rece=
iving this=20
error<BR></FONT>
<P><FONT face=3DArial><FONT size=3D2>getInteger(): Symbol definition error.=
Parsing=20
error near (END):(line 170)</FONT></FONT></P>
<P><SPAN class=3D893485418-12072004><FONT face=3DArial size=3D2>upon implem=
enting this=20
block of code. All vector layers are working fine. However this raster laye=
r=20
does not. </FONT></SPAN></P>
<P></SPAN><FONT face=3DArial size=3D2>LAYER<BR>MINSCALE 1<BR>MAXSCALE 15000=
0=20
<BR>NAME world_best<BR>TYPE RASTER<BR>TILEINDEX=20
"C:\__MAPSERVER_SHAPEFILES\world_best_sort"<BR>TILEITEM "location"<BR>STATU=
S=20
OFF<BR>#FILTERITEM "location"<BR>#FILTER "lk"<BR>OFFSITE=20
0<BR>END</FONT></P></DIV>
<DIV>
<P><SPAN class=3D893485418-12072004><FONT face=3DArial size=3D2>I have this=
support:</FONT></SPAN></P>
<P><SPAN class=3D893485418-12072004><FONT face=3DArial size=3D2>mapserv=20
-v<BR>MapServer version 4.0.2 OUTPUT=3DGIF OUTPUT=3DPNG OUTPUT=3DJPEG OUTPU=
T=3DWBMP=20
OUTPUT=3DPDF OUTPUT=3DSWF SUPPORTS=3DPROJ SUPPORTS=3DFREETYPE SUPPORTS=3DWM=
S_SERVER=20
SUPPORTS=3DWMS_CLIENT SUPPORTS=3DWFS_SERVER SUPPORTS WFS_CLIENT INPUT=3DEPP=
L7=20
INPUT=3DPOSTGIS INPUT=3DOGR INPUT=3DGDAL INPUT=3DSHAPEFILE</FONT></SPAN></P>
<P><SPAN class=3D893485418-12072004><FONT face=3DArial size=3D2>Any ideas o=
n why I'm=20
encountering this error?</FONT></SPAN></P>
<P><SPAN class=3D893485418-12072004><FONT face=3DArial=20
size=3D2>John</FONT></SPAN></P></DIV><FONT SIZE=3D3><BR>
<BR>
*****<BR>
This message is intended only for the use of the Addressee and may<BR>
contain information that is PRIVILEGED and CONFIDENTIAL.<BR>
<BR>
If you are not the intended recipient, you are hereby notified that any<BR>
dissemination of this communication is strictly prohibited. If you have<BR>
received this communication in error, please erase all copies of the<BR>
message and its attachments and notify Space Imaging immediately.<BR>
*****<BR>
</FONT>
</BODY></HTML>
------_=_NextPart_001_01C46842.CE113B29--
--__--__--
Message: 6
Date: Mon, 12 Jul 2004 16:46:07 -0400
Subject: [Mapserver-users] ms42pg.zip (Windows binary download)
This is a multipart message in MIME format.
--=_alternative 007215F285256ECF_=
Content-Type: text/plain; charset="US-ASCII"
Hello,
I'm trying to download
http://hypnos.cbs.umn.edu/projects/downloads/ms42pg.zip but it appears
that hypnos is down. Does anyone know of an alternative download source
or when hypnos might be up again?
Thanks,
W. Scott Meeks
Cambridge Systematics, Inc.
100 CambridgePark Drive, Suite 400
Cambridge, MA 02140
617 234-0582
smeeks at camsys.com
www.camsys.com
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Hello,</font>
<br>
<br><font size=2 face="sans-serif">I'm trying to download http://hypnos.cbs.umn.edu/projects/downloads/ms42pg.zip
but it appears that hypnos is down. Does anyone know of an alternative
download source or when hypnos might be up again?</font>
<br>
<br><font size=2 face="sans-serif">Thanks,</font>
<br>
<br><font size=2 face="sans-serif">W. Scott Meeks<br>
Cambridge Systematics, Inc.<br>
100 CambridgePark Drive, Suite 400<br>
Cambridge, MA 02140<br>
617 234-0582<br>
smeeks at camsys.com<br>
www.camsys.com</font>
--=_alternative 007215F285256ECF_=--
--__--__--
Message: 7
Date: Mon, 12 Jul 2004 16:04:43 -0500
Subject: [Mapserver-users] tileindex problems
HI all,
I'm trying to get a tile index working. I have 3 tif with a tfw file. I used the gdaltindex to create the tile index. I can open it up in ArcGIS and get the extents and everything. I can view the rasters alone, but not with the tile index. The web server crashes and I get a cgi error from IE. The log file is blank. I'm also getting an error whan I try to display the raster through a wms client. I've narrowed it down to maybe a projection issue, but I cannot figure out how to fix it. I've searched the forums and all the documentation. I'm running ms 4.0.2 w/ gdal.
Thanks for any assistance,
Dion Duran
GIS Developer - UEI
MAP
NAME USTestmap
IMAGETYPE jpeg
EXTENT 575024.00 3484335.99 604176.00 3475599.99
SIZE 400 300
SHAPEPATH "data"
IMAGECOLOR 255 255 255
UNITS METERS
WEB
LOG "demo.log"
END
PROJECTION
"init=epsg:26914"
END
# Start of LAYER DEFINITIONS ---------------------------------------------
LAYER # tileindex
NAME "tx_index"
STATUS default
TILEINDEX "tx_index.shp"
TILEITEM "Location"
TYPE RASTER
END # tileindex layer ends here
END # end of map file/object
--__--__--
Message: 8
Subject: Re: [Mapserver-users] ms42pg.zip (Windows binary download)
From: "Pericles S. Nacionales" <nacional at cbs.umn.edu>
Reply-To: nacional at cbs.umn.edu
To: Scott Meeks <SMeeks at camsys.com>
Cc: mapserver-users at lists.gis.umn.edu
Organization: University of Minnesota
Date: Mon, 12 Jul 2004 16:26:57 -0500
See
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0407/msg00258.html
Hypnos is having hardware problems (power supply fans). It should be up
and running again tomorrow.
-Perry
On Mon, 2004-07-12 at 15:46, Scott Meeks wrote:
> Hello,
> Thanks,
> W. Scott Meeks
> Cambridge, MA 02140
> 617 234-0582
www.camsys.com
"He's no geek.His tan's too good." -Benjamin Choate
--__--__--
Message: 9
From: Davis Michael A DPW GIS TECH <michael.davis at richardson.army.mil>
Date: Mon, 12 Jul 2004 21:59:03 -0000
Subject: [Mapserver-users] More info on strange mapserv - mode=map behavior
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C4685B.71C7AB00
Thanks to some great assistance from Adam Ryan, of Linn County, I have been
able to narrow down my issues with the mapserv cgi on Win2k+IIS. We are
using the latest 4.2 build.
Our problem has been occurring when we send a request in "map" mode. The
request will fail with a "CGI Error...CGI application misbehaved" error if
there is more than one layer set to default or requested through the URL.
The request will also fail if there is one layer with multiple classes set
to default.
All of the test .map files will work just fine in "browse" mode.
I am wondering if anyone in list land has had a similar experience, or if
anyone who uses Win2k+IIS can recommend web server settings to check or a
way to get more debug information out of the mapserv cgi. The standard log
file reports the bad requests as normal execution.
Thanks very much for all your continued help.
Mike Davis
GIS Analyst
Fort Richardson, AK
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<META NAME=3D"Generator" CONTENT=3D"MS Exchange Server version =
5.5.2653.12">
<TITLE>More info on strange mapserv - mode=3Dmap behavior</TITLE>
</HEAD>
<BODY>
<P><FONT SIZE=3D2>Thanks to some great assistance from Adam Ryan, of =
Linn County, I have been able to narrow down my issues with the mapserv =
cgi on Win2k+IIS. We are using the latest 4.2 build. =
</FONT></P>
<P><FONT SIZE=3D2>Our problem has been occurring when we send a request =
in "map" mode. The request will fail with a "CGI =
Error...CGI application misbehaved" error if there is more than =
one layer set to default or requested through the URL. The =
request will also fail if there is one layer with multiple classes set =
to default.</FONT></P>
<P><FONT SIZE=3D2>All of the test .map files will work just fine in =
"browse" mode.</FONT>
</P>
<P><FONT SIZE=3D2>I am wondering if anyone in list land has had a =
similar experience, or if anyone who uses Win2k+IIS can recommend web =
server settings to check or a way to get more debug information out of =
the mapserv cgi. The standard log file reports the bad requests =
as normal execution. </FONT></P>
<P><FONT SIZE=3D2>Thanks very much for all your continued help. </FONT>
</P>
<P><FONT SIZE=3D2>Mike Davis</FONT>
<BR><FONT SIZE=3D2>GIS Analyst</FONT>
<BR><FONT SIZE=3D2>Fort Richardson, AK</FONT>
</P>
</BODY>
</HTML>
------_=_NextPart_001_01C4685B.71C7AB00--
--__--__--
Message: 10
Date: Mon, 12 Jul 2004 19:35:07 -0400
To: Dion Duran <dion.duran at uei-houston.com>
Subject: Re: [Mapserver-users] tileindex problems
Dion Duran wrote:
> HI all,
> Dion Duran
> GIS Developer - UEI
Dion,
1) Try complete paths for the tile index and for the raster files as
recorded in the tile index.
