[Mapserver-users] Reprojecting Problem
    Ed McNierney
    ed at topozone.com
    Thu Jul 15 09:14:32 PDT 2004
This is a multi-part message in MIME format.
------_=_NextPart_001_01C46A86.D0CAB908
Content-Type: text/plain;
	charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
Kevin -
=20
Excellent data - now you're getting somewhere.  If you can see both
shapefiles and they're about correct horizontally, then you're getting
SOME reprojection happening.  So the next thing to check is your
projection definition.
=20
Where did you get this projection definition from?  Are you sure that
the false northing (the +y_0=3D2958000 parameter) is correct?
=20
    - Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242=20
From: kgrootendorst at baird.com [mailto:kgrootendorst at baird.com]=20
Sent: Thursday, July 15, 2004 12:06 PM
To: Ed McNierney
Cc: mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] Reprojecting Problem
Ed,=20
Thanks for your help.  I meant to reply to the list before but hit
'reply' instead of 'reply to all'.....=20
In response to your questions below:=20
1.   The shoreline extents are correct.=20
2.   The source projection is correct.=20
3.   I can see the both the shoreline and the counties shapefile -
however the shoreline draws many km's (1,000's) to the north of the
counties.  Horizontally looks okay - vertically is wrong.=20
4.  I'm assuming I have the datum shift files installed in proj - I'm
using the proj that came with MS 4.2.   I'm not sure how to use the
command line to do a datum shift - do you mean the url?=20
Thanks again.=20
I'm going to triple check my numbers - looks like a vertical shift
somewhere.=20
Kevin
______________________________=20
"Ed McNierney" <ed at topozone.com>=20
07/15/2004 09:26 AM=20
To
<kgrootendorst at baird.com>=20
cc
<mapserver-users at lists.gis.umn.edu>=20
Subject
=09
Kevin -=20
 =20
Then stick to that problem until it's fixed!  Things to think about:=20
 =20
1. Do you have the extents of the shoreline wrong?  Could it be in the
wrong place?=20
2. Are you SURE you've got the source projection correct?=20
3. Set the EXTENT of the requested map to be HUGE, so the shoreline
should be visible no matter where it is.=20
4. Are you sure you have the datum shift files installed in PROJ?  Can
you use the command-line PROJ to do a datum shift correctly?=20
 =20
Please keep replying on the list - I may not have time to keep helping,
and others may think of solutions that I miss.=20
 =20
    - Ed=20
Ed McNierney
ed at topozone.com
(978) 251-4242=20
Sent: Thursday, July 15, 2004 9:01 AM
To: Ed McNierney
Ed,=20
The shoreline does not display when trying to reproject from UTM to LCC.
Kevin=20
07/14/2004 06:20 PM=20
To
cc
Subject
=09
Kevin -=20
=20
Thanks - it's good to have that confirmed.  The next thing I'd do is
restore the PROJECTION and EXTENT to the MAP file so you display ONLY
the shoreline layer, but reprojected to your LCC projection.  You also
don't need the "+no_defs" before the "no_defs" in your projection
definition.=20
=20
   - Ed=20
Sent: Wednesday, July 14, 2004 5:10 PM
To: Ed McNierney
Ed,=20
I did what you suggested, and the shoreline displayed fine in UTM
extents.=20
Kevin
07/14/2004 01:34 PM=20
To
cc
Subject
=09
Kevin -=20
Thanks; I'd suggest next modifying the MAP file to comment out ALL
PROJECTION blocks, and turn off all the layers except the shore line.
You'll need to adjust the EXTENT to have the right values in UTM
coordinates, but this should get you a UTM-output map of the shoreline.
