[Mapserver-users] Reprojecting Problem
Ed McNierney
ed at topozone.com
Thu Jul 15 09:26:43 EDT 2004
This is a multi-part message in MIME format.
------_=_NextPart_001_01C46A6F.5F5E2ADC
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
Kevin -
=20
Then stick to that problem until it's fixed! Things to think about:
=20
1. Do you have the extents of the shoreline wrong? Could it be in the
wrong place?
2. Are you SURE you've got the source projection correct?
3. Set the EXTENT of the requested map to be HUGE, so the shoreline
should be visible no matter where it is.
4. Are you sure you have the datum shift files installed in PROJ? Can
you use the command-line PROJ to do a datum shift correctly?
=20
Please keep replying on the list - I may not have time to keep helping,
and others may think of solutions that I miss.
=20
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242=20
From: kgrootendorst at baird.com [mailto:kgrootendorst at baird.com]=20
Sent: Thursday, July 15, 2004 9:01 AM
To: Ed McNierney
Subject: RE: [Mapserver-users] Reprojecting Problem
Ed,=20
The shoreline does not display when trying to reproject from UTM to LCC.
Kevin=20
"Ed McNierney" <ed at topozone.com>=20
07/14/2004 06:20 PM=20
To
<kgrootendorst at baird.com>=20
cc
<mapserver-users at lists.gis.umn.edu>=20
Subject
=09
Kevin -=20
=20
Thanks - it's good to have that confirmed. The next thing I'd do is
restore the PROJECTION and EXTENT to the MAP file so you display ONLY
the shoreline layer, but reprojected to your LCC projection. You also
don't need the "+no_defs" before the "no_defs" in your projection
definition.=20
=20
- Ed=20
Sent: Wednesday, July 14, 2004 5:10 PM
To: Ed McNierney
Cc: mapserver-users at lists.gis.umn.edu
Ed,=20
I did what you suggested, and the shoreline displayed fine in UTM
extents.=20
Kevin
07/14/2004 01:34 PM=20
To
cc
Subject
=09
Kevin -=20
=20
Thanks; I'd suggest next modifying the MAP file to comment out ALL
PROJECTION blocks, and turn off all the layers except the shore line.
You'll need to adjust the EXTENT to have the right values in UTM
coordinates, but this should get you a UTM-output map of the shoreline.
I'm trying to make sure that all your data is valid and is really in the
projection you think it is.=20
=20
- Ed=20
Ed McNierney
ed at topozone.com
(978) 251-4242=20
Sent: Wednesday, July 14, 2004 12:45 PM
To: Ed McNierney
Ed,=20
Yes, it supports proj, and the other layers look okay. These other
layers are in the same projection as the map object.=20
The custom projection I'm using in the map is as follows:=20
# Custom Lambert Conformal Conic=20
<50000> +proj=3Dlcc +lat_1=3D49 +lat_2=3D63 +lat_0=3D49 +lon_0=3D-91.86
+x_0=3D6200000 +y_0=3D2958000 +ellps=3DGRS80 +datum=3DNAD83 +units=3Dm =
+no_defs
no_defs <>=20
I've had no problems using this projection with ArcMap.=20
I'm running the following:=20
Mapserver 4.2=20
PHP 4.3.4=20
Win2000=20
Kevin
07/14/2004 10:50 AM=20
To
<kgrootendorst at baird.com>, <mapserver-users at lists.gis.umn.edu>=20
cc
Subject