2) Try reproducing the problem with shp2img (often better debug info).
3) Try turning on maximum debugging. There is a topic about it in the wiki.
Amoung other things, turn on Mapserver debugging with DEBUG ON keyword on
the layer, and GDAL debugging with "set CPL_DEBUG = ON" at the commandline
before running shp2img.
4) Developers will be more interested in your problem if you are running with
a more current version of the software (ie. mapserver 4.2.x).
Good luck,
and watch the world go round - Rush | Geospatial Programmer for Rent
--__--__--
Message: 11
From: "Richard Orchard" <richard.orchard at ermapper.com.au>
Date: Tue, 13 Jul 2004 10:43:26 +0800
Subject: [Mapserver-users] Unable to download windows binaries
hi,
Is it just me, or is the site hosting the windows binaries down?
Richard
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender immediately and delete the original. Any other use of the email by you is prohibited..
www.ermapper.com
www.earthetc.com
--__--__--
Message: 12
Date: Tue, 13 Jul 2004 10:57:38 +0800
Subject: [Mapserver-users] Re: Your website
------=_NextPart_000_0007_00000547.00005672
charset="Windows-1252"
Here is the file.
Content-Type: application/octet-stream;
name="your_website.pif"
Content-Transfer-Encoding: base64
Content-Disposition: attachment;
filename="your_website.pif"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------=_NextPart_000_0007_00000547.00005672--
--__--__--
Message: 13
Date: Mon, 12 Jul 2004 23:02:34 -0400
From: Daniel Morissette <dmorissette at dmsolutions.ca>
To: DEAN Jeremy E <Jeremy.E.DEAN at co.benton.or.us>
CC: "Mapserver-Users (E-mail)" <mapserver-users at lists.gis.umn.edu>
Subject: Re: [Mapserver-users] PHP Mapscript processtemplate( ) problems
DEAN Jeremy E wrote:
> Hello again,
> I am having continued problems with the PHP MapScript method of
> PROCESSTEMPLATE( ). I have successfully used a legend template and the
> PROCESSLEGENDTEMPLATE( ) method to generate content, but am now also having
> trouble replicating that in the code below.
It seems that $map->processTemplate() has been broken since V4.0 in all
flavours of MapScript, for the full sotry, see:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=410
I have fixed the bug a few minutes ago in v4.3 (CVS) and in the 4.2.x
branch (to be released as 4.2.1 soon).
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
--__--__--
Message: 14
Date: Mon, 12 Jul 2004 23:29:41 -0400
To: stepan.kafka at centrum.cz
CC: mapserver users <mapserver-users at lists.gis.umn.edu>
Subject: Re: [Mapserver-users] changelog
stepan.kafka at centrum.cz wrote:
> The mapserver changelog file
> http://dl1.maptools.org/dl/mapserver_Changelog.txt
> has not been updated since 2004-03-23. Please, is actual version
> somewhere available?
There was a glitch introduced in the cron job that updates the file. It
should be fixed now.
Daniel
--__--__--
Message: 15
Date: Mon, 12 Jul 2004 23:38:12 -0400
To: Richard Orchard <richard.orchard at ermapper.com.au>
CC: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Unable to download windows binaries
Richard Orchard wrote:
> hi,
It has been reported earlier today on this list that the server hosting
those files had a hardware problem and will be back up tomorrow.
In the meantime you can also get windows binaries from maptools.org:
http://maptools.org/php_mapscript/index.phtml?page=downloads.html
Daniel
--__--__--
Message: 16
Date: Mon, 12 Jul 2004 23:02:01 -0500
To: <mapserver-users at lists.gis.umn.edu>, <fx.gamoy at mapxplore.com>
I'll see if I can whip up a demo. I've used the technique to place
railroad ties on a line so they would always be perpendicular so I'm
thinkin this is what you want...
Steve
>>> "fx gamoy" <fx.gamoy at mapxplore.com> 07/10/04 3:50 AM >>>
hello
thanks for your post
but what is the way to use truetype line symbol in the mapfile?
fx
To: <fx.gamoy at mapxplore.com>
Sent: Friday, July 09, 2004 7:27 PM
> You need to look at TrueType line symbols, I believe they
automatically
> are rotated
> to match the orientation of a line.
> Steve
> >>> "fx gamoy" <fx.gamoy at mapxplore.com> 7/9/2004 11:11:08 AM >>>
> Hello world,
> thanks in advance..
> fx
Mapserver-users at lists.gis.umn.edu
--__--__--
Message: 17
Date: Tue, 13 Jul 2004 00:15:53 -0400
To: Williams John <JRWilliams at spaceimaging.com>
Subject: Re: [Mapserver-users] getInteger(): Symbol definition error.
> fine. However this raster layer does not.
> LAYER
> MINSCALE 1
> MAXSCALE 150000
> NAME world_best
> TYPE RASTER
> TILEITEM "location"
> STATUS OFF
> #FILTER "lk"
> OFFSITE 0
> END
Starting with V4.0, OFFSITE expects a set of 3 values (r g b) instead of
a color index.
--__--__--
Message: 18
Date: Mon, 12 Jul 2004 23:24:59 -0500
To: <mapserver-users at lists.gis.umn.edu>, <JRWilliams at spaceimaging.com>
I believe the problem is the OFFSITE line. That parameter takes an RGB
triplet as opposed to an index value.
Steve
>>> "Williams John" <JRWilliams at spaceimaging.com> 07/12/04 2:02 PM >>>
170)
LAYER
MINSCALE 1
MAXSCALE 150000
NAME world_best
TYPE RASTER
TILEITEM "location"
STATUS OFF
#FILTER "lk"
OFFSITE 0
END
mapserv -v
MapServer version 4.0.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS
WFS_CLIENT INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
John
--__--__--
Message: 19
Date: Tue, 13 Jul 2004 00:39:56 -0400
To: "Pagurek, Debbie" <PAGUREKD at agr.gc.ca>
Subject: Re: [Mapserver-users] question about legendurl_href in the history.txt
file
Pagurek, Debbie wrote:
> Could someone explain what the following note means? It is in the history.txt document that is released with mapserver 4.2.
> I can't make sense of it or how to implement legendurl_href.
> "Replace wms_style_%s_legendurl, wms_logourl, wms_descriptionurl, wms_dataurl
> and wms_metadataurl metadata by four new metadata by metadata replaced. The
> new metadata are called legendurl_width, legendurl_height, legendurl_format,
> legendurl_href, logourl_width, etc...
> Old dependancy to the metadata with four value in it , space separated, are
> not kept."
Ouch! That's a bad one... I had to re-read it almost 10 times to make
sense of it...
First of all, you can't implement legendurl_href in WMS Capabilites yet,
the comment above applies only to WMS context, the support of LegendURL
in the WMS capabilities is still an open issue, see
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=438
IIRC, what the comment above tries to say is that the following metadata
were used before by the WMS context code, and that each of them used to
expect a different number of parameters delimited by spaces:
wms_logourl
wms_descriptionurl
wms_dataurl
wms_metadataurl
This was a mess since some of the above included 4 space-delimited
values (width, height, format, url) and some included only 2 (only
format and url since width/height don't make sense for DataUrl for
instance), so each of the above was replaced by a set of 4 metadata
entries instead.
e.g.
wms_style_%s_legendurl has been replaced with:
wms_style_%s_legendurl_width
wms_style_%s_legendurl_height
wms_style_%s_legendurl_format
wms_style_%s_legendurl_href
wms_logourl has been replaced with:
wms_logourl_width
wms_logourl_height
wms_logourl_format
wms_logourl_href
... and so on for each of the 5 old metadata values above that were
split into 4 values the same way.
I'll copy this explanation to the bug.
