[Mapserver-users] JOIN problem
Randy James
rjames57 at yahoo.com
Wed Jul 14 13:50:16 EDT 2004
Hi Rebecca
I know a bit about regex but there are people on the list
that know way more than me so i am forwarding your email to
the list. Its a good idea to reply to the list rather than
the person who is try to give a bit of advice; that way the
whole list can give feedback.
Randy
--- Rebecca Colwell <colwell at geog.umn.edu> wrote:
> Hey Randy,
> I'm struggling to understand how to make things work that
> I didn't come
> across in the tutorial. Would you mind breaking down the
> terms regex
> and filter a bit for me, and maybe give me an example of
> what you mean?
> I'm experiencing that newbie/lost feeling (I've been
> trying to figure
> this out on my own for the last few days).
> Thanks,
> ~Becky
> PS Should I continue sending this dialog to the whole
> list or just you?
> I'm new with listserv etiquette too.
> Randy James wrote:
> > Hi
> > That it is not a join problem but maybe a regex problem
> or
> > something else with the filter.
> > Randy
> > --- Rebecca Colwell <colwell at geog.umn.edu> wrote: > Hey
> > Randy,
> >>Yes, it displays my US shapefile when I comment out
> that
> >>line. What
> >>does this tell you?
> >>Thanks!
> >>~Becky
> >>Randy James wrote:
> >>>Hi
> >>>Will it work if you do not filter it by 'Disfchmt_R' ?
> >>>Randy
> Hi,
> >>>>I'm trying to work through building one of my first
> >>.map
> >>>>files, and have
> >>>>hit a wall. I can't seem to figure out how to do a
> >>>>one-to-one join. I
> >>>>keep getting the error messages:
> >>>>msDrawMap(): Image handling error. Failed to draw
> layer
> >>>>named 'states'.
> >>>>msDBFGetItemIndex(): DBASE file error. Item
> >>'Disfchmt_R'
> >>>>not found.
> >>>>I triple checked the .dbf I'm trying to join, and
> that
> >>is
> >>>>the name of
> >>>>the attribute field I want to access.
> >>>>Below is my short bit of code so far. I would be so
> >>>>thankful if anyone
> >>>>could guide me in the right direction on how to get
> it
> >>to
> >>>>work.
> >>>>~Becky
> >>>>MAP
> >>>> IMAGETYPE PNG24
> >>>> EXTENT -2153561.581984760 4847233.565621579
> >>>>2641846.236294404
> >>>>-6178805.564371807
> >>>> SIZE 800 500
> >>>> SHAPEPATH "data"
> >>>> IMAGECOLOR 203 201 226
> >>>> PROJECTION
> >>>> "proj=laea"
> >>>> "ellps=clrk66"
> >>>> "lat_0=45"
> >>>> "lon_0=-100"
> >>>> END
> >>>> # Start of LAYER DEFINITIONS
> >>>> LAYER # States polygon layer begins here
> >>>> NAME states
> >>>> DATA STATES
> >>>> STATUS DEFAULT
> >>>> TYPE POLYGON
> >>>> PROJECTION
> >>>> "init=epsg:4326"
> >>>> END
> >>>> JOIN
> >>>> NAME "Felon Ethnicity"
> >>>> TABLE "data/FelonEthnicity.dbf"
> >>>> FROM "STATE_NAME"
> >>>> TO "STATE"
> >>>> TYPE single
> >>>> END #Join
> >>>> CLASS
> >>>> NAME "<21%"
> >>>> EXPRESSION ('[Disfchmt_R]' <= .021)
> >>>> COLOR 242 240 247
> >>>> OUTLINECOLOR 200 200 200
> >>>> COLOR 232 232 232
> >>>> OUTLINECOLOR 32 32 32
> >>>> END
> >>>> END # States polygon layer ends here
> >>>> # End of LAYER DEFINITIONS
> >>>>END # end of map file/object
> >>>>_______________________________________________
> >>>>Mapserver-users mailing list
> >>>>Mapserver-users at lists.gis.umn.edu
>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
______________________________________________________________________
> >>>Post your free ad now! http://personals.yahoo.ca
Do you Yahoo!?
New and Improved Yahoo! Mail - Send 10MB messages!
http://promotions.yahoo.com/new_mail
