[Mapserver-users] Hi all.... here is my problem.... trying to load php dll's
    DEAN Jeremy E
    Jeremy.E.DEAN at Co.Benton.OR.US
    Wed Jul 14 08:36:48 PDT 2004
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C469B8.6067C990
Content-Type: text/plain;
	charset="iso-8859-1"
Hello,
I am assuming you are trying to install on a Windows OS.  If this is the
case you need to make sure you have the php_mapscript.dll in your
<Drive>:\WINDOWS\System32\ folder (can be WINNT\System32 depending on what
you are using) along with 9 necessary DLL's that MapScript uses.  These
should be bundled in 6 zip files that are included in the standard binary
download.
> The dll "php_mapscript.dll" looks as it was walking away.. I mean, an
error rise when I try to load it: "Unable to load php_mapscript.dll <
After that is done you should just have to add:
extension=php_mapscript.dll
to your PHP.ini file, wherever it resides.
> In the "extension_dir" of "php.ini" I put the path where
"php_mapscript.dll" is, so I actually have the dll. (I checked it and it's
there) <
Also, I have always used the phpinfo( ) call as a quick way to test if my
installation worked.
Hope this helps,
Jeremy Dean
Benton County IRM
Programmer/Analyst
[541] 766-6610
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=iso-8859-1">
<TITLE>Hi all.... here is my problem.... trying to load php dll's</TITLE>
<META content="MSHTML 6.00.2800.1400" name=GENERATOR></HEAD>
<BODY>
<DIV><SPAN class=789181715-14072004><FONT face=Arial color=#0000ff
size=2>Hello,</FONT></SPAN></DIV>
size=2></FONT></SPAN> </DIV>
<DIV><SPAN class=789181715-14072004><FONT face=Arial color=#0000ff size=2>I am
assuming you are trying to install on a Windows OS.  If this is the case
These should be bundled in 6 zip files that are included in the
standard binary download.</FONT></SPAN></DIV>
<DIV class=OutlookMessageHeader dir=ltr align=left><FONT size=2><SPAN
color=#0000ff>> </FONT></SPAN>The dll "php_mapscript.dll" looks as it
was walking away.. I mean, an error rise when I try to load it: "Unable to load
php_mapscript.dll<FONT face=Arial><FONT color=#0000ff><SPAN
class=789181715-14072004> </SPAN><SPAN
class=789181715-14072004>< </SPAN></FONT></FONT><BR><BR><SPAN
class=789181715-14072004><FONT face=Arial color=#0000ff>After that is done you
should just have to add:</FONT></SPAN></FONT></DIV>
<DIV class=OutlookMessageHeader dir=ltr align=left><FONT face=Arial
color=#0000ff size=2><SPAN class=789181715-14072004></SPAN></FONT> </DIV>
color=#0000ff>extension=php_mapscript.dll</FONT></SPAN></FONT></DIV>
<DIV><FONT size=2><SPAN class=789181715-14072004><FONT face=Arial
color=#0000ff></FONT></SPAN></FONT> </DIV>
color=#0000ff>to your PHP.ini file, wherever it resides.</DIV>
align=left><BR></DIV></FONT></SPAN></FONT>
<DIV class=OutlookMessageHeader dir=ltr style="MARGIN-RIGHT: 0px"
align=left><FONT size=2><SPAN class=789181715-14072004> </SPAN><BR><SPAN
color=#0000ff>> </FONT></SPAN>In the "extension_dir" of "php.ini" I put
the path where "php_mapscript.dll" is, so I actually have the dll. (I checked it
and it's there)<SPAN class=789181715-14072004><FONT face=Arial
color=#0000ff> <</FONT></SPAN></FONT></DIV>
align=left><FONT face=Arial color=#0000ff size=2><SPAN
class=789181715-14072004>Also, I have always used the phpinfo( ) call as a quick
way to test if my installation worked.</SPAN></FONT></DIV>
class=789181715-14072004>Hope this helps,</SPAN></FONT></DIV>
class=789181715-14072004></SPAN></FONT><FONT face=Arial color=#0000ff
size=2><SPAN class=789181715-14072004><FONT face="Courier New" size=2>Jeremy
Dean</FONT> <BR><FONT face="Courier New" size=2>Benton County IRM</FONT>
<BR><FONT face="Courier New" size=2>Programmer/Analyst</FONT> <BR><FONT
face="Courier New" size=2>[541] 766-6610</FONT>
</DIV></SPAN></FONT></BODY></HTML>
------_=_NextPart_001_01C469B8.6067C990--
More information about the MapServer-users
