[Mapserver-users] Reprojecting Problem
kgrootendorst at baird.com
Wed Jul 14 12:45:05 EDT 2004
This is a multipart message in MIME format.
--=_alternative 005C067C85256ED1_=
Content-Type: text/plain; charset="US-ASCII"
Ed,
Yes, it supports proj, and the other layers look okay. These other layers
are in the same projection as the map object.
The custom projection I'm using in the map is as follows:
# Custom Lambert Conformal Conic
<50000> +proj=lcc +lat_1=49 +lat_2=63 +lat_0=49 +lon_0=-91.86 +x_0=6200000
+y_0=2958000 +ellps=GRS80 +datum=NAD83 +units=m +no_defs no_defs <>
I've had no problems using this projection with ArcMap.
I'm running the following:
Mapserver 4.2
PHP 4.3.4
Win2000
Kevin
"Ed McNierney" <ed at topozone.com>
07/14/2004 10:50 AM
To
<kgrootendorst at baird.com>, <mapserver-users at lists.gis.umn.edu>
cc
Subject
[SPAM] - RE: [Mapserver-users] Reprojecting Problem - Email found in
subject
Kevin -
Do all your other layers look OK in the output map? BTW, I think it's
good practice to include a PROJECTION block in ALL layers if they're not
all the same projection.
If you run "mapserv -v" from the command line, does it show
"SUPPORTS=PROJ"?
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
Sent: Wednesday, July 14, 2004 10:17 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Reprojecting Problem
Hello,
I'm having trouble with reprojecting in Mapserver. I'm trying to
reproject my 'shoreline' file (defined as UTM 17N NAD83) to my map, which
has been defined with a customized lambert conformal conic projection.
Based on my Mapfile below, can anyone see why my data will not re-project?
Am I missing something? I thought everything looked okay, but obviously
something must be wrong!
MAP
NAME "test"
STATUS ON
EXTENT 6000000 600000 9000000 1500000
#Minx Miny Maxx Maxy
SIZE 600 400
SHAPEPATH "./Data"
SYMBOLSET "./etc/symbols.sym"
FONTSET "./etc/fonts.txt"
IMAGETYPE PNG
UNITS METERS
WEB
IMAGEPATH "C:/Program Files/Apache Group/Apache2/htdocs/ms_tmp/"
IMAGEURL "/ms_tmp/"
END
PROJECTION
"init=epsg:50000" #Custom LCC Projection - defined in proj/epsg
END
LEGEND
STATUS ON
IMAGECOLOR 255 255 255
POSITION LL
KEYSIZE 18 12
KEYSPACING 5 5
END
SCALEBAR
STATUS ON
COLOR 255 255 255
OUTLINECOLOR 0 0 0
BACKGROUNDCOLOR 0 0 0
UNITS KILOMETERS
INTERVALS 5
SIZE 150 10
STYLE 0
POSITION LL
END
LAYER
NAME "ec_counties_LCC"
STATUS ON
DATA "./ec_counties_LCC"
TYPE POLYGON
UNITS METERS
SIZEUNITS PIXELS
CLASS
TEMPLATE "ttt"
STYLE
SYMBOL 0
COLOR 211 255 190
OUTLINECOLOR 0 0 0
END
END
END
LAYER
NAME "New_York_County"
STATUS ON
DATA "./New_York_County"
TYPE POLYGON
#LABELITEM "NAME"
CLASS
#NAME "New_York_County"
TEMPLATE "ttt"
LABEL
TYPE bitmap
FONT "arial"
SIZE small
POSITION CC
COLOR 255 0 0
END
STYLE
SYMBOL 0
COLOR 252 241 207
OUTLINECOLOR 0 0 0
END
END
END
LAYER
NAME "Shoreline_UTM"
STATUS ON
DATA "./Shoreline_UTM"
TYPE LINE
UNITS METERS
SIZEUNITS PIXELS
PROJECTION
"init=epsg:26917" #UTM Zone 17N NAD 83
END
CLASS
STYLE
SYMBOL 0
COLOR 0 0 255
END
END
END
END
Thanks.