I'm trying to make sure that all your data is valid and is really in the
projection you think it is.=20
  - Ed=20
Ed McNierney
ed at topozone.com
(978) 251-4242=20
Sent: Wednesday, July 14, 2004 12:45 PM
To: Ed McNierney
Ed,=20
Yes, it supports proj, and the other layers look okay.  These other
layers are in the same projection as the map object.=20
The custom projection I'm using in the map is as follows:=20
# Custom Lambert Conformal Conic=20
<50000> +proj=3Dlcc +lat_1=3D49 +lat_2=3D63 +lat_0=3D49 +lon_0=3D-91.86
+x_0=3D6200000 +y_0=3D2958000 +ellps=3DGRS80 +datum=3DNAD83 +units=3Dm =
+no_defs
no_defs <>=20
I've had no problems using this projection with ArcMap.=20
I'm running the following:=20
Mapserver 4.2=20
PHP 4.3.4=20
Win2000=20
Kevin
07/14/2004 10:50 AM=20
To
<kgrootendorst at baird.com>, <mapserver-users at lists.gis.umn.edu>=20
cc
Subject
[SPAM] - RE: [Mapserver-users] Reprojecting Problem - Email found in
subject
=09
Kevin -=20
Do all your other layers look OK in the output map?  BTW, I think it's
good practice to include a PROJECTION block in ALL layers if they're not
all the same projection.=20
If you run "mapserv -v" from the command line, does it show
"SUPPORTS=3DPROJ"?=20
 - Ed=20
Ed McNierney
ed at topozone.com
(978) 251-4242=20
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
Sent: Wednesday, July 14, 2004 10:17 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Reprojecting Problem
Hello,=20
I'm having trouble with reprojecting in Mapserver.  I'm trying to
reproject my 'shoreline' file (defined as UTM 17N NAD83) to my map,
which has been defined with a customized lambert conformal conic
projection.=20
Based on my Mapfile below, can anyone see why my data will not
re-project?  Am I missing something?  I thought everything looked okay,
but obviously something must be wrong!=20
MAP=20
NAME "test"=20
STATUS ON=20
EXTENT 6000000 600000 9000000 1500000=20
#Minx Miny Maxx Maxy=20
SIZE 600 400=20
SHAPEPATH "./Data"=20
SYMBOLSET "./etc/symbols.sym"=20
FONTSET "./etc/fonts.txt"=20
IMAGETYPE PNG=20
UNITS METERS=20
WEB=20
IMAGEPATH "C:/Program Files/Apache Group/Apache2/htdocs/ms_tmp/"=20
IMAGEURL "/ms_tmp/"=20
END=20
PROJECTION=20
"init=3Depsg:50000"     #Custom LCC Projection - defined in proj/epsg=20
END=20
LEGEND=20
STATUS ON=20
IMAGECOLOR 255 255 255=20
POSITION LL=20
KEYSIZE 18 12=20
KEYSPACING 5 5=20
END=20
SCALEBAR=20
STATUS ON=20
OUTLINECOLOR 0 0 0=20
BACKGROUNDCOLOR 0 0 0=20
UNITS KILOMETERS=20
INTERVALS 5=20
SIZE 150 10=20
STYLE 0=20
POSITION LL=20
END=20
LAYER=20
NAME "ec_counties_LCC"=20
STATUS ON=20
DATA "./ec_counties_LCC"=20
TYPE POLYGON=20
UNITS METERS=20
SIZEUNITS PIXELS=20
CLASS=20
  TEMPLATE "ttt"=20
  STYLE=20
    SYMBOL 0=20
    COLOR 211 255 190=20
  END=20
END=20
END=20
LAYER=20
NAME "New_York_County"=20
STATUS ON=20
DATA "./New_York_County"=20
TYPE POLYGON=20
#LABELITEM "NAME"=20
CLASS=20
  #NAME "New_York_County"=20
  TEMPLATE "ttt"=20
  LABEL=20
    TYPE bitmap=20
    FONT "arial"=20
    SIZE small=20
    POSITION CC=20
    COLOR 255 0 0=20
  END=20
  STYLE=20
    SYMBOL 0=20
    COLOR 252 241 207=20
  END=20
END=20
END=20
LAYER=20
NAME "Shoreline_UTM"=20
STATUS ON=20
DATA "./Shoreline_UTM"=20
TYPE LINE=20
UNITS METERS=20
SIZEUNITS PIXELS=20
PROJECTION=20
