[Mapserver-users] Color Bug?
David Fawcett
David.Fawcett at state.mn.us
Tue Jul 20 10:41:03 EDT 2004
This is a MIME message. If you are reading this text, you may want to
consider changing to a mail reader or gateway that understands how to
properly handle MIME multipart messages.
--=__Part1435A4EF.0__=
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
Content-Disposition: inline
I have two scale dependent polygon layers that represent counties in MN.
One displays at scales greater than 2,000,000 and the other less than
2,000,000.
I am using a MapServer 4.0 beta binary created in 8/2003 on Win2K.
Here are the two layer definitions:
____________________________________________
LAYER
NAME basemap
STATUS DEFAULT
TYPE POLYGON
DATA score
MINSCALE 2000000
CLASS
OUTLINECOLOR 153 153 153
COLOR 204 204 153
END
END
LAYER
NAME basemap
STATUS DEFAULT
TYPE POLYGON
DATA score
LABELITEM "NAME"
MAXSCALE 2000000
CLASS
OUTLINECOLOR 153 153 153 #An OUTLINECOLOR with no COLOR gives
same effect as old POLYLINE
COLOR 204 204 153
SYMBOL 'dashed1'
LABEL
TYPE TRUETYPE
FONT "arial-bold"
SIZE 10
POSITION cc
MINSIZE 6
MAXSIZE 12
COLOR 181 181 181
SHADOWCOLOR 204 204 204
ANTIALIAS TRUE
PARTIALS FALSE
MINFEATURESIZE 40
END
END
END
_____________________________________________
Both layers have the same COLOR defined, but when the larger scale
layer gets displayed, the color is different, apparently lighter.
I have attached two .gif's to demonstrate the problem. out.gif is a
view at a smaller scale and in.gif is a larger scale view.
Any ideas? Bug or PIBCAK?
Thanks,
David.
David J. Fawcett
MN Office of Environmental Assistance
Content-Type: image/gif; name="out.gif"
Content-Transfer-Encoding: base64
Content-Disposition: attachment; filename="out.gif"
R0lGODdhkAGQAecAAP///8zMmZmZmQAzzP8AMzPMMwAAAMzMzMzMn8zMxczMsszMpczMrMzMv8zM
sMzMuMzMx7KyhRkZE2ZmTJmZkxkZGBkZGX9/Z2ZmWTMzJn9/X29vWhkZFhkZF7KyrLKysn9/e2Zm
T39/Y7KylkxMTExMOZmZirKyi39/b0xMSX9/azMzMzMzK7KyobKyp5mZj5mZcmZmYrKymzMzLjMz
LDMzJ0xMQBMTDrKyrp+fn5mZexkZFLKykDMzL2ZmVkxMOzMzMWZmZpmZhW9vU5mZd2ZmWH9/d/j4
+NLS0uXl5fLy8uvr69jY2Ofn59/f38XFxbi4uKWlpb+/v8zMtczMpB8fH39/f52dnRoaGpeXl3Jy