Kevin
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Ed,</font>
<br><font size=2 face="sans-serif">Yes, it supports proj, and the other
layers look okay. These other layers are in the same projection as
the map object.</font>
<br><font size=2 face="sans-serif">The custom projection I'm using in the
map is as follows:</font>
<br><font size=2 face="sans-serif"># Custom Lambert Conformal Conic</font>
<br><font size=2 face="sans-serif"><50000> +proj=lcc +lat_1=49 +lat_2=63
+lat_0=49 +lon_0=-91.86 +x_0=6200000 +y_0=2958000 +ellps=GRS80 +datum=NAD83
+units=m +no_defs no_defs <></font>
<br><font size=2 face="sans-serif">I've had no problems using this projection
with ArcMap.</font>
<br>
<br><font size=2 face="sans-serif">I'm running the following:</font>
<br><font size=2 face="sans-serif">Mapserver 4.2</font>
<br><font size=2 face="sans-serif">PHP 4.3.4</font>
<br><font size=2 face="sans-serif">Win2000</font>
<br>
<br><font size=2 face="sans-serif">Kevin<br>
<br>
</font>
<br>
<br>
<br>
<table width=100%>
<tr valign=top>
<td width=40%><font size=1 face="sans-serif"><b>"Ed McNierney"
<ed at topozone.com></b> </font>
<p><font size=1 face="sans-serif">07/14/2004 10:50 AM</font>
<td width=59%>
<table width=100%>
<tr>
<td>
<div align=right><font size=1 face="sans-serif">To</font></div>
<td valign=top><font size=1 face="sans-serif"><kgrootendorst at baird.com>,
<mapserver-users at lists.gis.umn.edu></font>
<tr>
<td>
<div align=right><font size=1 face="sans-serif">cc</font></div>
<td valign=top>
<tr>
<td>
<div align=right><font size=1 face="sans-serif">Subject</font></div>
<td valign=top><font size=1 face="sans-serif">[SPAM] - RE: [Mapserver-users]
Reprojecting Problem - Email found in subject</font></table>
<br>
<table>
<tr valign=top>
<td>
<td></table>
<br></table>
<br>
<br>
<br><font size=2 color=blue face="Arial">Kevin -</font>
<br><font size=3> </font>
<br><font size=2 color=blue face="Arial">Do all your other layers look
OK in the output map? BTW, I think it's good practice to include
a PROJECTION block in ALL layers if they're not all the same projection.</font>
<br><font size=2 color=blue face="Arial">If you run "mapserv -v"
from the command line, does it show "SUPPORTS=PROJ"?</font>
<br><font size=2 color=blue face="Arial"> - Ed</font>
<p><font size=2 color=blue face="Arial">Ed McNierney<br>
President and Chief Mapmaker<br>
TopoZone.com / Maps a la carte, Inc.<br>
73 Princeton Street, Suite 305<br>
North Chelmsford, MA 01863<br>
ed at topozone.com<br>
(978) 251-4242 </font>
<p>
<br>
<hr><font size=2 face="Tahoma"><b>From:</b> mapserver-users-admin at lists.gis.umn.edu
[mailto:mapserver-users-admin at lists.gis.umn.edu] <b>On Behalf Of </b>kgrootendorst at baird.com<b><br>
Sent:</b> Wednesday, July 14, 2004 10:17 AM<b><br>
To:</b> mapserver-users at lists.gis.umn.edu<b><br>
Subject:</b> [Mapserver-users] Reprojecting Problem</font><font size=3><br>
</font>
<br><font size=2 face="sans-serif"><br>
Hello,</font><font size=3> </font><font size=2 face="sans-serif"><br>
has been defined with a customized lambert conformal conic projection.</font><font size=3>
obviously something must be wrong!</font><font size=3> <br>
</font><font size=2 face="Courier New"><br>
MAP</font><font size=3> </font><font size=2 face="Courier New"><br>
NAME "test"</font><font size=3> </font><font size=2 face="Courier New"><br>
STATUS ON</font><font size=3> </font><font size=2 face="Courier New"><br>
EXTENT 6000000 600000 9000000 1500000 <br>
#Minx Miny Maxx Maxy</font><font size=3> </font><font size=2 face="Courier New"><br>
SIZE 600 400 <br>
SHAPEPATH "./Data"</font><font size=3> </font><font size=2 face="Courier New"><br>