  "init=3Depsg:26917"      #UTM Zone 17N NAD 83=20
END=20
CLASS=20
  STYLE=20
    SYMBOL 0=20
    COLOR 0 0 255=20
  END=20
END=20
END=20
END=20
Thanks.=20
Kevin=20
Content-Type: text/html;
	charset="us-ascii"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Dus-ascii">
<META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR></HEAD>
<BODY>
<DIV dir=3Dltr align=3Dleft><SPAN class=3D652060916-15072004><FONT =
face=3DArial=20
size=3D2>Kevin -</FONT></SPAN></DIV>
face=3DArial=20
size=3D2></FONT></SPAN> </DIV>
face=3DArial=20
size=3D2>Excellent data - now you're getting somewhere.  If you can =
see both=20
shapefiles and they're about correct horizontally, then you're getting =
SOME=20
reprojection happening.  So the next thing to check is your =
projection=20
definition.</FONT></SPAN></DIV>
face=3DArial=20
face=3DArial=20
size=3D2>Where did you get this projection definition from?  Are =
you sure=20
that the false northing (the <FONT face=3D"Lucida Sans =
Unicode">+y_0=3D2958000=20
parameter) is correct?</FONT></FONT></SPAN></DIV>
<DIV dir=3Dltr align=3Dleft><SPAN class=3D652060916-15072004><FONT=20
face=3D"Lucida Sans Unicode" size=3D2></FONT></SPAN> </DIV>
<DIV dir=3Dltr align=3Dleft><SPAN =
class=3D652060916-15072004>    <FONT=20
face=3D"Lucida Sans Unicode" size=3D2>- Ed</FONT></SPAN></DIV>
<P><FONT size=3D2>Ed McNierney<BR>President and Chief =
Mapmaker<BR>TopoZone.com /=20
Maps a la carte, Inc.<BR>73 Princeton Street, Suite 305<BR>North =
Chelmsford,=20
MA  01863<BR>ed at topozone.com<BR>(978) 251-4242 =
</FONT></P></SPAN></DIV><BR>
<DIV class=3DOutlookMessageHeader lang=3Den-us dir=3Dltr align=3Dleft>
<HR tabIndex=3D-1>
<FONT face=3DTahoma size=3D2><B>From:</B> kgrootendorst at baird.com=20
[mailto:kgrootendorst at baird.com] <BR><B>Sent:</B> Thursday, July 15, =
2004 12:06=20
PM<BR><B>To:</B> Ed McNierney<BR><B>Cc:</B>=20
mapserver-users at lists.gis.umn.edu<BR><B>Subject:</B> RE: =
[Mapserver-users]=20
Reprojecting Problem<BR></FONT><BR></DIV>
<DIV></DIV><BR><FONT face=3Dsans-serif size=3D2>Ed,</FONT> <BR><FONT =
face=3Dsans-serif=20
size=3D2>Thanks for your help.  I meant to reply to the list before =
but hit=20
'reply' instead of 'reply to all'.....</FONT> <BR><FONT =
size=3D2>In response to your questions below:</FONT> <BR><BR><FONT =
size=3D2>1.   The shoreline extents are correct.</FONT> <BR><FONT=20
face=3Dsans-serif size=3D2>2.   The source projection is =
correct.</FONT>=20
<BR><FONT face=3Dsans-serif size=3D2>3.   I can see the both the =
shoreline and=20
the counties shapefile - however the shoreline draws many km's (1,000's) =
to the=20
north of the counties.  Horizontally looks okay - vertically is=20
wrong.</FONT> <BR><FONT face=3Dsans-serif size=3D2>4.  I'm assuming =
I have the=20
datum shift files installed in proj - I'm using the proj that came with =
MS 4.2.=20
  I'm not sure how to use the command line to do a datum shift - do =
you=20
mean the url?</FONT> <BR><BR><FONT face=3Dsans-serif size=3D2>Thanks =
again.</FONT>=20
<BR><FONT face=3Dsans-serif size=3D2>I'm going to triple check my =
numbers - looks=20
like a vertical shift somewhere.</FONT> <BR><BR><FONT face=3Dsans-serif=20
size=3D2>Kevin</FONT><FONT face=3D"Times New Roman" color=3Dblue=20