Daniel
--__--__--
Message: 20
Date: Tue, 13 Jul 2004 00:56:40 -0400
To: murilo.yoshida at agx.com.br
Subject: Re: [Mapserver-users] CreateLegendIcon and FAQ suggestion
Murilo Lacerda Yoshida wrote:
> The problem is this. I used the FAQ suggestion about how to set a line
> width. OK, it works fine.
> I have four layer of lines that were changed as the FAQ says.
> But now when I draw the legend for that four layers, they are all
> drawn in the same color, that is the color of the first layer drawn. The
> legend icon still is a line, but with more width (as
> I have set in my mapfile).
> Help me, please. I don't know why this is happening... and I can't see
> anything wrong in the mapfile...
You didn't mention the version you're using, but we'll assume it's 4.0
or older. There was a problem with color of legend icons in v4.0 that
was fixed in v4.2. You should try to upgrade to v4.2. See:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=608
--__--__--
Message: 21
Date: Tue, 13 Jul 2004 01:01:50 -0400
To: mapserver-users <mapserver-users at lists.gis.umn.edu>
Subject: [Mapserver-users] MapServer 4.2.1 released
MapServer 4.2.1 has been posted to the website a few minutes ago. This
release doesn't include any new functionality, just fixes of critical
bugs found since the release of 4.2.0. The complete list of fixes is
copied at the end of this message.
Windows binaries for this version should follow shortly at the usual
locations.
Daniel
Version 4.2.1 (2004-07-12)
- Disable drawERD() (ERDAS formats) when GDAL is available (bug 691)
- Fixed layer->drawQuery() for PHP and SWIG MapScript (bug 695)
- Python mapscript: fixed win32 and non-standard include dirs (bug 680).
- Mladen Turk's map copying macros in mapcopy.h clean up map cloning and
allow for copying of fontset and symbolset. Added cloning tests in
python/tests/testCloneMap.py and refactored testing suite (bugs 640 &
701).
- Postgis: wrapped in name space changes from HEAD (changed functions so
they
were declared static), and modified item querying so that it closed the
correct cursor.
- Fixed problem with tiled raster layers if there is no tile in the current
view (bug 729).
- Fixed problem with maxy in PHP MapScript's map->zoomscale() (bug 75)
- Fixed $map->processTemplate() which was always returning NULL.
Bug introduced in version 4.0 in all flavours of MapScript (bug 410)
--__--__--
Message: 22
Date: Tue, 13 Jul 2004 01:37:14 -0400
To: eduardo at consultoria.eti.br
Subject: Re: [Mapserver-users] using URL's in pixmap symbol
Steve Lime wrote:
> It shouldn't work, but it shouldn't blow up either. If you do get a segfault or something particularly nasty then please file a bug so that it gets addressed.
> There are not immediate plans to add this functionality, so only local images may be accessed. The place to add this is in mapsymbol.c in the function msAddImageSymbol(). One would need to leverage lubcurl to read the image and somehow turn it into a GD image internally. It's be really nice if GD supported this itself!
Hint: you'd want to call msHTTPGetFile() (maphttp.c) to fetch the image
before passing it to GD.
Note that doing this will slow down you map draws if you fetch the image
on every request, so you should pass the parameter
bCheckLocalCache=MS_TRUE to msHTTPGetFile(). If CheckLocalCache==MS_TRUE
then if the output file already exists then is is not downloaded again,
and status 242 is returned.
Daniel
--__--__--
Message: 23
Date: Tue, 13 Jul 2004 02:04:42 -0400
To: norbert.thieme at ilmenau.baw.de
CC: mapserver <mapserver-users at lists.gis.umn.edu>
Subject: Re: [Mapserver-users] Is there a problem with WMS getCapabilities
with VERSION=1.1.1?
Norbert Thieme wrote:
> Hi all,
> I read in the docs that WMS version 1.1.1 is supported in MS 4.2. When I
> change the requests which worked with 1.1.0 I get a problem with the
> output of the getCapabilities request.
> The XML looks fine but it is cut off at a indefinite point. I tested
> this also for the getMap request and there version 1.1.1 works fine. I
> tested different mapfiles with getCapabilities and I can't see a reason
> in the mapfiles.
> Could that be a problem with the web server - that it stops transmission
> before the XML is complete? Or even the mapserver itself?
> Did anyone try the getCapabilities request with version 1.1.1? Was the
> output OK?
There is no known issue with WMS 1.1.1 Capabilities, for instance the
following WMS uses MS 4.2 and works:
http://dev1.dmsolutions.ca/cgi-bin/mswms_gmap?version=1.1.1&request=GetCapabilities
It could be that something specific to your data crashes the MapServer
binary during the generation of the Capabilities, that would explain the
truncated output. However there is not much we can do to help unless you
can file a bug with a testcase to reproduce.
Daniel
--__--__--
Message: 24
Date: Tue, 13 Jul 2004 08:15:36 +0200
Subject: Re: [Mapserver-users] Road Labels
Hi Jerl,
don't know if anybody already answered your question directly, but what you are looking for is the
MINDISTANCE directive at label level, that takes a pixel values for the minimal distance between the
next duplicate label.
HTH, Michael
Jerl Simpson schrieb:
> Hello,
> I was thinking I had seen a post about this in the past, but I could not
> find it in the archives. Here is the problem I am having.
> I have Local roads displayed with annotations. The annotations show up
> just fine, but every line segment is labeled. This gives an affect
> where the same street may be label 15 times on the within the same map
> image.
> I wouldn't mind a label showing up 1 or 2 times...and certainly more
> than once of a road is not joined all the way through.
> Is there a way to get around this?
> Thank you,
> Jerl
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de/www.zopecms.de
--__--__--
Message: 25
From: VILLOIN Franck DSIC BMS <Franck.VILLOIN at interieur.gouv.fr>
To: dscandiuzzi at brturbo.com
Date: Tue, 13 Jul 2004 09:38:10 +0200
Subject: [Mapserver-users] RE Mapserver Windows Installation
------_=_NextPart_001_01C468AC.58F0DBA0
Daniel,
In your form change Mapserver40 by Mapserver40.exe with Windows environment
the scripts executable is post fixed by exe.
With apache when I want run with unix syntax, I insert this line
ScriptAliasMatch /cgi-bin/mapserv*
D:/Apache/Serveur/Apache2/cgi-bin/mapserv.exe
Franck
Date: Mon, 12 Jul 2004 11:38:08 -0300 (BRT)
From: Daniel Scandiuzzi <dscandiuzzi at brturbo.com>
Subject: [Mapserver-users] Mapserver Windows Installation
--25536377.1089643088538.JavaMail.nobody.webmail4.brturbo.com
I am having some problems insalling MapServer on windows xp. I am a new
user. I already put mapserv.exe in the webserver directory in my case
(C:\Inetpub\wwwroot).
I got the demo installed and it is not working. When I press the
"Submit" button, it gives me a error ("page not found"). The address shown
on is "c:\cgi-bin\mapserver40". I already tryed renaming mapserv to
mapserver40. I am very newbee in mapserver.
Is there any tutorial that explains how to install mapserver on windows
XP?