[SPAM] - RE: [Mapserver-users] Reprojecting Problem - Email found in
subject
=09
Kevin -=20
Do all your other layers look OK in the output map? BTW, I think it's
good practice to include a PROJECTION block in ALL layers if they're not
all the same projection.=20
If you run "mapserv -v" from the command line, does it show
"SUPPORTS=3DPROJ"?=20
- Ed=20
Ed McNierney
ed at topozone.com
(978) 251-4242=20
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
Sent: Wednesday, July 14, 2004 10:17 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Reprojecting Problem
Hello,=20
I'm having trouble with reprojecting in Mapserver. I'm trying to
reproject my 'shoreline' file (defined as UTM 17N NAD83) to my map,
which has been defined with a customized lambert conformal conic
projection.=20
Based on my Mapfile below, can anyone see why my data will not
re-project? Am I missing something? I thought everything looked okay,
but obviously something must be wrong!=20
MAP=20
NAME "test"=20
STATUS ON=20
EXTENT 6000000 600000 9000000 1500000=20
#Minx Miny Maxx Maxy=20
SIZE 600 400=20
SHAPEPATH "./Data"=20
SYMBOLSET "./etc/symbols.sym"=20
FONTSET "./etc/fonts.txt"=20
IMAGETYPE PNG=20
UNITS METERS=20
WEB=20
IMAGEPATH "C:/Program Files/Apache Group/Apache2/htdocs/ms_tmp/"=20
IMAGEURL "/ms_tmp/"=20
END=20
PROJECTION=20
"init=3Depsg:50000" #Custom LCC Projection - defined in proj/epsg=20
END=20
LEGEND=20
STATUS ON=20
IMAGECOLOR 255 255 255=20
POSITION LL=20
KEYSIZE 18 12=20
KEYSPACING 5 5=20
END=20
SCALEBAR=20
STATUS ON=20
OUTLINECOLOR 0 0 0=20
BACKGROUNDCOLOR 0 0 0=20
UNITS KILOMETERS=20
INTERVALS 5=20
SIZE 150 10=20
STYLE 0=20
POSITION LL=20
END=20
LAYER=20
NAME "ec_counties_LCC"=20
STATUS ON=20
DATA "./ec_counties_LCC"=20
TYPE POLYGON=20
UNITS METERS=20
SIZEUNITS PIXELS=20
CLASS=20
TEMPLATE "ttt"=20
STYLE=20
SYMBOL 0=20
COLOR 211 255 190=20
END=20
END=20
END=20
LAYER=20
NAME "New_York_County"=20
STATUS ON=20
DATA "./New_York_County"=20
TYPE POLYGON=20
#LABELITEM "NAME"=20
CLASS=20
#NAME "New_York_County"=20
TEMPLATE "ttt"=20
LABEL=20
TYPE bitmap=20
FONT "arial"=20
SIZE small=20
POSITION CC=20
COLOR 255 0 0=20
END=20
STYLE=20
SYMBOL 0=20
COLOR 252 241 207=20
END=20
END=20
END=20
LAYER=20
NAME "Shoreline_UTM"=20
STATUS ON=20
DATA "./Shoreline_UTM"=20
TYPE LINE=20
UNITS METERS=20
SIZEUNITS PIXELS=20
PROJECTION=20
"init=3Depsg:26917" #UTM Zone 17N NAD 83=20
END=20
CLASS=20
STYLE=20
SYMBOL 0=20
COLOR 0 0 255=20
END=20
END=20
END=20
END=20
Thanks.=20
Kevin=20
Content-Type: text/html;
charset="us-ascii"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Dus-ascii">
<META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR></HEAD>
<BODY>
<DIV dir=3Dltr align=3Dleft><SPAN class=3D537562213-15072004><FONT =
face=3DArial=20
color=3D#0000ff size=3D2>Kevin -</FONT></SPAN></DIV>
face=3DArial=20
color=3D#0000ff size=3D2></FONT></SPAN> </DIV>
face=3DArial=20
color=3D#0000ff size=3D2>Then stick to that problem until it's =
fixed! Things=20
to think about:</FONT></SPAN></DIV>
face=3DArial=20
face=3DArial=20