size=3D5><BR>______________________________</FONT> <BR><BR><BR>
<TABLE width=3D"100%">
  <TBODY>
  <TR vAlign=3Dtop>
    <TD width=3D"40%"><FONT face=3Dsans-serif size=3D1><B>"Ed McNierney" =
      <ed at topozone.com></B> </FONT>
      <P><FONT face=3Dsans-serif size=3D1>07/15/2004 09:26 AM</FONT> =
</P>
    <TD width=3D"59%">
        <TBODY>
        <TR>
          <TD>
            <DIV align=3Dright><FONT face=3Dsans-serif =
size=3D1>To</FONT></DIV>
          <TD vAlign=3Dtop><FONT face=3Dsans-serif=20
            size=3D1><kgrootendorst at baird.com></FONT>=20
        <TR>
          <TD>
size=3D1>cc</FONT></DIV>
            size=3D1><mapserver-users at lists.gis.umn.edu></FONT>=20
        <TR>
          <TD>
size=3D1>Subject</FONT></DIV>
          <TD vAlign=3Dtop><FONT face=3Dsans-serif size=3D1>RE: =
            Reprojecting Problem</FONT></TR></TBODY></TABLE><BR>
      <TABLE>
        <TBODY>
        <TR vAlign=3Dtop>
          <TD>
<TD></TR></TBODY></TABLE><BR></TR></TBODY></TABLE><BR><BR><BR><FONT =
face=3DArial=20
color=3Dblue size=3D2>Kevin -</FONT> <BR><FONT size=3D3> </FONT> =
<BR><FONT=20
face=3DArial color=3Dblue size=3D2>Then stick to that problem until it's =
fixed!=20
 Things to think about:</FONT> <BR><FONT size=3D3> </FONT> =
<BR><FONT=20
face=3DArial color=3Dblue size=3D2>1. Do you have the extents of the =
shoreline wrong?=20
 Could it be in the wrong place?</FONT> <BR><FONT face=3DArial =
color=3Dblue=20
size=3D2>2. Are you SURE you've got the source projection =
correct?</FONT>=20
<BR><FONT face=3DArial color=3Dblue size=3D2>3. Set the EXTENT of the =
requested map to=20
be HUGE, so the shoreline should be visible no matter where it =
is.</FONT>=20
<BR><FONT face=3DArial color=3Dblue size=3D2>4. Are you sure you have =
the datum shift=20
files installed in PROJ?  Can you use the command-line PROJ to do a =
datum=20
shift correctly?</FONT> <BR><FONT size=3D3> </FONT> <BR><FONT =
face=3DArial=20
color=3Dblue size=3D2>Please keep replying on the list - I may not have =
time to keep=20
helping, and others may think of solutions that I miss.</FONT> <BR><FONT =
size=3D3> </FONT> <BR><FONT size=3D3>    </FONT><FONT =
face=3DArial=20
color=3Dblue size=3D2>- Ed</FONT>=20
Chelmsford, MA=20
 01863<BR>ed at topozone.com<BR>(978) 251-4242 </FONT>
<P><BR>
<HR>
[mailto:kgrootendorst at baird.com] <B><BR>Sent:</B> Thursday, July 15, =
2004 9:01=20
AM<B><BR>To:</B> Ed McNierney<B><BR>Subject:</B> RE: [Mapserver-users]=20
Reprojecting Problem</FONT><FONT size=3D3><BR></FONT><BR><FONT =
size=3D2><BR>Ed,</FONT><FONT size=3D3> </FONT><FONT face=3Dsans-serif =
size=3D2><BR>The=20
shoreline does not display when trying to reproject from UTM to =
LCC.</FONT><FONT=20
size=3D3><BR></FONT><FONT face=3Dsans-serif =
size=3D2><BR>Kevin</FONT><FONT size=3D3>=20
</FONT>
<P><FONT size=3D3><BR><BR></FONT>
  <TBODY>
  <TR vAlign=3Dtop>
    <TD width=3D"46%"><FONT face=3Dsans-serif size=3D1><B>"Ed McNierney" =
      <P><FONT face=3Dsans-serif size=3D1>07/14/2004 06:20 =
PM</FONT><FONT size=3D3>=20
      </FONT></P>
    <TD width=3D"53%"><BR>
        <TBODY>
        <TR>
          <TD width=3D"15%">
          <TD vAlign=3Dtop width=3D"84%"><FONT face=3Dsans-serif=20
            size=3D1><kgrootendorst at baird.com></FONT><FONT =
