[Mapserver-users] Fw: [Freegis-list] QGIS Windows preview release
Gerry Creager N5JXS
gerry.creager at tamu.edu
Sat Jul 17 13:25:06 EDT 2004
It creates a file that's close enough to valid as to be editted in a few
minutes if you've ever created a mapfile in the past.
Qgis ROCKS!
gerry
Jeff McKenna wrote:
> The "Export as MapServer file" functionality looks promising..however at
> this moment it doesn't create a valid mapfile. It's something to follow
> for sure.
> jeff
> Tyler Mitchell wrote:
>> Note QGIS, described below, can (among MANY other things) output
>> MapServer map files. For those on windows, this release is worth
>> checking out.
>> ----- Forwarded by Tyler Mitchell/Lignum on 07/16/2004 09:35 AM -----
>> sherman at mrcc.com Sent by: freegis-list-bounces at intevation.de
>> 07/16/2004 09:24 AM
>> To
>> freegis-list at intevation.de
>> cc
>> Fax to
>> Subject
>> Greetings,
>> A preview release of QGIS for Windows is available for download from
>> http://qgis.org/downloads.html. The feature set is the same as QGIS 0.4
>> (see the release notes for 0.4 for more information). Some plugins are
>> not included and there are likely bugs.
>> This version includes PostgreSQL client support. You can connect to
>> a PostGIS enabled PostgreSQL database to view data.
>> Plugins included in this preview are:
>> * Delimited text
>> * Copyright
>> * North arrow
>> * Scale bar
>> * Grid maker
>> There are known issues with the North arrow and Copyright
>> plugins.
>> Stability will be improved by 0.5 final. If you give this release a try,
>> please help us out by reporting bugs at
>> http://sourceforge.net/tracker/?group_id=55820&atid=478378. Bugs should
>> be filed under the group "Windows Version".
>> To install, just unzip the distribution file and then execute the
>> qgis.exe binary. No other installation is required.
>> -gary
>> Gary Sherman
>> http://qgis.org
>> Freegis-list mailing list
>> Freegis-list at intevation.de
>> https://intevation.de/mailman/listinfo/freegis-list
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Gerry Creager -- gerry.creager at tamu.edu
Network Engineering -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
Page: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