cj8/P4SEhBwcHBsbG7e3t4ODg3x8fJubm19fX83Nzaenp9nZ2cPDwzk5ORMTE2ZmX1lZWbKynhkZ
FZubg0xMPZmZgRgYGBQUFHt7exUVFRUVEUxMR0xMRWZmXIWFhaysrGlpaV1dXY+Pj05OTpKSkj4+
Pjo6OqGhoZubdNfX17W1taKioh4eHsjIyNPT0ywsLDU1NXV1dTQ0NKurq7q6um9vb729vWxsbMzM
qTExMWZmUoWFYwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACwAAAAAkAGQAUAI/gABCBxI
sKDBgwgTKlzIsKHDhxAjSpxIsaLFixgzatzIsaPHjyBDihzpUUCAkyhTqlwZQADJlzBjypxJs6ZN
iCZZ6tyZ0uXNn0CDCh1K9GNOnkh1+izKtKnTp1BhHk1KVeXSqFizat26dWrVry25iq0poKxZs2PT
NvUK9utVtXA5lm1Lt67dk2zv6t1L96zfv4D98k36Nq5hjXMHK7abd7HjxzsTQ+Zb+LBlhE4MjAFQ
xQBByScjGAgAQwKMCBICiEagenRoAxIklJhMmLbt2yvN4hVsFTfey8Apgh48oPgA3419K1+OMvni
ssGjSxzOXK/z6tgnX1dcWbr3hduz/tcWTz5y4KrhaXf/fpl6+b7v4/eUrzz9b/Y2ddNnvD++/f51
/cfcet65B+CBAQam4ILuCYggeg/ehx8AZ0Vo4WMOwnchhBtWBZeBHYboFnIiIpXhgx/qV+KKVJ0I
lov9wXhgXCCyaGNzN4onY38p7phjjD9W5+N+aqmomm0MJlkjSxGUOGSQLUKZkmFPYuhYARFWKSVP
Wr7X3oE7FiDmmGMC2OWWLJ1JHnBq3tUmkGji9iZ2NRlX3EZztqWlknwaaZ2VceKI5lAGuGRFDpkd
kOghXiDiRGYfPHLIFwYcIFAVZcFhgAeVnmDABSoY8EGnBohKRKWtHZAApx8QsQOn/gcgIFoQKzAg
ghV3cLBAqiflUWkCCexq43VVLvljnsyxl5dosU2QkmitrVSaBBk0qRO0r8U2W5odEisnsiRumN6E
FPZnJ7gm7pUnurexixu5ArkbKJfhQimvbfAOZOy8cva75b205VsQwExWSkEFGMR2WqWiCSCBtQFI
oEMCILwQgsIqlRDDBRJYIIMBCeBQKazAJvAnkv/GKbC++/KLFAEww/xiuykPunK53PV5npRzEvxc
oDfjXPN7PfMMdNA+/yzfm0lz15Kfu/FXHdJND1Y100t3O/XNVVtNX9H+3ejVXC3rRLXRWftLtMs9
2ce1zrzBGbba5XVNs4dIi8t2/oBz743XV2dfaHffdfstKFV56204h2sv7nZISSChBEZMIIFEEniW
jd3gjRfuOODs2WmnvoIvHiXhez/O9W2iF8e36emizrbqqx+oQLAtwT5eznBrjl6FX4Neu4W9+y4i
2EIi+F/QQmepO710L8d57sJTDfD0Vcks/bebKw8W8+B/ZxJ0DREY/vnoh7+n+em37z6NkLH//vz0
R6Wm/PXnrz9QbeK///8AJMm6ApgV7P2uePsbIAELGCcD6gh7/ltgfhzIuOdxyUHG64sEfwIpUVUK
EBYIhAcPcJJVVQoBHFCDaEgogQ+0xgLUWqHnLKgd5GzQfkNqnetQRsMatiuC/jfMD4ug1kN1CQmI
QRRg845XxNyg6S+fyY2KyJdEhmRQbk2knuEwGBh9xWuBRDxi8a44LwoqTXkCI2MWAcVDe2UJiUUy
4+eiJzaVxXGNwaPjsOwYRzn6zY95lNId8Zg2QsZOkGMJoyEHtEjobYkmiUICpT7wBTBQ6gBmGGEm
R6WoSmXSVB401atIRcIAFCoAExiCKE2GkhVWAAQjQJUGakCyBLwBDgo4ZSpNJQdWkWpUraqDKEGA
Kw7wAFVfS1IjI8PHQYJJMWTC0jOXqZRmws9MpgNkIRFZp8xNc4va0ebpHikTHd4JMzjpmjireUiv
uWydPClQ0+DpREfm7J3W/ozOcGQYgBDAUAewWiENjIASGFhgBxmQQRH+6YHUvAaG1UImOzsntbu5
UXFJgVfTzDlGNR7OTfUKEj3NlkZqGlGPe7RZSU16snCiTaVpHBwCShmA2wVrpgHAaQMYgJIFAKsB