SYMBOLSET "./etc/symbols.sym"</font><font size=3> </font><font size=2 face="Courier New"><br>
FONTSET "./etc/fonts.txt"</font><font size=3> </font><font size=2 face="Courier New"><br>
IMAGETYPE PNG</font><font size=3> </font><font size=2 face="Courier New"><br>
UNITS METERS</font><font size=3> </font><font size=2 face="Courier New"><br>
WEB</font><font size=3> </font><font size=2 face="Courier New"><br>
IMAGEPATH "C:/Program Files/Apache Group/Apache2/htdocs/ms_tmp/"</font><font size=3>
IMAGEURL "/ms_tmp/"</font><font size=3> </font><font size=2 face="Courier New"><br>
END</font><font size=3> </font><font size=2 face="Courier New"><br>
PROJECTION</font><font size=3> </font><font size=2 face="Courier New"><br>
- defined in proj/epsg</font><font size=3> </font><font size=2 face="Courier New"><br>
LEGEND</font><font size=3> </font><font size=2 face="Courier New"><br>
IMAGECOLOR 255 255 255</font><font size=3> </font><font size=2 face="Courier New"><br>
POSITION LL</font><font size=3> </font><font size=2 face="Courier New"><br>
KEYSIZE 18 12 <br>
KEYSPACING 5 5 <br>
SCALEBAR</font><font size=3> </font><font size=2 face="Courier New"><br>
OUTLINECOLOR 0 0 0</font><font size=3> </font><font size=2 face="Courier New"><br>
BACKGROUNDCOLOR 0 0 0</font><font size=3> </font><font size=2 face="Courier New"><br>
UNITS KILOMETERS</font><font size=3> </font><font size=2 face="Courier New"><br>
INTERVALS 5</font><font size=3> </font><font size=2 face="Courier New"><br>
SIZE 150 10 <br>
STYLE 0</font><font size=3> </font><font size=2 face="Courier New"><br>
LAYER</font><font size=3> </font><font size=2 face="Courier New"><br>
NAME "ec_counties_LCC"</font><font size=3> </font><font size=2 face="Courier New"><br>
DATA "./ec_counties_LCC"</font><font size=3> </font><font size=2 face="Courier New"><br>
TYPE POLYGON</font><font size=3> </font><font size=2 face="Courier New"><br>
SIZEUNITS PIXELS</font><font size=3> </font><font size=2 face="Courier New"><br>
CLASS</font><font size=3> </font><font size=2 face="Courier New"><br>
TEMPLATE "ttt"</font><font size=3> </font><font size=2 face="Courier New"><br>
STYLE</font><font size=3> </font><font size=2 face="Courier New"><br>
SYMBOL 0</font><font size=3> </font><font size=2 face="Courier New"><br>
COLOR 211 255 190</font><font size=3> </font><font size=2 face="Courier New"><br>
NAME "New_York_County"</font><font size=3> </font><font size=2 face="Courier New"><br>
DATA "./New_York_County"</font><font size=3> </font><font size=2 face="Courier New"><br>
#LABELITEM "NAME"</font><font size=3> </font><font size=2 face="Courier New"><br>
#NAME "New_York_County"</font><font size=3>
LABEL</font><font size=3> </font><font size=2 face="Courier New"><br>
TYPE bitmap</font><font size=3> </font><font size=2 face="Courier New"><br>
FONT "arial"</font><font size=3>
SIZE small</font><font size=3> </font><font size=2 face="Courier New"><br>
POSITION CC</font><font size=3> </font><font size=2 face="Courier New"><br>
COLOR 255 0 0</font><font size=3> </font><font size=2 face="Courier New"><br>
COLOR 252 241 207</font><font size=3> </font><font size=2 face="Courier New"><br>
NAME "Shoreline_UTM"</font><font size=3> </font><font size=2 face="Courier New"><br>
DATA "./Shoreline_UTM"</font><font size=3> </font><font size=2 face="Courier New"><br>
TYPE LINE</font><font size=3> </font><font size=2 face="Courier New"><br>
Zone 17N NAD 83</font><font size=3> </font><font size=2 face="Courier New"><br>
COLOR 0 0 255</font><font size=3> </font><font size=2 face="Courier New"><br>
END</font><font size=3> <br>
Thanks.</font><font size=3> <br>
Kevin</font>
<br>
--=_alternative 005C067C85256ED1_=--