size=3D3> </FONT>
        <TR>
          <TD>
size=3D1><mapserver-users at lists.gis.umn.edu></FONT><FONT size=3D3> =
            </FONT>
        <TR>
          <TD>
            Reprojecting Problem</FONT></TR></TBODY></TABLE><BR><BR>
        <TBODY>
        <TR vAlign=3Dtop>
          <TD width=3D"49%">
          <TD =
width=3D"50%"></TR></TBODY></TABLE><BR></TR></TBODY></TABLE><BR><FONT=20
size=3D3><BR><BR></FONT><FONT face=3DArial color=3Dblue =
size=3D2><BR>Kevin -</FONT><FONT=20
size=3D3> <BR> </FONT><FONT face=3DArial color=3Dblue =
size=3D2><BR>Thanks - it's=20
good to have that confirmed.  The next thing I'd do is restore the=20
PROJECTION and EXTENT to the MAP file so you display ONLY the shoreline =
layer,=20
but reprojected to your LCC projection.  You also don't need the =
"+no_defs"=20
before the "no_defs" in your projection definition.</FONT><FONT =
size=3D3>=20
<BR> <BR>   </FONT><FONT face=3DArial color=3Dblue =
size=3D2>-=20
Ed</FONT><FONT size=3D3> <BR><BR></FONT>
<HR>
[mailto:kgrootendorst at baird.com] <B><BR>Sent:</B> Wednesday, July 14, =
2004 5:10=20
PM<B><BR>To:</B> Ed McNierney<B><BR>Cc:</B>=20
mapserver-users at lists.gis.umn.edu<B><BR>Subject:</B> RE: =
Reprojecting Problem</FONT><FONT size=3D3><BR></FONT><FONT =
size=3D2><BR><BR>Ed,</FONT><FONT size=3D3> </FONT><FONT =
face=3Dsans-serif size=3D2><BR>I=20
did what you suggested, and the shoreline displayed fine in UTM=20
extents.</FONT><FONT size=3D3> </FONT><FONT face=3Dsans-serif=20
size=3D2><BR><BR>Kevin</FONT><FONT size=3D3><BR><BR></FONT>
  <TBODY>
  <TR vAlign=3Dtop>
      <P><FONT face=3Dsans-serif size=3D1>07/14/2004 01:34 =
      </FONT></P>
        <TBODY>
        <TR>
          <TD width=3D"15%">
size=3D3> </FONT>
        <TR>
          <TD>
            </FONT>
        <TR>
          <TD>
            Reprojecting Problem</FONT></TR></TBODY></TABLE><BR><FONT=20
        <TBODY>
        <TR vAlign=3Dtop>
          <TD width=3D"49%">
          <TD =
size=3D2><BR><BR>Kevin=20
-</FONT><FONT size=3D3> <BR></FONT><FONT face=3DArial color=3Dblue =
size=3D2><BR>Thanks;=20
I'd suggest next modifying the MAP file to comment out ALL PROJECTION =
blocks,=20
and turn off all the layers except the shore line.  You'll need to =
adjust=20
the EXTENT to have the right values in UTM coordinates, but this should =
get you=20
a UTM-output map of the shoreline.  I'm trying to make sure that =
all your=20
data is valid and is really in the projection you think it =
is.</FONT><FONT=20
size=3D3> <BR><BR>  </FONT><FONT face=3DArial color=3Dblue =
size=3D2>-=20
Ed</FONT><FONT size=3D3> </FONT>
Chelmsford, MA=20
<P><FONT size=3D3><BR></FONT>
<HR>
2004 12:45=20
Reprojecting Problem</FONT><FONT face=3Dsans-serif=20
size=3D2><BR><BR><BR>Ed,</FONT><FONT size=3D3> </FONT><FONT =
size=3D2><BR>Yes, it supports proj, and the other layers look okay. =
 These=20
other layers are in the same projection as the map object.</FONT><FONT =
size=3D3>=20
</FONT><FONT face=3Dsans-serif size=3D2><BR>The custom projection I'm =
using in the=20
map is as follows:</FONT><FONT size=3D3> </FONT><FONT face=3Dsans-serif =
size=3D2><BR>#=20
Custom Lambert Conformal Conic</FONT><FONT size=3D3> </FONT><FONT =
size=3D2><BR><50000> +proj=3Dlcc +lat_1=3D49 +lat_2=3D63 =