color=3D#0000ff size=3D2>1. Do you have the extents of the shoreline =
wrong? =20
Could it be in the wrong place?</FONT></SPAN></DIV>
face=3DArial=20
color=3D#0000ff size=3D2>2. Are you SURE you've got the source =
projection=20
correct?</FONT></SPAN></DIV>
face=3DArial=20
color=3D#0000ff size=3D2>3. Set the EXTENT of the requested map to be =
HUGE, so the=20
shoreline should be visible no matter where it is.</FONT></SPAN></DIV>
face=3DArial=20
color=3D#0000ff size=3D2>4. Are you sure you have the datum shift files =
installed in=20
PROJ? Can you use the command-line PROJ to do a datum shift=20
correctly?</FONT></SPAN></DIV>
face=3DArial=20
face=3DArial=20
color=3D#0000ff size=3D2>Please keep replying on the list - I may not =
have time to=20
keep helping, and others may think of solutions that I =
miss.</FONT></SPAN></DIV>
face=3DArial=20
<DIV dir=3Dltr align=3Dleft><SPAN =
class=3D537562213-15072004> <FONT=20
face=3DArial color=3D#0000ff size=3D2>- Ed</FONT></SPAN></DIV>
<P><FONT size=3D2>Ed McNierney<BR>President and Chief =
Mapmaker<BR>TopoZone.com /=20
Maps a la carte, Inc.<BR>73 Princeton Street, Suite 305<BR>North =
Chelmsford,=20
MA 01863<BR>ed at topozone.com<BR>(978) 251-4242 =
</FONT></P></SPAN></DIV><BR>
<DIV class=3DOutlookMessageHeader lang=3Den-us dir=3Dltr align=3Dleft>
<HR tabIndex=3D-1>
<FONT face=3DTahoma size=3D2><B>From:</B> kgrootendorst at baird.com=20
[mailto:kgrootendorst at baird.com] <BR><B>Sent:</B> Thursday, July 15, =
2004 9:01=20
AM<BR><B>To:</B> Ed McNierney<BR><B>Subject:</B> RE: [Mapserver-users]=20
Reprojecting Problem<BR></FONT><BR></DIV>
<DIV></DIV><BR><FONT face=3Dsans-serif size=3D2>Ed,</FONT> <BR><FONT =
face=3Dsans-serif=20
size=3D2>The shoreline does not display when trying to reproject from =
UTM to=20
LCC.<BR></FONT><BR><FONT face=3Dsans-serif size=3D2>Kevin</FONT>=20
<P><BR><BR><BR>
<TABLE width=3D"100%">
<TBODY>
<TR vAlign=3Dtop>
<TD width=3D"40%"><FONT face=3Dsans-serif size=3D1><B>"Ed McNierney" =
<ed at topozone.com></B> </FONT>
<P><FONT face=3Dsans-serif size=3D1>07/14/2004 06:20 PM</FONT> =
</P>
<TD width=3D"59%">
<TBODY>
<TR>
<TD>
<DIV align=3Dright><FONT face=3Dsans-serif =
size=3D1>To</FONT></DIV>
<TD vAlign=3Dtop><FONT face=3Dsans-serif=20
size=3D1><kgrootendorst at baird.com></FONT>=20
<TR>
<TD>
size=3D1>cc</FONT></DIV>
size=3D1><mapserver-users at lists.gis.umn.edu></FONT>=20
<TR>
<TD>
size=3D1>Subject</FONT></DIV>
<TD vAlign=3Dtop><FONT face=3Dsans-serif size=3D1>RE: =
Reprojecting Problem</FONT></TR></TBODY></TABLE><BR>
<TABLE>
<TBODY>
<TR vAlign=3Dtop>
<TD>
<TD></TR></TBODY></TABLE><BR></TR></TBODY></TABLE><BR><BR><BR><FONT =
face=3DArial=20
color=3Dblue size=3D2>Kevin -</FONT> <BR><FONT size=3D3> </FONT> =
<BR><FONT=20
face=3DArial color=3Dblue size=3D2>Thanks - it's good to have that =
confirmed.=20
The next thing I'd do is restore the PROJECTION and EXTENT to the =
MAP file=20
so you display ONLY the shoreline layer, but reprojected to your LCC =
projection.=20
You also don't need the "+no_defs" before the "no_defs" in your =