thanks for the attencion,
Daniel
--25536377.1089643088538.JavaMail.nobody.webmail4.brturbo.com--
<HTML>
<HEAD>
5.5.2653.12">
<TITLE>RE Mapserver Windows Installation</TITLE>
</HEAD>
<BODY>
<P><FONT SIZE=3D2 FACE=3D"Arial">Daniel,</FONT>
</P>
<P><FONT SIZE=3D2 FACE=3D"Arial">In your form change Mapserver40 by =
Mapserver40.exe with Windows environment the scripts executable is post =
fixed by exe.</FONT></P>
<P><FONT SIZE=3D2 FACE=3D"Arial">With apache when I want run with unix =
syntax, I insert this line</FONT>
<BR><B><FONT FACE=3D"Times New Roman">ScriptAliasMatch =
/cgi-bin/mapserv* =
D:/Apache/Serveur/Apache2/cgi-bin/mapserv.exe</FONT></B>
</P>
<P><FONT FACE=3D"Times New Roman">Franck</FONT>
</P>
<BR>
<BR>
<P><FONT SIZE=3D2 FACE=3D"Arial">Date: Mon, 12 Jul 2004 11:38:08 -0300 =
(BRT)</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial">From: Daniel Scandiuzzi =
<dscandiuzzi at brturbo.com></FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial">To: =
mapserver-users at lists.gis.umn.edu</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial">Subject: [Mapserver-users] Mapserver =
Windows Installation</FONT>
</P>
<P><FONT SIZE=3D2 =
FACE=3D"Arial">--25536377.1089643088538.JavaMail.nobody.webmail4.brturbo=
.com</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial">Content-Type: text/plain; =
charset=3DISO-8859-1</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial">Content-Transfer-Encoding: =
7bit</FONT>
</P>
<P><FONT SIZE=3D2 FACE=3D"Arial"> I am having some =
problems insalling MapServer on windows xp. I am a new user. I already =
put mapserv.exe in the webserver directory in my case =
(C:\Inetpub\wwwroot). </FONT></P>
<P><FONT SIZE=3D2 FACE=3D"Arial"> I got the demo =
installed and it is not working. When I press the "Submit" =
button, it gives me a error ("page not found"). The address =
shown on is "c:\cgi-bin\mapserver40". I already tryed =
renaming mapserv to mapserver40. I am very newbee in =
mapserver.</FONT></P>
<P><FONT SIZE=3D2 FACE=3D"Arial"> Is there any =
tutorial that explains how to install mapserver on windows XP?</FONT>
<BR><FONT SIZE=3D2 FACE=3D"Arial"> thanks for the =
attencion,</FONT>
</P>
<P><FONT SIZE=3D2 FACE=3D"Arial"> Daniel </FONT>
<BR><FONT SIZE=3D2 =
.com--</FONT>
</P>
</BODY>
</HTML>
------_=_NextPart_001_01C468AC.58F0DBA0--
--__--__--
Message: 26
Subject: RE: [Mapserver-users] Problem in installing Proj4 and GDAL for Linux RH Advanced Server
Date: Tue, 13 Jul 2004 11:56:46 +0400
To: "Frank Warmerdam" <warmerdam at pobox.com>, <norbert.thieme at ilmenau.baw.de>
Cc: <mapserver-users at lists.gis.umn.edu>
Dear Frank and norbert
Thank you for your reply. The following is some more information about
my configuration:
..>I put all of my mapserver configuration files under
</usr/src/projects> which are as follows:
curl-7.12.0 gd-2.0.27 libgeotiff-1.2.2 OpenEV_FW
postgis-0.8.2.tar.gz tiff-v3.6.1
freetype-1.3.1 jpeg-6b mapserver-4.2.0 PaxHeaders.13119
proj-4.4.8 tutorial.zip
..>After installing all of the above individually using ./configure and
make I typed the following command in mapserver:
./configure --with-freetype --with-zlib --with-png --with-jpeg
--with-gd=/usr/local --with-proj --with-gdal --with-tiff
..>I got the following:
checking for gcc... gcc
checking for C compiler default output... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for ranlib... ranlib
checking for flex... flex
checking for yywrap in -lfl... yes
checking lex output file root... lex.yy
checking whether yytext is a pointer... yes
checking for bison... bison -y
checking if compiler supports -R... no
checking if compiler supports -Wl,-rpath,... yes
checking for exp in -lm... yes
checking for __gxx_personality_v0 in -lstdc++... no
checking how to run the C preprocessor... gcc -E
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for strcasecmp... yes
checking for strncasecmp... yes
checking for strdup... yes
configure: checking where FreeType 2.x is installed......
checking for freetype-config... /usr/bin/freetype-config
using libfreetype from -L/usr/lib -lfreetype
checking for FT_Init_FreeType in -lfreetype... yes
using libfreetype -lfreetype from system libs.
configure: checking where Zlib is installed......
checking for zlibVersion in -lz... yes
using libz from system libs.
configure: checking where PNG is installed......
checking for png_init_io in -lpng... yes
using libpng from system libs.
configure: checking whether we should include JPEG support......
checking for jpeg_read_header in -ljpeg... yes
using libjpeg from system libs.
configure: checking where libXpm is installed......
checking for XpmFreeXpmImage in -lXpm... no
XPM (libXpm) library cannot be found, possibly needed for GD
configure: checking where libiconv is installed......
checking for libiconv_open in -liconv... no
libiconv library cannot be found, possibly needed for GD
configure: checking for GD 2.0.12 or higher......
checking for gdImageSetAntiAliased in -lgd... yes
using libgd 2.0.12 (or higher) from -L/usr/local/lib -lgd -ljpeg
-lfreetype -lpng -lz
checking for gdImageGif in -lc... no
checking for gdImagePng in -lc... yes
checking for gdImageJpeg in -lc... yes
checking for gdImageWBMP in -lc... yes
checking for gdImageStringFT in -lc... yes
checking for gdImageGifPtr in -lc... no
using GD ( -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT)
from /usr/local.
configure: checking whether we should include PDF support......
checking for PDF_setlinewidth in -lpdf... no
checking for PDF_setrgbcolor in -lpdf... no
checking for PDF_moveto in -lpdf... no
checking for PDF_curveto in -lpdf... no
checking for PDF_show_xy in -lpdf... no
libpdf not found... PDF support not included.
configure: checking whether we should include EPPL7 support......
including EPPL7 support.
configure: checking whether we should include PROJ.4 support......
checking for pj_init in -lproj... yes
checking for pj_transform in -lproj... yes
checking for pj_latlong_from_proj in -lproj... yes
using PROJ.4 from system libs.
configure: checking whether we should include thread safe support......
thread safe support disabled.
configure: checking whether we should include ESRI SDE support......
ESRI SDE support not requested.
configure: checking whether we should compile in MPATROL support......
MPATROL support not requested.
configure: checking whether we should include OGR support......
OGR support not requested.
checking if GDAL support requested... yes
checking for gdal-config...
/usr/src/projects/OpenEV_FW/bin_safe/gdal-config
checking checking ms JPEG output... no we, have GDAL available.
configure: checking whether we should include TIFF support......
checking for TIFFOpen in -ltiff... yes
using libtiff from system libs.
checking if PostGIS support requested... no
checking if MyGIS support requested... no
checking if OracleSpatial support requested... no
checking if MING/Flash support requested... no
configure: checking whether we should include WMS Server support......
OGC WMS compatibility enabled (-DUSE_WMS_SVR).
configure: checking whether we should include WFS Server support......
OGC WFS Server support not requested.
configure: checking whether we should include WMS Client Connections
support......
configure: checking whether we should include WFS Client Connections
support......
OGC WFS Client Connections not enabled (PROJ.4, libcurl and OGR
required).
configure: checking for curl-config...
configure: checking HTTPD server (Apache) version...
checking for httpd... /usr/sbin/httpd
/usr/sbin/httpd version is Apache/1.3.23 (1003023).
Compiling with -DIGNORE_MISSING_DATA.
configure: checking whether we should enable debug features......
configure: checking for PHP/MapScript module options......
PHP/MapScript module not configured.
configure: creating ./config.status
config.status: creating Makefile
..>Then I typed make and after moved the mapserv file to the cgi-bin
folder.
..>Mapserv -v gives the following:
MapServer version 4.3 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=EPPL7
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
..>ldd mapserv gives the following:
libgd.so.2 => /usr/local/lib/libgd.so.2 (0x4002f000)
libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x40069000)
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x40088000)
libtiff.so.3 => /usr/local/lib/libtiff.so.3 (0x400bc000)
libm.so.6 => /lib/i686/libm.so.6 (0x400fe000)
libc.so.6 => /lib/i686/libc.so.6 (0x40121000)
libXpm.so.4 => /usr/X11R6/lib/libXpm.so.4 (0x4025e000)
libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0x4026d000)
libpng.so.2 => /usr/lib/libpng.so.2 (0x40363000)
libz.so.1 => /usr/lib/libz.so.1 (0x40384000)
/lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
..>My root path is as follows:
/usr/kerberos/sbin:/usr/kerberos/bin:/opt/IBMJava2-131/bin:/opt/IBMJava2
-131/jre/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bi
n:/usr/X11R6/bin:/root/bin:/usr/src/projects/OpenEV_FW/bin_safe:/usr/src
/projects/proj-4.4.8/
..>My /etc/ld.so.conf contains the following:
/usr/kerberos/lib
/usr/X11R6/lib
/usr/lib/qt-2.3.1/lib
/usr/lib/sane
/usr/lib/mysql
/usr/local/lib
/usr/src/projects/proj-4.4.8
..>The map file that I'm trying to read is the following:
example1-1.map [----] 0 L:[ 1+ 0 1/ 38] *(0 / 867b)= 32 20H
MAP
IMAGETYPE PNG
EXTENT 201621.496941 -294488.285333 1425518.020722
498254.511514
SIZE 400 300
SHAPEPATH "data"
PROJECTION
"proj=laea"
"ellps=clrk66"
"lat_0=45"
"lon_0=-100"
# Alternatively, you can specify an EPSG code.
# "init=epsg:2163"
END
LAYER # States polygon layer begins here
NAME states
DATA states_ugl
STATUS DEFAULT
TYPE POLYGON
PROJECTION
"init=epsg:4326"
END
CLASS
COLOR 232 232 232
OUTLINECOLOR 32 32 32
END
END # States polygon layer ends here
# End of LAYER DEFINITIONS -------------------------------
..>This tutorial I got from the mapserver web site which is
<tutorial.zip>.