+lat_0=3D49 +lon_0=3D-91.86=20
+no_defs=20
 no_defs <></FONT><FONT size=3D3> </FONT><FONT =
size=3D2><BR>I've had no problems using this projection with =
ArcMap.</FONT><FONT=20
size=3D3> </FONT><FONT face=3Dsans-serif size=3D2><BR><BR>I'm running =
the=20
following:</FONT><FONT size=3D3> </FONT><FONT face=3Dsans-serif =
size=3D2><BR>Mapserver=20
4.2</FONT><FONT size=3D3> </FONT><FONT face=3Dsans-serif =
size=3D2><BR>PHP=20
4.3.4</FONT><FONT size=3D3> </FONT><FONT face=3Dsans-serif=20
size=3D2><BR>Win2000</FONT><FONT size=3D3> </FONT><FONT =
  <TBODY>
  <TR vAlign=3Dtop>
    <TD width=3D"34%"><FONT face=3Dsans-serif size=3D1><B>"Ed McNierney" =
      <P><FONT face=3Dsans-serif size=3D1>07/14/2004 10:50 =
AM</FONT><FONT size=3D3>=20
      </FONT></P>
    <TD width=3D"65%"><BR>
        <TBODY>
        <TR>
          <TD width=3D"13%">
          <TD vAlign=3Dtop width=3D"86%"><FONT face=3Dsans-serif=20
            size=3D1><kgrootendorst at baird.com>,=20
            <mapserver-users at lists.gis.umn.edu></FONT><FONT =
size=3D3>=20
</FONT>
        <TR>
          <TD>
          <TD vAlign=3Dtop>
        <TR>
          <TD>
          <TD vAlign=3Dtop><FONT face=3Dsans-serif size=3D1>[SPAM] - RE: =
            [Mapserver-users] Reprojecting Problem - Email found in=20
            subject</FONT></TR></TBODY></TABLE><BR><FONT =
size=3D3><BR><BR></FONT><BR>
        <TBODY>
        <TR vAlign=3Dtop>
          <TD width=3D"49%">
          <TD =
size=3D2><BR><BR><BR>Kevin=20
-</FONT><FONT size=3D3> </FONT><FONT face=3DArial color=3Dblue =
size=3D2><BR><BR>Do all=20
your other layers look OK in the output map?  BTW, I think it's =
good=20
practice to include a PROJECTION block in ALL layers if they're not all =
the same=20
projection.</FONT><FONT size=3D3> </FONT><FONT face=3DArial color=3Dblue =
size=3D2><BR><BR>If you run "mapserv -v" from the command line, does it =
show=20
"SUPPORTS=3DPROJ"?</FONT><FONT size=3D3> </FONT><FONT face=3DArial =
color=3Dblue=20
size=3D2><BR><BR> - Ed</FONT><FONT size=3D3> </FONT>
<P><FONT face=3DArial color=3Dblue size=3D2>Ed McNierney<BR>President =
and Chief=20
Mapmaker<BR>TopoZone.com / Maps a la carte, Inc.<BR>73 Princeton Street, =
Suite=20
305<BR>North Chelmsford, MA  01863<BR>ed at topozone.com<BR>(978) =
251-4242=20
</FONT>
<HR>
<FONT face=3DTahoma size=3D2><B>From:</B> =
mapserver-users-admin at lists.gis.umn.edu=20
[mailto:mapserver-users-admin at lists.gis.umn.edu] <B>On Behalf Of=20
</B>kgrootendorst at baird.com<B><BR>Sent:</B> Wednesday, July 14, 2004 =
10:17=20
AM<B><BR>To:</B> mapserver-users at lists.gis.umn.edu<B><BR>Subject:</B>=20
[Mapserver-users] Reprojecting Problem</FONT><FONT face=3Dsans-serif=20
size=3D2><BR><BR><BR>Hello,</FONT><FONT size=3D3> </FONT><FONT =
size=3D2><BR>I'm having trouble with reprojecting in Mapserver. =
 I'm trying=20
to reproject my 'shoreline' file (defined as UTM 17N NAD83) to my map, =
which has=20
been defined with a customized lambert conformal conic =
projection.</FONT><FONT=20
size=3D3> </FONT><FONT face=3Dsans-serif size=3D2><BR>Based on my =
Mapfile below, can=20
anyone see why my data will not re-project?  Am I missing =
something?=20
 I thought everything looked okay, but obviously something must be=20