projection=20
definition.</FONT> <BR><FONT size=3D3> </FONT> <BR><FONT =
size=3D3> =20
</FONT><FONT face=3DArial color=3Dblue size=3D2>- Ed</FONT> <BR><BR>
<HR>
[mailto:kgrootendorst at baird.com] <B><BR>Sent:</B> Wednesday, July 14, =
2004 5:10=20
PM<B><BR>To:</B> Ed McNierney<B><BR>Cc:</B>=20
mapserver-users at lists.gis.umn.edu<B><BR>Subject:</B> RE: =
Reprojecting Problem</FONT><FONT size=3D3><BR></FONT><BR><FONT =
size=3D2><BR>Ed,</FONT><FONT size=3D3> </FONT><FONT face=3Dsans-serif =
size=3D2><BR>I did=20
what you suggested, and the shoreline displayed fine in UTM =
extents.</FONT><FONT=20
size=3D3> <BR></FONT><FONT face=3Dsans-serif =
size=3D2><BR>Kevin</FONT><FONT=20
size=3D3><BR><BR><BR></FONT>
<TBODY>
<TR vAlign=3Dtop>
<TD width=3D"46%"><FONT face=3Dsans-serif size=3D1><B>"Ed McNierney" =
<P><FONT face=3Dsans-serif size=3D1>07/14/2004 01:34 =
PM</FONT><FONT size=3D3>=20
</FONT></P>
<TD width=3D"53%"><BR>
<TBODY>
<TR>
<TD width=3D"15%">
<TD vAlign=3Dtop width=3D"84%"><FONT face=3Dsans-serif=20
size=3D1><kgrootendorst at baird.com></FONT><FONT =
size=3D3> </FONT>
<TR>
<TD>
size=3D1><mapserver-users at lists.gis.umn.edu></FONT><FONT size=3D3> =
</FONT>
<TR>
<TD>
Reprojecting Problem</FONT></TR></TBODY></TABLE><BR><BR>
<TBODY>
<TR vAlign=3Dtop>
<TD width=3D"49%">
<TD =
width=3D"50%"></TR></TBODY></TABLE><BR></TR></TBODY></TABLE><BR><FONT=20
size=3D3><BR><BR></FONT><FONT face=3DArial color=3Dblue =
size=3D2><BR>Kevin -</FONT><FONT=20
size=3D3> <BR> </FONT><FONT face=3DArial color=3Dblue =
size=3D2><BR>Thanks; I'd=20
suggest next modifying the MAP file to comment out ALL PROJECTION =
blocks, and=20
turn off all the layers except the shore line. You'll need to =
adjust the=20
EXTENT to have the right values in UTM coordinates, but this should get =
you a=20
UTM-output map of the shoreline. I'm trying to make sure that all =
your=20
data is valid and is really in the projection you think it =
is.</FONT><FONT=20
size=3D3> <BR> <BR> </FONT><FONT face=3DArial =
color=3Dblue size=3D2>-=20
Ed</FONT><FONT size=3D3> </FONT>
Chelmsford, MA=20
01863<BR>ed at topozone.com<BR>(978) 251-4242 </FONT>
<P><FONT size=3D3><BR></FONT>
<HR>
2004 12:45=20
Reprojecting Problem</FONT><FONT size=3D3><BR></FONT><FONT =
size=3D2><BR><BR>Ed,</FONT><FONT size=3D3> </FONT><FONT =
size=3D2><BR>Yes, it supports proj, and the other layers look okay. =
These=20
other layers are in the same projection as the map object.</FONT><FONT =
size=3D3>=20
</FONT><FONT face=3Dsans-serif size=3D2><BR>The custom projection I'm =
using in the=20
map is as follows:</FONT><FONT size=3D3> </FONT><FONT face=3Dsans-serif =
size=3D2><BR>#=20
Custom Lambert Conformal Conic</FONT><FONT size=3D3> </FONT><FONT =
size=3D2><BR><50000> +proj=3Dlcc +lat_1=3D49 +lat_2=3D63 =
+lat_0=3D49 +lon_0=3D-91.86=20
+no_defs=20
no_defs <></FONT><FONT size=3D3> </FONT><FONT =
size=3D2><BR>I've had no problems using this projection with =
ArcMap.</FONT><FONT=20
size=3D3> </FONT><FONT face=3Dsans-serif size=3D2><BR><BR>I'm running =