..>The command I type from the internet explorer is as follows:
http://192.168.3.48/cgi-bin/mapserv?map=/var/www/html/tutorial/example1-
1.map&mode=map
..>The error that I get is as follows:
1.map&mode=map
Kindest Regards,
Taha
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Monday, July 12, 2004 5:27 PM
To: Taha Al Sayed
Subject: Re: [Mapserver-users] Problem in installing Proj4 and GDAL for
Taha Al Sayed wrote:
> Dear All
> I'm trying to install the demo from map server on a Linux box with Red
hat Advanced server. I managed to get it to work only with shp files
(after some modifications). So far I'm not able to get the projection to
work neither the GDAL. I have installed the packages for GDAL and Proj4
and then included then in the configuration of the mapserver using
<--with-gdal --with-proj>. When I test the proj4 and gdal packages
seperately they seem to work, but from map the server they don't,
although the configuration in mapserver doesn't give any error messages.
Taha,
This report doesn't give us much to go on to help you work out the
problem.
What does "mapserv -v" report? What does "ldd mapserv" report? What
makes you think the projections aren't working?
Best regards,
--__--__--
Message: 27
Date: Tue, 13 Jul 2004 04:07:50 -0400
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] input using mapserver
I'd like to setup an easy-to-use site where community members can make
comments about an ortho image that we'll be serving. Sort of a spatial
community/neighborhood outreach thing. The way I envision this is
essentially storing/accepting the comments as input into a point layer.
Has anyone done something like this? Any pointers/tips would be
welcome/greatly appreciated. This has to be done purely using open
source stuff since I'm just helping out a graduate student - I believe
it can be, would just greatly appreciate any pointers from people who
have done stuff like this before
thanks a lot.
- bri
Recursivity. Call back if it happens again.
--__--__--
Message: 28
Date: Tue, 13 Jul 2004 10:33:55 +0200
From: =?iso-8859-1?b?U+liYXN0aWVu?= DUBOIS <sebastien.dubois at esm2.imt-mrs.fr>
To: bowens at refractions.net
Cc: postgis-users at postgis.refractions.net, mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] bug report missing support
cf http://postgis.refractions.net/pipermail/postgis-users/2004-July/005174.html
and the back of this mail.
it seems to have a bug in the postgis connector (when querying multi point , "my
cursor" not closed at each time)
i don't have the background to build the patch but perhaps you would...
Please let me know what i have to do to solve this bug...
thanks in advance
Selon strk <strk at keybit.net>:
> On Tue, Jul 13, 2004 at 10:03:08AM +0200, Sébastien DUBOIS wrote:
> > thanks for your explication
> > do you think i had to back move to an older version of postgresql?
> > which one?
> > thanks in advance.
> No.. I think you should patch the postgis connector
> and send a patch to the mapserver guys.
> --strk;
> > Strk a écrit:
> > It's a missing support for new postgresql in the postgis connector.
> > Old postgresql automatically closed portals on end of transaction,
> > while new one do not. Dunno why that connector is not fixed yet.
> > --strk;
This mail sent through IMP: http://horde.org/imp/
--__--__--
Message: 29
Reply-To: merlos at tsc.uvigo.es
Date: Tue, 13 Jul 2004 14:48:00 +0200
Subject: [Mapserver-users] Spanish Wiki - New Documentation
Hi
This post is just to notice Spanish speakers I have been making changes on
the wiki.
I've organized a little the Spanish Discussion page:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?SpanishDiscussions
And added there two new documents in Spanish:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?SpanishLinuxInstall
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?SpanishJavaMapScript
Regards. Juan.
--__--__--
Message: 30
Date: Tue, 13 Jul 2004 07:26:08 -0500
From: "Render, Kathy S." <ksrender at southernco.com>
Subject: [Mapserver-users] Unable to access the windows binaries for mapserver
I am unable to access the Windows binaries from the website. I see a
server not found message.
--__--__--
Message: 31
Date: Tue, 13 Jul 2004 08:38:19 -0400
To: Taha Al Sayed <t_alsayed at thuraya.com>
Cc: UMN MapServer <mapserver-users at lists.gis.umn.edu>
Subject: Re: [Mapserver-users] Problem in installing Proj4 and GDAL for Linux
RH Advanced Server
> MAP
> PROJECTION
> "proj=laea"
> "ellps=clrk66"
> "lat_0=45"
> "lon_0=-100"
> # "init=epsg:2163"
> END
> NAME states
> DATA states_ugl
> STATUS DEFAULT
> TYPE POLYGON
> PROJECTION
> "init=epsg:4326"
> END
Taha,
I see a likely problem. You have your map projection set to be
LAEA with an ellipsoid of Clark 1866. Your polygon layer you have
marked as geographic wihth a datum of WGS84.
Until quite recently PROJ.4 could not convert between ellipsoids
without an indication of what datum shift should be used. I thought
this was changed in PROJ 4.4.8 (which I see you are using) but perhaps
I am wrong. Try changing your map projection to the following, and see
if it helps. I also include the no_defs parameter in projection blocks
to avoid surprising default additions.
PROJECTION
"proj=laea"
"datum=WGS84"
"lat_0=45"
"lon_0=-100"
"no_defs"
END
> <tutorial.zip>.
> 1.map&mode=map
> 1.map&mode=map
I wasn't able to access this error. Is it behind a firewall?
Best regards,
--__--__--
Message: 32
Subject: RE: [Mapserver-users] Change Projection (e.g. Geographic to Robinson)
Date: Tue, 13 Jul 2004 08:55:30 -0400
This is a multi-part message in MIME format.
------_=_NextPart_001_01C468D8.AD9A0424
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
This works for me:
=20
$newproj=3Dms_newprojectionObj("proj=3Drobin,lon_0=3D0,x_0=3D0,y_0=3D0");=
=20
$latlon=3Dms_newprojectionObj("proj=3Dlonglat,ellps=3DGRS80,datum=3DNAD83=
,no_def
s");
=20
$oldext=3D ms_newRectObj();
$oldext->setextent($bounds[0],$bounds[1],$bounds[2],$bounds[3]);
//this is the extent of my map in geographic
$oldext->project($latlon,$newproj); //reproject to Robinson
=20
=20
$map->setextent($oldext->minx,$oldext->miny,$oldext->maxx,$oldext->maxy)
; //set the new map extent
=20
=20
Hope that helps,
D. Pagurek
=20
=20
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Stefan
Schwarzer
Sent: Monday, July 12, 2004 10:56 AM
Subject: [Mapserver-users] Change Projection (e.g. Geographic to
Robinson)
=20
Hi there,
it seems that either the "change projection on-the-fly" feature isn't
widely used or nobody has problems with it. At least, the number of
threats using the ms_newprojectionObj command is relatively small. And
the WIKI is empty on the subject of "Projections".
Could somebody provide me with a working example? I tried to change the
projection of my data from "geographic" to "robinson" using the
ms_newprojectionObj object, but it didn't work, and honestly, I am a
bit confused by the different parameters...
