[Mapserver-users] Fw: [Freegis-list] QGIS Windows preview release
Jeff McKenna
jmckenna at dmsolutions.ca
Fri Jul 16 14:16:41 EDT 2004
The "Export as MapServer file" functionality looks promising..however at
this moment it doesn't create a valid mapfile. It's something to follow
for sure.
jeff
Tyler Mitchell wrote:
> Note QGIS, described below, can (among MANY other things) output MapServer
> map files. For those on windows, this release is worth checking out.
> ----- Forwarded by Tyler Mitchell/Lignum on 07/16/2004 09:35 AM -----
> sherman at mrcc.com
> Sent by: freegis-list-bounces at intevation.de
> 07/16/2004 09:24 AM
> To
> freegis-list at intevation.de
> cc
> Fax to
> Subject
> Greetings,
> A preview release of QGIS for Windows is available for download from
> http://qgis.org/downloads.html. The feature set is the same as QGIS 0.4
> (see the release notes for 0.4 for more information). Some plugins are
> not included and there are likely bugs.
> This version includes PostgreSQL client support. You can connect to
> a PostGIS enabled PostgreSQL database to view data.
> Plugins included in this preview are:
> * Delimited text
> * Copyright
> * North arrow
> * Scale bar
> * Grid maker
> There are known issues with the North arrow and Copyright
> plugins.
> Stability will be improved by 0.5 final. If you give this release a try,
> please help us out by reporting bugs at
> http://sourceforge.net/tracker/?group_id=55820&atid=478378. Bugs should
> be filed under the group "Windows Version".
> To install, just unzip the distribution file and then execute the
> qgis.exe binary. No other installation is required.
> -gary
> Gary Sherman
> http://qgis.org
> Freegis-list mailing list
> Freegis-list at intevation.de
> https://intevation.de/mailman/listinfo/freegis-list
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