the=20
following:</FONT><FONT size=3D3> </FONT><FONT face=3Dsans-serif =
size=3D2><BR>Mapserver=20
4.2</FONT><FONT size=3D3> </FONT><FONT face=3Dsans-serif =
size=3D2><BR>PHP=20
4.3.4</FONT><FONT size=3D3> </FONT><FONT face=3Dsans-serif=20
size=3D2><BR>Win2000</FONT><FONT size=3D3> </FONT><FONT =
size=3D2><BR><BR>Kevin</FONT><FONT size=3D3><BR><BR><BR></FONT>
<TBODY>
<TR vAlign=3Dtop>
<TD width=3D"34%"><FONT face=3Dsans-serif size=3D1><B>"Ed McNierney" =
<P><FONT face=3Dsans-serif size=3D1>07/14/2004 10:50 =
AM</FONT><FONT size=3D3>=20
</FONT></P>
<TD width=3D"65%"><BR>
<TBODY>
<TR>
<TD width=3D"13%">
<TD vAlign=3Dtop width=3D"86%"><FONT face=3Dsans-serif=20
size=3D1><kgrootendorst at baird.com>,=20
<mapserver-users at lists.gis.umn.edu></FONT><FONT =
size=3D3>=20
</FONT>
<TR>
<TD>
<TD vAlign=3Dtop>
<TR>
<TD>
<TD vAlign=3Dtop><FONT face=3Dsans-serif size=3D1>[SPAM] - RE: =
[Mapserver-users] Reprojecting Problem - Email found in=20
subject</FONT></TR></TBODY></TABLE><BR><FONT =
<TBODY>
<TR vAlign=3Dtop>
<TD width=3D"49%">
<TD =
size=3D2><BR><BR>Kevin=20
-</FONT><FONT size=3D3> <BR></FONT><FONT face=3DArial color=3Dblue =
size=3D2><BR>Do all=20
your other layers look OK in the output map? BTW, I think it's =
good=20
practice to include a PROJECTION block in ALL layers if they're not all =
the same=20
projection.</FONT><FONT size=3D3> <BR></FONT><FONT face=3DArial =
color=3Dblue=20
size=3D2><BR>If you run "mapserv -v" from the command line, does it show =
"SUPPORTS=3DPROJ"?</FONT><FONT size=3D3> <BR></FONT><FONT face=3DArial =
color=3Dblue=20
size=3D2><BR> - Ed</FONT><FONT size=3D3> </FONT>
<P><FONT face=3DArial color=3Dblue size=3D2>Ed McNierney<BR>President =
and Chief=20
Mapmaker<BR>TopoZone.com / Maps a la carte, Inc.<BR>73 Princeton Street, =
Suite=20
305<BR>North Chelmsford, MA 01863<BR>ed at topozone.com<BR>(978) =
251-4242=20
</FONT>
<HR>
<FONT face=3DTahoma size=3D2><B>From:</B> =
mapserver-users-admin at lists.gis.umn.edu=20
[mailto:mapserver-users-admin at lists.gis.umn.edu] <B>On Behalf Of=20
</B>kgrootendorst at baird.com<B><BR>Sent:</B> Wednesday, July 14, 2004 =
10:17=20
AM<B><BR>To:</B> mapserver-users at lists.gis.umn.edu<B><BR>Subject:</B>=20
[Mapserver-users] Reprojecting Problem</FONT><FONT face=3Dsans-serif=20
size=3D2><BR><BR><BR>Hello,</FONT><FONT size=3D3> </FONT><FONT =
size=3D2><BR>I'm having trouble with reprojecting in Mapserver. =
I'm trying=20
to reproject my 'shoreline' file (defined as UTM 17N NAD83) to my map, =
which has=20
been defined with a customized lambert conformal conic =
projection.</FONT><FONT=20
size=3D3> </FONT><FONT face=3Dsans-serif size=3D2><BR>Based on my =
Mapfile below, can=20
anyone see why my data will not re-project? Am I missing =
something?=20
I thought everything looked okay, but obviously something must be=20
wrong!</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New"=20
size=3D2><BR><BR><BR>MAP</FONT><FONT size=3D3> </FONT><FONT =
size=3D2><BR>NAME "test"</FONT><FONT size=3D3> </FONT><FONT =
