[Mapserver-users] JOIN problem
Rebecca Colwell
colwell at geog.umn.edu
Wed Jul 14 11:40:02 EDT 2004
I'm trying to work through building one of my first .map files, and have
hit a wall. I can't seem to figure out how to do a one-to-one join. I
keep getting the error messages:
msDrawMap(): Image handling error. Failed to draw layer named 'states'.
msDBFGetItemIndex(): DBASE file error. Item 'Disfchmt_R' not found.
I triple checked the .dbf I'm trying to join, and that is the name of
the attribute field I want to access.
Below is my short bit of code so far. I would be so thankful if anyone
could guide me in the right direction on how to get it to work.
~Becky
MAP
IMAGETYPE PNG24
EXTENT -2153561.581984760 4847233.565621579 2641846.236294404
-6178805.564371807
SIZE 800 500
SHAPEPATH "data"
IMAGECOLOR 203 201 226
PROJECTION
"proj=laea"
"ellps=clrk66"
"lat_0=45"
"lon_0=-100"
END
# Start of LAYER DEFINITIONS
LAYER # States polygon layer begins here
NAME states
DATA STATES
STATUS DEFAULT
TYPE POLYGON
PROJECTION
"init=epsg:4326"
END
JOIN
NAME "Felon Ethnicity"
TABLE "data/FelonEthnicity.dbf"
FROM "STATE_NAME"
TO "STATE"
TYPE single
END #Join
CLASS
NAME "<21%"
EXPRESSION ('[Disfchmt_R]' <= .021)
COLOR 242 240 247
OUTLINECOLOR 200 200 200
COLOR 232 232 232
OUTLINECOLOR 32 32 32
END
END # States polygon layer ends here
# End of LAYER DEFINITIONS -------------------------------
END # end of map file/object