wrong!</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New"=20
size=3D2><BR><BR><BR>MAP</FONT><FONT size=3D3> </FONT><FONT =
size=3D2><BR>NAME "test"</FONT><FONT size=3D3> </FONT><FONT =
size=3D2><BR>STATUS ON</FONT><FONT size=3D3> </FONT><FONT =
size=3D2><BR>EXTENT 6000000 600000 9000000 1500000 <BR>#Minx Miny Maxx=20
Maxy</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New" =
size=3D2><BR>SIZE 600 400=20
<BR>SHAPEPATH "./Data"</FONT><FONT size=3D3> </FONT><FONT =
size=3D2><BR>SYMBOLSET "./etc/symbols.sym"</FONT><FONT size=3D3> =
</FONT><FONT=20
face=3D"Courier New" size=3D2><BR>FONTSET "./etc/fonts.txt"</FONT><FONT =
size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR>IMAGETYPE PNG</FONT><FONT =
size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR>UNITS METERS</FONT><FONT =
size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR>WEB</FONT><FONT size=3D3> =
</FONT><FONT=20
face=3D"Courier New" size=3D2><BR>IMAGEPATH "C:/Program Files/Apache=20
Group/Apache2/htdocs/ms_tmp/"</FONT><FONT size=3D3> </FONT><FONT=20
face=3D"Courier New" size=3D2><BR>IMAGEURL "/ms_tmp/"</FONT><FONT =
size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR>END</FONT><FONT size=3D3> =
</FONT><FONT=20
face=3D"Courier New" size=3D2><BR>PROJECTION</FONT><FONT size=3D3> =
</FONT><FONT=20
face=3D"Courier New" size=3D2><BR>"init=3Depsg:50000"     =
#Custom LCC=20
Projection - defined in proj/epsg</FONT><FONT size=3D3> </FONT><FONT=20
face=3D"Courier New" size=3D2><BR>END</FONT><FONT size=3D3> </FONT><FONT =
face=3D"Courier New" size=3D2><BR>LEGEND</FONT><FONT size=3D3> =
</FONT><FONT=20
face=3D"Courier New" size=3D2><BR>STATUS ON</FONT><FONT size=3D3> =
</FONT><FONT=20
face=3D"Courier New" size=3D2><BR>IMAGECOLOR 255 255 255</FONT><FONT =
size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR>POSITION LL</FONT><FONT =
size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR>KEYSIZE 18 12 =
<BR>KEYSPACING 5 5=20
<BR>END</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New"=20
size=3D2><BR>SCALEBAR</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier =
New"=20
size=3D2><BR>COLOR 255 255 255</FONT><FONT size=3D3> </FONT><FONT =
size=3D2><BR>OUTLINECOLOR 0 0 0</FONT><FONT size=3D3> </FONT><FONT=20
face=3D"Courier New" size=3D2><BR>BACKGROUNDCOLOR 0 0 0</FONT><FONT =
size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR>IMAGECOLOR 255 255 =
255</FONT><FONT=20
size=3D3> </FONT><FONT face=3D"Courier New" size=3D2><BR>UNITS =
KILOMETERS</FONT><FONT=20
size=3D3> </FONT><FONT face=3D"Courier New" size=3D2><BR>INTERVALS =
5</FONT><FONT=20
size=3D3> </FONT><FONT face=3D"Courier New" size=3D2><BR>SIZE 150 10 =
<BR>STYLE=20
0</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New" =
size=3D2><BR>POSITION=20
LL</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New"=20
size=3D2><BR>END</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New" =
size=3D2><BR>LAYER</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier =
New"=20
size=3D2><BR>NAME "ec_counties_LCC"</FONT><FONT size=3D3> </FONT><FONT=20
</FONT><FONT=20
face=3D"Courier New" size=3D2><BR>DATA "./ec_counties_LCC"</FONT><FONT =
size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR>TYPE POLYGON</FONT><FONT =