size=3D2><BR>STATUS ON</FONT><FONT size=3D3> </FONT><FONT =
size=3D2><BR>EXTENT 6000000 600000 9000000 1500000 <BR>#Minx Miny Maxx=20
Maxy</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New" =
size=3D2><BR>SIZE 600 400=20
<BR>SHAPEPATH "./Data"</FONT><FONT size=3D3> </FONT><FONT =
size=3D2><BR>SYMBOLSET "./etc/symbols.sym"</FONT><FONT size=3D3> =
</FONT><FONT=20
face=3D"Courier New" size=3D2><BR>FONTSET "./etc/fonts.txt"</FONT><FONT =
size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR>IMAGETYPE PNG</FONT><FONT =
size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR>UNITS METERS</FONT><FONT =
size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR>WEB</FONT><FONT size=3D3> =
</FONT><FONT=20
face=3D"Courier New" size=3D2><BR> IMAGEPATH "C:/Program =
Files/Apache=20
Group/Apache2/htdocs/ms_tmp/"</FONT><FONT size=3D3> </FONT><FONT=20
face=3D"Courier New" size=3D2><BR> IMAGEURL "/ms_tmp/"</FONT><FONT =
size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR>END</FONT><FONT size=3D3> =
</FONT><FONT=20
face=3D"Courier New" size=3D2><BR>PROJECTION</FONT><FONT size=3D3> =
</FONT><FONT=20
face=3D"Courier New" size=3D2><BR> "init=3Depsg:50000" =
#Custom LCC=20
Projection - defined in proj/epsg</FONT><FONT size=3D3> </FONT><FONT=20
face=3D"Courier New" size=3D2><BR>END</FONT><FONT size=3D3> </FONT><FONT =
face=3D"Courier New" size=3D2><BR>LEGEND</FONT><FONT size=3D3> =
</FONT><FONT=20
face=3D"Courier New" size=3D2><BR> STATUS ON</FONT><FONT size=3D3> =
</FONT><FONT=20
face=3D"Courier New" size=3D2><BR> IMAGECOLOR 255 255 =
255</FONT><FONT size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR> POSITION =
LL</FONT><FONT size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR> KEYSIZE 18 12=20
<BR> KEYSPACING 5 5 <BR>END</FONT><FONT size=3D3> </FONT><FONT=20
face=3D"Courier New" size=3D2><BR>SCALEBAR</FONT><FONT size=3D3> =
</FONT><FONT=20
</FONT><FONT=20
face=3D"Courier New" size=3D2><BR> COLOR 255 255 255</FONT><FONT =
size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR> OUTLINECOLOR 0 0 =
0</FONT><FONT=20
size=3D2><BR> BACKGROUNDCOLOR 0 0=20
0</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New"=20
size=3D2><BR> IMAGECOLOR 255 255 255</FONT><FONT size=3D3> =
</FONT><FONT=20
face=3D"Courier New" size=3D2><BR> UNITS KILOMETERS</FONT><FONT =
size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR> INTERVALS =
</FONT><FONT face=3D"Courier New" size=3D2><BR> SIZE 150 10 =
<BR> STYLE=20
0</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New" =
size=3D2><BR> POSITION=20
LL</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New"=20
size=3D2><BR>END</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New" =
size=3D2><BR>LAYER</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier =
New"=20
size=3D2><BR> NAME "ec_counties_LCC"</FONT><FONT size=3D3> =
</FONT><FONT=20
</FONT><FONT=20
face=3D"Courier New" size=3D2><BR> DATA =
"./ec_counties_LCC"</FONT><FONT size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR> TYPE =