Thanks for any help,
Stefan
_______________________________________
Stefan Schwarzer
GIS & Data Management
UNEP/DEWA/GRID-Geneva
Chemin des Anemones 11
CH - 1219 Chatelaine
Switzerland
Tel: (+41) 22.917.83.49
Fax: (+41) 22.917.80.29
Email: stefan.schwarzer at grid.unep.ch
Internet: http://geodata.grid.unep.ch/
_______________________________________=20
Content-Type: text/html;
charset="us-ascii"
<html>
<head>
<meta name=3DGenerator content=3D"Microsoft Word 10 (filtered)">
<style>
/* Font Definitions */
@font-face
{font-family:Courier;
panose-1:2 7 4 9 2 2 5 2 4 4;}
@font-face
{font-family:Tahoma;
panose-1:2 11 6 4 3 5 4 4 2 4;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0in;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
{color:blue;
p
{margin-right:0in;
margin-left:0in;
font-size:12.0pt;
span.EmailStyle18
{font-family:Arial;
color:navy;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;}
div.Section1
{page:Section1;}
</style>
</head>
<body lang=3DEN-CA link=3Dblue vlink=3Dblue>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 color=3Dnavy face=3DArial><span =
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>This works for =
me:</span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'> </span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'> =
$newproj=3Dms_newprojectionObj("proj=3Drobin,lon_0=3D0,x_0=3D0,y_0=3D=
0");</span></font></p>
style=3D'font-size:
$latlon=3Dms_newprojectionObj("proj=3Dlonglat,ellps=3DGRS80,datum=3D=
NAD83,no_defs");</span></font></p>
style=3D'font-size:
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'> $oldext=3D =
ms_newRectObj();</span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'> $oldext->setextent($b=
//this is the extent of my map in geographic</span></font></p>
style=3D'font-size:
//reproject to Robinson</span></font></p>
style=3D'font-size:
style=3D'font-size:
$map->setextent($oldext->minx,$oldext->miny,$oldext->maxx,$ol=
dext->maxy);
//set the new map extent</span></font></p>
style=3D'font-size:
style=3D'font-size:
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Hope that helps,</span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>D. Pagurek</span></font></p>
style=3D'font-size:
style=3D'font-size:
<p class=3DMsoNormal style=3D'margin-left:.5in'><font size=3D2 =
face=3DTahoma><span
lang=3DEN-US style=3D'font-size:10.0pt;font-family:Tahoma'>-----Original
Message-----<br>
<b><span style=3D'font-weight:bold'>From:</span></b>
[mailto:mapserver-users-admin at lists.gis.umn.edu] <b><span =
bold'>On Behalf Of </span></b>Stefan Schwarzer<br>
<b><span style=3D'font-weight:bold'>Sent:</span></b> </span></font><font =
size=3D2 face=3DTahoma><span lang=3DEN-US =
style=3D'font-size:10.0pt;font-family:Tahoma'>Monday,
July 12, 2004</span></font><font size=3D2 face=3DTahoma><span =
lang=3DEN-US
style=3D'font-size:10.0pt;font-family:Tahoma'> </span></font><font
style=3D'font-size:10.0pt;font-family:Tahoma'>10:56
AM</span></font><font size=3D2 face=3DTahoma><span lang=3DEN-US =
style=3D'font-size:
10.0pt;font-family:Tahoma'><br>
<b><span style=3D'font-weight:bold'>To:</span></b> =
mapserver-users at lists.gis.umn.edu<br>
<b><span style=3D'font-weight:bold'>Subject:</span></b> =
Projection (e.g. Geographic to Robinson)</span></font></p>
<p class=3DMsoNormal style=3D'margin-left:.5in'><font size=3D3 =
face=3D"Times New Roman"><span
style=3D'font-size:12.0pt'> </span></font></p>
style=3D'font-size:12.0pt'>Hi there,<br>
<br>
it seems that either the "change projection on-the-fly" =
feature isn't
widely used or nobody has problems with it. At least, the number of =
threats
using the <b><span =
style=3D'font-weight:bold'>ms_newprojectionObj</span></b>
command is relatively small. And the WIKI is empty on the subject of
"Projections".<br>
<br>
projection of my data from "geographic" to =
"robinson" using
the ms_newprojectionObj object, but it didn't work, and honestly, =
I am a
bit confused by the different parameters...<br>
<br>
Thanks for any help,<br>
<br>
Stefan<br>
<br>
<br>
</span></font></p>
<x-sigsep>
<p style=3D'margin-left:.5in'></x-sigsep><font size=3D3 face=3D"Times =
New Roman"><x-tab><span
style=3D'font-size:12.0pt'> &nbs=
p;</x-tab>_______________________________________<br>
<br>
</span></font><font size=3D2 face=3DCourier><x-tab><span =
font-family:Courier'> <b><=
span
style=3D'font-weight:bold'></x-tab>Stefan Schwarzer<br>
</span></b><x-tab> </x-tab=
>GIS
& Data Management<br>
<br>
<x-tab> </x-tab>UNEP/DEWA/=
GRID-Geneva<br>
<x-tab> </x-tab>Chemin =
des
Anemones 11<br>
<x-tab> </x-tab>CH - 1219
Chatelaine<br>
<x-tab> </span></x-tab></f=
ont><font
size=3D2 face=3DCourier><span =
style=3D'font-size:10.0pt;font-family:Courier'>Switzerland</span></font><=
font
style=3D'font-size:10.0pt;font-family:Courier'><br>
<br>
<x-tab> </x-tab>Tel: =
(+41)
22.917.83.49<br>
<x-tab> </x-tab>Fax: =
(+41)
22.917.80.29<br>
<br>
<x-tab> </x-tab>Email:
stefan.schwarzer at grid.unep.ch<br>
<x-tab> </x-tab>Internet: =
<a
href=3D"http://geodata.grid.unep.ch/" =
eudora=3Dautourl>http://geodata.grid.unep.ch/<br>
</a></span></font><x-tab> =
</p>
</div>
</body>
</html>
------_=_NextPart_001_01C468D8.AD9A0424--
--__--__--
Message: 33
From: "Eduardo Patto Kanegae" <eduardo at consultoria.eti.br>
Date: Tue, 13 Jul 2004 10:22:06 -0300
Subject: [Mapserver-users] about 2nd MUM
just a curious question: how many visitors were there at 2nd MUM?
best
http://www.consultoria.eti.br
UIN: 303747254
Treinamento em UMN MapServer - http://www.consultoria.eti.br/ptbr/?menuoption=mapserver
I Encontro Nacional de Usuários MapServer - http://mapserver.cttmar.univali.br/encontro2004
Projeto MapServer Brasil - http://mapserver.cttmar.univali.br
***Fim da Mensagem / End of Message ***
--__--__--
Message: 34
Reply-To: <murilo.yoshida at agx.com.br>
From: "Murilo Lacerda Yoshida" <murilo.yoshida at agx.com.br>
To: "'Daniel Morissette'" <dmorissette at dmsolutions.ca>,
Subject: RES: [Mapserver-users] CreateLegendIcon and FAQ suggestion
Date: Tue, 13 Jul 2004 10:37:34 -0300
Daniel,
I am using mapserver v4.0... So I guess that's it.
Thanks again,
Murilo
-----Mensagem original-----
De: mapserver-users-admin at lists.gis.umn.edu
[mailto:mapserver-users-admin at lists.gis.umn.edu] Em nome de Daniel
Morissette
Enviada em: terça-feira, 13 de julho de 2004 01:57
Para: murilo.yoshida at agx.com.br
Cc: mapserver-users at lists.gis.umn.edu
Assunto: Re: [Mapserver-users] CreateLegendIcon and FAQ suggestion
line
The
Mapserver-users mailing list
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
--__--__--
Message: 35
Date: Tue, 13 Jul 2004 10:19:29 -0400
To: Eduardo Patto Kanegae <eduardo at consultoria.eti.br>
Subject: Re: [Mapserver-users] about 2nd MUM
Hello Eduardo,
Roughly about 220 people attended MUM2/OSGIS in Ottawa. The proceedings
can be found at http://www.omsug.ca/osgis2004/proceedings.html which
include a list of attendees.
jeff
> best
> UIN: 303747254
Jeff McKenna
GIS Specialist
DM Solutions Group Inc.
--__--__--
Message: 36
Date: Tue, 13 Jul 2004 16:20:43 +0200
To: "Pagurek, Debbie" <PAGUREKD at AGR.GC.CA>
From: Stefan Schwarzer <stefan.schwarzer at grid.unep.ch>
Robinson)
--=====================_33479015==.ALT
Content-Type: text/plain; charset="us-ascii"; format=flowed
Thanks Debbie.
Yes, that's actually the code I've found as well in a thread which dates
back a year or so. But it doesn't work with me. I assume that I have to
change as well the projection definition in the map file, which is now
PROJECTION
'init=epsg:4326'
END
Am I right? But what is the code? I din't find on the Internet...