size=3D3>=20
size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR>SIZEUNITS =
PIXELS</FONT><FONT size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR>CLASS</FONT><FONT =
size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR>  NAME=20
"ec_counties_LCC"</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier =
New"=20
size=3D2><BR>  TEMPLATE "ttt"</FONT><FONT size=3D3> </FONT><FONT=20
face=3D"Courier New" size=3D2><BR>  STYLE</FONT><FONT size=3D3> =
</FONT><FONT=20
face=3D"Courier New" size=3D2><BR>    SYMBOL 0</FONT><FONT =
size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR>    COLOR 211 =
255=20
190</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New" =
size=3D2><BR>   =20
OUTLINECOLOR 0 0 0</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier =
New"=20
size=3D2><BR>  END</FONT><FONT size=3D3> </FONT><FONT =
New"=20
size=3D2><BR>NAME "New_York_County"</FONT><FONT size=3D3> </FONT><FONT=20
</FONT><FONT=20
face=3D"Courier New" size=3D2><BR>DATA "./New_York_County"</FONT><FONT =
size=3D3>=20
size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR>#LABELITEM =
"NAME"</FONT><FONT size=3D3>=20
size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR>  #NAME=20
"New_York_County"</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier =
New"=20
face=3D"Courier New" size=3D2><BR>  LABEL</FONT><FONT size=3D3> =
</FONT><FONT=20
face=3D"Courier New" size=3D2><BR>    TYPE bitmap</FONT><FONT =
size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR>    FONT=20
"arial"</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New" =
size=3D2><BR> =20
  SIZE small</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier =
New"=20
size=3D2><BR>    POSITION CC</FONT><FONT size=3D3> =
</FONT><FONT=20
face=3D"Courier New" size=3D2><BR>    COLOR 255 0 =
0</FONT><FONT size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR>  END</FONT><FONT =
size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR>  STYLE</FONT><FONT =
size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR>    SYMBOL =
0</FONT><FONT=20
size=3D3> </FONT><FONT face=3D"Courier New" size=3D2><BR>    =
COLOR 252 241=20
207</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New" =
size=3D2><BR>   =20
New"=20
New"=20
size=3D2><BR>NAME "Shoreline_UTM"</FONT><FONT size=3D3> </FONT><FONT=20
</FONT><FONT=20
face=3D"Courier New" size=3D2><BR>DATA "./Shoreline_UTM"</FONT><FONT =
size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR>TYPE LINE</FONT><FONT =
size=3D3>=20
size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR>PROJECTION</FONT><FONT =
size=3D3>=20
"init=3Depsg:26917"  =20
   #UTM Zone 17N NAD 83</FONT><FONT size=3D3> </FONT><FONT=20
face=3D"Courier New" size=3D2><BR>CLASS</FONT><FONT size=3D3> =
</FONT><FONT=20
</FONT><FONT=20
size=3D3>=20
</FONT><FONT face=3D"Courier New" size=3D2><BR>    COLOR 0 0=20
255</FONT><FONT size=3D3> </FONT><FONT face=3D"Courier New" =
size=3D2><BR> =20
size=3D2><BR>END</FONT><FONT size=3D3> </FONT><FONT face=3Dsans-serif=20
size=3D2><BR><BR>Thanks.</FONT><FONT size=3D3> </FONT><FONT =
size=3D2><BR><BR>Kevin</FONT><FONT size=3D3> </FONT>
<P></P></BODY></HTML>
------_=_NextPart_001_01C46A86.D0CAB908--
More information about the MapServer-users
