[Mapserver-users] JOIN problem
David Fawcett
David.Fawcett at state.mn.us
Wed Jul 14 14:45:22 EDT 2004
If that doesn't work, you may want to try your field name in all caps.
e.g. [DISFCHMT_R]
This may have been dealt with many versions ago, but I seem to remember
that MapServer sometimes wanted field names in all caps.
David.
David J. Fawcett
MN Office of Environmental Assistance
>>> Dylan Keon <keon at nacse.org> 7/14/2004 1:19:34 PM >>>
There is a good explanation of EXPRESSION at
http://mapserver.gis.umn.edu/doc42/mapfile-reference.html#class
Make sure your attribute name is *exactly* as it appears in the DBF
file, as they are case sensitive.
Also, it should probably be
EXPRESSION ([Disfchmt_R] <= .021)
instead of
EXPRESSION ('[Disfchmt_R]' <= .021)
(remove the single quotation marks).
--Dylan
On 07/14/2004 10:50 AM, Randy James wrote:
> Hi Rebecca
> I know a bit about regex but there are people on the list
> that know way more than me so i am forwarding your email to
> the list. Its a good idea to reply to the list rather than
> the person who is try to give a bit of advice; that way the
> whole list can give feedback.
> Randy
> --- Rebecca Colwell <colwell at geog.umn.edu> wrote:
>>Hey Randy,
>>I'm struggling to understand how to make things work that
>>I didn't come
>>across in the tutorial. Would you mind breaking down the
>>terms regex
>>and filter a bit for me, and maybe give me an example of
>>what you mean?
>> I'm experiencing that newbie/lost feeling (I've been
>>trying to figure
>>this out on my own for the last few days).
>>Thanks,
>>~Becky
>>PS Should I continue sending this dialog to the whole
>>list or just you?
>> I'm new with listserv etiquette too.
>>Randy James wrote:
>>>Hi
>>>That it is not a join problem but maybe a regex problem
>>or
>>>something else with the filter.
>>>Randy
>>>--- Rebecca Colwell <colwell at geog.umn.edu> wrote: > Hey
>>>Randy,
>>>>Yes, it displays my US shapefile when I comment out
>>that
>>>>line. What
>>>>does this tell you?
>>>>Thanks!
>>>>~Becky
>>>>Randy James wrote:
>>>>>Hi
>>>>>Will it work if you do not filter it by 'Disfchmt_R' ?
>>>>>Randy
>>Hi,
>>>>>>I'm trying to work through building one of my first
>>>>.map
>>>>>>files, and have
>>>>>>hit a wall. I can't seem to figure out how to do a
>>>>>>one-to-one join. I
>>>>>>keep getting the error messages:
>>>>>>msDrawMap(): Image handling error. Failed to draw
>>layer
>>>>>>named 'states'.
>>>>>>msDBFGetItemIndex(): DBASE file error. Item
>>>>'Disfchmt_R'
>>>>>>not found.
>>>>>>I triple checked the .dbf I'm trying to join, and
>>that
>>>>is
>>>>>>the name of
>>>>>>the attribute field I want to access.
>>>>>>Below is my short bit of code so far. I would be so
>>>>>>thankful if anyone
>>>>>>could guide me in the right direction on how to get
>>it
>>>>to
>>>>>>work.
>>>>>>~Becky
>>>>>>MAP
>>>>>> IMAGETYPE PNG24
>>>>>> EXTENT -2153561.581984760 4847233.565621579
>>>>>>2641846.236294404
>>>>>>-6178805.564371807
>>>>>> SIZE 800 500
>>>>>> SHAPEPATH "data"
>>>>>> IMAGECOLOR 203 201 226
>>>>>> PROJECTION
>>>>>> "proj=laea"
>>>>>> "ellps=clrk66"
>>>>>> "lat_0=45"
>>>>>> "lon_0=-100"
>>>>>> END
>>>>>> # Start of LAYER DEFINITIONS
>>>>>> LAYER # States polygon layer begins here
>>>>>> NAME states
>>>>>> DATA STATES
>>>>>> STATUS DEFAULT
>>>>>> TYPE POLYGON
>>>>>> PROJECTION
>>>>>> "init=epsg:4326"
>>>>>> END
>>>>>> JOIN
>>>>>> NAME "Felon Ethnicity"
>>>>>> TABLE "data/FelonEthnicity.dbf"
>>>>>> FROM "STATE_NAME"
>>>>>> TO "STATE"
>>>>>> TYPE single
>>>>>> END #Join
>>>>>> CLASS
>>>>>> NAME "<21%"
>>>>>> COLOR 242 240 247
>>>>>> OUTLINECOLOR 200 200 200
>>>>>> COLOR 232 232 232
>>>>>> OUTLINECOLOR 32 32 32
>>>>>> END
>>>>>> END # States polygon layer ends here
>>>>>> # End of LAYER DEFINITIONS
>>>>>>END # end of map file/object
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