Stefan
>This works for me:
> $newproj=ms_newprojectionObj("proj=robin,lon_0=0,x_0=0,y_0=0");
>$latlon=ms_newprojectionObj("proj=longlat,ellps=GRS80,datum=NAD83,no_defs");
> $oldext= ms_newRectObj();
>$map->setextent($oldext->minx,$oldext->miny,$oldext->maxx,$oldext->maxy);
>Hope that helps,
>D. Pagurek
>From: mapserver-users-admin at lists.gis.umn.edu
>[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Stefan Schwarzer
>Subject: [Mapserver-users] Change Projection (e.g. Geographic to Robinson)
>Hi there,
>threats using the ms_newprojectionObj command is relatively small. And the
>ms_newprojectionObj object, but it didn't work, and honestly, I am a bit
>Stefan
> Stefan Schwarzer
> Switzerland
Stefan Schwarzer
Switzerland
Content-Type: text/html; charset="us-ascii"
<html>
<body>
<font size=3>Thanks Debbie.<br><br>
now<br><br>
<x-tab> </x-tab>PROJECTION<br>
<x-tab> </x-tab>
'init=epsg:4326'<br>
<x-tab> </x-tab>END<br><br>
Internet...<br><br>
Stefan<br><br>
<br>
</font><blockquote type=cite class=cite cite><font face="arial" size=2 color="#000080">This
works for me:<br>
<br>
$newproj=ms_newprojectionObj("proj=robin,lon_0=0,x_0=0,y_0=0");<br>
$latlon=ms_newprojectionObj("proj=longlat,ellps=GRS80,datum=NAD83,no_defs");<br>
<br>
$oldext= ms_newRectObj();<br>
//this is the extent of my map in geographic<br>
Robinson<br>
<br>
//set the new map extent<br>
<br>
<br>
Hope that helps,<br>
D. Pagurek<br>
<br>
</font><font face="tahoma" size=2>-----Original Message-----<br>
<b>From:</b> mapserver-users-admin at lists.gis.umn.edu
[<a href="mailto:mapserver-users-admin at lists.gis.umn.edu" eudora="autourl">mailto:mapserver-users-admin at lists.gis.umn.edu</a>]
<b>On Behalf Of </b>Stefan Schwarzer<br>
<b>Sent:</b> Monday, July 12, 2004 10:56 AM<br>
<b>To:</b> mapserver-users at lists.gis.umn.edu<br>
<b>Subject:</b> [Mapserver-users] Change Projection (e.g. Geographic to
Robinson)<br>
</font><font face="Times New Roman, Times" size=3> <br>
Hi there,<br><br>
isn't widely used or nobody has problems with it. At least, the number of
threats using the <b>ms_newprojectionObj</b> command is relatively small.
"Projections".<br><br>
using the ms_newprojectionObj object, but it didn't work, and
honestly, I am a bit confused by the different parameters...<br><br>
Thanks for any help,<br><br>
Stefan<br><br>
<br>
<x-tab> </x-tab>
_______________________________________<br><br>
</font><font face="courier" size=2><x-tab> </x-tab>
<b>Stefan Schwarzer<br>
</b><x-tab> </x-tab>GIS
& Data Management<br><br>
<x-tab> </x-tab>UNEP/DEWA/GRID-Geneva<br>
<x-tab> </x-tab>Chemin des
Anemones 11<br>
Chatelaine<br>
<x-tab> </x-tab>Switzerland<br><br>
<x-tab> </x-tab>Tel: (+41)
22.917.83.49<br>
<x-tab> </x-tab>Fax: (+41)
22.917.80.29<br><br>
<a href="http://geodata.grid.unep.ch/" eudora="autourl">http://geodata.grid.unep.ch/</a><br>
</font><font size=3><x-tab> </x-tab>_______________________________________
</blockquote>
<x-sigsep><p></x-sigsep>
<x-tab> </x-tab>_______________________________________<br><br>
</font><font face="Courier, Courier" size=2><x-tab> </x-tab><b>Stefan
Schwarzer<br>
Anemones 11<br>
Chatelaine<br>
22.917.83.49<br>
<a href="http://geodata.grid.unep.ch/" eudora="autourl">http://geodata.grid.unep.ch/<br>
</a></font><font size=3><x-tab> </x-tab>_______________________________________
</font></body>
</html>
--=====================_33479015==.ALT--
--__--__--
Message: 37
Date: Tue, 13 Jul 2004 11:26:43 -0300
From: Eduardo Patto Kanegae <eduardo at consultoria.eti.br>
Subject: [Mapserver-users] Map of MapServer Users
I've found the map of mapserver users at
http://www.moximedia.com:8080/imf-ows/imf.jsp?site=ms_users
and other reference is the WMS map of MUM2 attendees.
is there any another?
is there any WMS one?
UIN: 303747254
Fórum MapServer Brasil - http://mapserver.cttmar.univali.br/forum
--__--__--
Message: 38
Date: Tue, 13 Jul 2004 16:52:19 +0200
From: "eric.belenfant" <eric.belenfant at ac-orleans-tours.fr>
Organization: Rectorat =?ISO-8859-1?Q?Orl=E9ans?=
To: Mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] adding dynamic charts on the map
I'm looking for a way to add dynamic charts on a map generated with
mapserver.
I use mapscript, and i'm able to generate the pie charts for example
from the datas which are in the .tab files (MAPINFO).
But my problem is to add these charts at the right place on the chart.
There could have lots of charts too.
I heard that i could add these images as symbols but symbols are some
predefined images and not dynamic or am i stupid ?
Would anyone encountered this problem ???
thanks
eric
--__--__--
Message: 39
To: Dion Duran <dion.duran at uei-houston.com>, mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] tileindex problems
From: Tyler Mitchell <tjmitchell at riverside.bc.ca>
Date: Tue, 13 Jul 2004 08:27:47 -0700
> 1) Try complete paths for the tile index and for the raster files as
> recorded in the tile index.
I found that this is very important to do.
--__--__--
Message: 40
Date: Tue, 13 Jul 2004 11:35:44 -0400
Subject: [Mapserver-users] Mr. SID to GeoTIFF
I have aerial imagery in Mr. SID format and I use a LizardTech utility to
convert the sid image to a geo tiff. I can view the resulting tiff in an
image viewer, however, when I load it in MapServer (via PHP), I get the
following error:
[MapServer Error]: drawTIFF(): Only colormapped and grayscale images are
supported.
More info:
- The tiff is color.
- The utility offers the following options:
-h or -?
show short usage message
-help
show detailed usage message
-v or -version
show version information
-quiet
don't show informational messages
-log STRING
write output to log file
-progress STRING
progress meter style: none | default | timer
-i or -input STRING
[required]
input file
-o or -output STRING
[required]
output file
-watermarkFile STRING
watermark file
-watermarkPosition STRING
position of watermark: CENTER, CENTER_LEFT, CENTER_RIGHT, UPPER_LEFT,
UPPER_CE
NTER, UPPER_RIGHT, LOWER_LEFT, LOWER_CENTER, LOWER_RIGHT (default)
-drmin or -dynRangeMin UNSIGNED-INT
minimum dynamic range
-drmax or -dynRangeMax UNSIGNED-INT
maximum dynamic range
-drauto or -autoDynRange
automatic dynamic range adjustment
-wf or -worldFile
generate world file
-sh or -stripHeight UNSIGNED-INT
strip height
-ulxy FLOAT0 FLOAT1
upper-left of scene (x,y)
-lrxy FLOAT0 FLOAT1
lower-right of scene (x,y)
-cxy FLOAT0 FLOAT1
center of scene (x,y)
-wh FLOAT0 FLOAT1
size of scene (width,height)
-s or -scale SIGNED-INT
scale of scene
-coord or -coordspace STRING
coordinate space of scene: geo | image | resrel
-jpg or -jpeg
output is JPEG
-tif or -tiff
output is TIFF
-tifg or -geotiff
output is GeoTIFF
-bmp
output is BMP
-bip
output is BIP
-raw
output is RAW (same as BIP)
-pwd or -password STRING
password to decode image
- I used the following command with the conversion utility:
mrsiddecode -i do_s03_9540_00.sid -o do_s03_9540_00.tif -tifg
Thanks for any help.
-Abe
--__--__--
Message: 41
Date: Tue, 13 Jul 2004 10:30:31 -0500
Subject: [Mapserver-users] Using a polygon instead of a bounding box?
I'm using data from multiple sources, some of which are more accurate
than others. When viewed at a national level they are all equally
accurate, but when viewed at a county level or lower, I want the
better (local) data sources to "override" the poorer (national) data
sources. My problem is that these local data sources are not
necessarily rectangles, but can be arbitrary polygons.
I would like mapserver to be able to query my coverage database, get
the bounding polygons for each data source I need, and then create a
layer based on this patchwork. Any locations not covered by the
higher accuracy local data would be filled in with the national data.
Optimally, this would be transparent to the user, and would appear to
be just another layer served by mapserver. Is this possible? If not,
any ideas or workarounds?
Thanks,
Timothy Rupe
Programmer
USGS Mid-Continent Mapping Center
--__--__--
Message: 42
To: "bean at vt.edu" <agillesp at vt.edu>
cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Mr. SID to GeoTIFF
Date: Tue, 13 Jul 2004 12:02:31 -0400
Colormapped would seem to mean a palette, as opposed to true-color?