POLYGON</FONT><FONT=20
size=3D3> </FONT><FONT face=3D"Courier New" size=3D2><BR> UNITS=20
METERS</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New"=20
size=3D2><BR> SIZEUNITS PIXELS</FONT><FONT size=3D3> </FONT><FONT=20
face=3D"Courier New" size=3D2><BR> CLASS</FONT><FONT size=3D3> =
</FONT><FONT=20
face=3D"Courier New" size=3D2><BR> NAME =
"ec_counties_LCC"</FONT><FONT=20
size=3D3> </FONT><FONT face=3D"Courier New" size=3D2><BR> =
TEMPLATE=20
"ttt"</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New" =
size=3D2><BR> =20
STYLE</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New"=20
size=3D2><BR> SYMBOL 0</FONT><FONT size=3D3> =
</FONT><FONT=20
face=3D"Courier New" size=3D2><BR> COLOR 211 255 =
190</FONT><FONT=20
size=3D3> </FONT><FONT face=3D"Courier New" size=3D2><BR> =20
OUTLINECOLOR 0 0 0</FONT><FONT size=3D3> </FONT><FONT =
size=3D2><BR> END</FONT><FONT size=3D3> </FONT><FONT =
New"=20
size=3D2><BR> NAME "New_York_County"</FONT><FONT size=3D3> =
</FONT><FONT=20
</FONT><FONT=20
"./New_York_County"</FONT><FONT size=3D3>=20
size=3D2><BR> #LABELITEM=20
"NAME"</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New"=20
size=3D2><BR> CLASS</FONT><FONT size=3D3> </FONT><FONT =
size=3D2><BR> #NAME "New_York_County"</FONT><FONT size=3D3> =
</FONT><FONT=20
face=3D"Courier New" size=3D2><BR> TEMPLATE =
"ttt"</FONT><FONT size=3D3>=20
LABEL</FONT><FONT=20
TYPE=20
bitmap</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New" =
size=3D2><BR> =20
FONT "arial"</FONT><FONT size=3D3> </FONT><FONT =
size=3D2><BR> SIZE small</FONT><FONT size=3D3> =
</FONT><FONT=20
CC</FONT><FONT=20
COLOR 255=20
0 0</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New" =
size=3D2><BR> =20
size=3D2><BR> =20
</FONT><FONT=20
face=3D"Courier New" size=3D2><BR> COLOR 252 241 =
207</FONT><FONT=20
New"=20
size=3D2><BR> NAME "Shoreline_UTM"</FONT><FONT size=3D3> =
</FONT><FONT=20
</FONT><FONT=20
"./Shoreline_UTM"</FONT><FONT size=3D3>=20
LINE</FONT><FONT size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR> UNITS =
METERS</FONT><FONT=20
size=3D3> </FONT><FONT face=3D"Courier New" size=3D2><BR> SIZEUNITS =
PIXELS</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New"=20
size=3D2><BR> PROJECTION</FONT><FONT size=3D3> </FONT><FONT =
size=3D2><BR> "init=3Depsg:26917" #UTM =
Zone 17N NAD=20
83</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New"=20
size=3D2><BR> STYLE</FONT><FONT size=3D3> </FONT><FONT=20
face=3D"Courier New" size=3D2><BR> SYMBOL =
0</FONT><FONT size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR> COLOR =
0 0=20
255</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New" =
size=3D2><BR> =20
END</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New"=20
size=3D2><BR>END</FONT><FONT size=3D3> </FONT><FONT face=3Dsans-serif=20
size=3D2><BR><BR>Thanks.</FONT><FONT size=3D3> </FONT><FONT =
size=3D2><BR><BR>Kevin</FONT><FONT size=3D3> </FONT>
<P><FONT face=3DArial color=3D#0000ff size=3D2></FONT></P></BODY></HTML>
------_=_NextPart_001_01C46A6F.5F5E2ADC--