Have you tried checking and decreasing the color-depth of your TIFF?
H4sICNoBwDoAA3NpZwA9jbsNwDAIRHumuC4NklvXTOD0KSJEnwU8fHz4Q8M9i3sGzkS7BBrm
OkCTwsycb4S3DloZuMIYeXpLFqw5LaMhXC2ymhreVXNWMw9YGuAYdfmAbwomoPSyFJuFn2x8
Opr8bBBidccAAAA=
MOTD on Prickle-Prickle, the 48th of Confusion, in the YOLD 3170:
nuppin'
--__--__--
Message: 43
Subject: Re: [Mapserver-users] adding dynamic charts on the map
To: "eric.belenfant" <eric.belenfant at ac-orleans-tours.fr>
Cc: Mapserver List <mapserver-users at lists.gis.umn.edu>
Date: 13 Jul 2004 12:03:24 -0400
On Tue, 2004-07-13 at 10:52, eric.belenfant wrote:
> Hi,
> mapserver.
> thanks
> eric
You are not stupid. What you want to do is very difficult to accomplish
dynamically.
I spent quite a bit of time looking into this at one time. Both for
dynamic pie charts and dynamic legends. It's quite difficult and really
cannot be done completely dynamically. With my dynamic legends I wound
up generating them once (a large but finite set) and using a naming
scheme and a special symbol.sym file. Not really worth the effort.
With the pie charts we wound up just displaying circles on the map and
when the user clicks the circle we display a pie chart OFF the map in a
popup window.
See: http://www.gomoos.org/shrimp/ (Perl Mapscript)
Click one of the symbols to see the pie-charts.
Choose Time Series Maps to see the dynamic legends.
--__--__--
Message: 44
Date: Tue, 13 Jul 2004 11:07:55 -0500
From: BONNER S KARGER <bskarger at students.wisc.edu>
To: Mapserver User Group <Mapserver-users at lists.gis.umn.edu>
Subject: [Mapserver-users] JOIN problems
List,
I am trying to use JOIN in my LAYER object to get more attribute info from a MySQL table. I have a point layer shapefile called "waste1" in the data directory. There is a field called PRDUCER_ID. The MySQL table I want to join is in the DB called "BYPRODUCTS3". The table name is "PRODUCER". The field name I want to use as the key in the table is called "PRODUCER_ID".
Browsing the map is no problem, but when I click the query option, then click a point from this layer, I get the following error:
Content-type: text/html msMySQLJoinConnect(): DBASE file error. Item PRDUCER_ID not found in table waste1.
msMySQLQuery(): Query error. Bad mysql query (SELECT count(PRDUCER_ID) FROM waste1)
What is going on? It seems like there is no place in the JOIN object to tell mapserver what db table to use...only which .dbf table to use.
Below is the layer def. from my map file:
LAYER
NAME waste1
TYPE POINT
STATUS ON
DATA waste1
CLASS
NAME "Meat Proc. Residuals"
TEMPLATE "test.html"
COLOR 255 051 000
SYMBOL "circle"
SIZE 8
END
TOLERANCE 5
DUMP TRUE # allow GML export
JOIN
CONNECTIONTYPE mysql
CONNECTION "server:user:pass:BYPRODUCTS3"
NAME "MeatProcJoin"
TABLE waste1
FROM PRODUCER_ID
TO PRDUCER_ID
TYPE SINGLE
END
END
This is mapserver 4.2, on Linux.
Any ideas?
Thanks
Bonner
--__--__--
Message: 45
Date: Tue, 13 Jul 2004 11:17:11 -0500
To: Timothy Rupe <twoslick at gmail.com>
Subject: Re: [Mapserver-users] Using a polygon instead of a bounding box?
Would it not work to create a layer with the better data and have it's
maxscale set? It would have to overlay the other data. And since it
overlays, if it's an opaque polygon, it will cover the other data.
Now, I'm not an expert...by any stretch. So others may have better ways
to do this.
Jerl
> Thanks,
> Timothy Rupe
> Programmer
--__--__--
Message: 46
Date: Tue, 13 Jul 2004 12:21:12 -0400
Subject: [Mapserver-users] Source Shape data in 3 dimension
------_=_NextPart_001_01C468F5.69D486DE
charset="US-ASCII"
I seem to be having problems displaying some of my Shape file data in
Mapserver and I just noticed that this data is in three dimensions; X,
Y, and Z, for height I suspect. I do not expect to see 3 dimensional
images through Mapserver, but does anyone know if Mapserver has an issue
with showing this type of data in 2 dimensions?
=20
Trent Burton
charset="US-ASCII"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD><TITLE>Message</TITLE>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Dus-ascii">
<META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR></HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2><SPAN class=3D832351716-13072004>I seem =
to be having=20
problems displaying some of my Shape file data in Mapserver and I just =
noticed=20
that this data is in three dimensions; X, Y, and Z, for height I =
suspect. =20
I do not expect to see 3 dimensional images through Mapserver, but does =
anyone=20
know if Mapserver has an issue with showing this type of data in 2=20
dimensions?</SPAN></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><SPAN=20
class=3D832351716-13072004></SPAN></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2><SPAN class=3D832351716-13072004>Trent=20
Burton</SPAN></FONT></DIV></BODY></HTML>
=00
------_=_NextPart_001_01C468F5.69D486DE--
--__--__--
Message: 47
Date: Tue, 13 Jul 2004 11:26:56 -0500
Subject: [Mapserver-users] Brazillian maps
Hello,
I am looking map datasets that cover Brazil, and/or South America.
So far I cannot find much. Part of the problem could be that I do not
read or speak Spanish.
If anyone could point me in the right direction I would greatly
appreciate it.
I'm looking for political boundaries, road, rail, cities, water
boundaries, and anything else that might be useful.
Thank you.
Jerl
--__--__--
Message: 48
Subject: RE: [Mapserver-users] getInteger(): Symbol definition error.
Date: Tue, 13 Jul 2004 10:45:47 -0600
To: "Daniel Morissette" <dmorissette at dmsolutions.ca>,
"Williams John"
You guys are awesome. Hit the nail on the head!
I've been working with John on this issue.
Thanks for solving another one!
Mark
[mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Daniel
Morissette
Sent: Monday, July 12, 2004 10:16 PM
To: Williams John
> I am receiving this error
> getInteger(): Symbol definition error. Parsing error near (END):(line 170)
> upon implementing this block of code. All vector layers are working
> LAYER
> MINSCALE 1
> MAXSCALE 150000
> NAME world_best
> TYPE RASTER
> TILEINDEX "C:\__MAPSERVER_SHAPEFILES\world_best_sort"
> TILEITEM "location"
> STATUS OFF
> #FILTERITEM "location"
> #FILTER "lk"
> OFFSITE 0
> END
a color index.
This message is intended only for the use of the Addressee and may
contain information that is PRIVILEGED and CONFIDENTIAL.
If you are not the intended recipient, you are hereby notified that any
dissemination of this communication is strictly prohibited. If you have
received this communication in error, please erase all copies of the
message and its attachments and notify Space Imaging immediately.
--__--__--
Message: 49
Subject: RE: [Mapserver-users] Mr. SID to GeoTIFF
Date: Tue, 13 Jul 2004 12:53:50 -0400
To: "bean at vt.edu" <agillesp at vt.edu>, <mapserver-users at lists.gis.umn.edu>
It sounds like you're using the "native" TIFF support rather than GDAL's
more comprehensive support. Run "mapserv -v" at the command line and
make sure you have GDAL input support and do NOT have TIFF input
support.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com
bean at vt.edu
Sent: Tuesday, July 13, 2004 11:36 AM
to convert the sid image to a geo tiff. I can view the resulting tiff
in an image viewer, however, when I load it in MapServer (via PHP), I
supported.
More info:
-h or -?
-help
-v or -version
-quiet
-log STRING
-progress STRING
-i or -input STRING
[required]
input file
[required]
output file
watermark file
UPPER_CE NTER, UPPER_RIGHT, LOWER_LEFT, LOWER_CENTER, LOWER_RIGHT
(default)
-wf or -worldFile
generate world file
strip height
-ulxy FLOAT0 FLOAT1
-lrxy FLOAT0 FLOAT1
-cxy FLOAT0 FLOAT1
-wh FLOAT0 FLOAT1
scale of scene
-jpg or -jpeg
output is JPEG
-tif or -tiff
output is TIFF
-tifg or -geotiff
output is GeoTIFF
-bmp
output is BMP
-bip
output is BIP
-raw
-Abe
--__--__--
End of Mapserver-users Digest