CLDpAhDAypM0oAEBYECsckrCmZYMJQTQkHqGxs2YLjNmWNVeO314UXKubKTckh0bj3W0r4K1N2J1
zFn/lqDk3CtwXaVo/AL5xmQNL64z5GpeiafIxTBvrWyVq17JA1gT0W6lIqXrVNNKVbyZVWu866iC
tNjGveLTsYglniHnmc3qaVSOhXWnYC+LuIpkRnIAWEIiKpUZASyCEXzA/qQBEHEFLKz2AEfIjAWq
IAUp9MEPBjiDqCIx2yuUirZYmFyiBKJb3oIHslnk7BxLi5/RDUyzeJQuODH7NtsYB6TZ3WbqPJsv
j7ZFNLhjwDEPAAMUpMAAJuiBD35wgBygd1exlMHBhPWaUooGhjBorI46y93Meo+QyGPkgalr1dKF
F6UWxWJG4UpYBq3kvxLYgAE4UIEOxPIDDfiwCeDrXgO0oFAGcMELDKAA0syABiqoQAxqcIAVYnhb
2VlXjhfM4MQNmEVZjWpIB7s9bJK3iki+CBWTzOQmz4QtV6HOkp1M5So/V11wtLKWA7inLXuZyV3K
8pfHfL4wk/nMBLwf/prXrD81s/nN7+sfnOeMPqbR+c4+Vg+e96xRG/I5I+bdTe/+fF05ERrQgUKW
ZKc8FAUe2iKB3k9orQbBR1ekr0xsZKQxZOlLr3XSTnuQmDv9aZO2jGz16TRmDECCPfChUr4FriBE
tdMXtsEDC7DxCfmJ4QDvmKV6SrWqI7LplOwQwsCeKJKGPZFitw7Zya7nspnd7GIrONrjVM+ohw1P
UI9Wz9Su9hCxvTvpMTrcCKGntysqNrSgO17WLvIa1x3WFm27zWelt1T/6JYtYxq60SXwgABTZ7fq
jLAIFjiYGtzD4jlvumgk17/JfdLKkjVLBqa4WoecIwee+yD3nmC8/jVO2cXi9Ud9JLnJLd5xmHJl
4irf98pb7vJExnysM69jzV+ubychZ9ELunZV09LzTGM7tNe8+RmjjXSij1zlRd+4V8XydKiTe9J9
7J3S7QlsrM8kUbXVQhW2gCjNVGEMmRnD2U+bGTSkAQ0koBZsDLAGhYmmBLJBicQoZjGMPctgFfiY
qkDQA0+pKgEPyEAD9l6xi0lAC6LJgOQlMIHIS0ADE1BYBmKjAQmIaoy/Zno+X3IESwkkckhYQukB
UPrVt95Sq8/BCjisBpMlYArAGmpTaerTBABVqERFCU59SoXDAxWnRj1J73//hJvGqqmcbEACGCDU
BwCrxQlgDUZF/r/zlz98MGXicbK9TqPp+SiaYvom96eedEkrfPyjJzqYol7yrsc/kZyj/9OADjx+
kX8mxoEn8wdzOid1iXZ/IaFD3qRYBchMS3eA3UcTVVAISAAGhpBJSNAZilB2TgAAVlAFvNUZXzA5
VTAHqwJLBpABmKctdycbmZcBqLJCwIIHdpeCGtAwD7N5l9dfvfIriNeAzRE3lDFeEUgTSmA5THAE
qwcAe1AFjsAEA4F6SrCEAKAETNB8CoB80tcAz8dUt8OFJ4F8NZV7yKdTDGB9CdBiTAUsUiCGQCht
oeZ/CFh+3zZuXHdPECg4mKYsBQNDGqZfFbBeovEp2dcauJNf/vv1d/5lAACmbAjXUiz3huK3ExPC
Oa5zNRUXiSllbg7XY/JEH8/GWCMCbUY3dOKjf6GniXbIfviBislDiiHyf322dXCYc5KYI49Fi2il
iqtoihLnivURYR0ni+XVHzLIKq4SUAZAKzx1ErqkSq2yA0XljAbQADZgABjQALp2eA8AiXP1Ur5Y
icAIFjETbLzoc0UoPiYVZEJWbkR2izfyVwRof8JIc6wocU/EfzKSYPZ4j5XYQOL1jYk1h/oEatpl
i71oHeNDMH8lYD+GkENkH2UjLxR2caI4hJShj5KVJoHGLtYDjpZlgCGpfr7RkCD5iBApdHW1HHk2
kBeJkSOp/of40l0nmYopKW/DkhNHMVmeKI6FdZA3GYzb1ZOtWHUqiZLnKJTvJCAVCY+vWI82WUZt
0ZQ/xH+7WIcP+JBESJT/uH0Bh5UAWWC/6JVfGZN5OGG5iF0PBpZPdGRFCXBlaZZhyZV8SJZFBJSz
45YPIQUguAWPUgUAkBlHoBDOlRkguBkRkRkDYZhnlxDzGJV3GZCkJWgEZxFSYAGHsAWIQAaVwhkf
YAWNgASDGQa7VQiXFJidCQAgJEKcBACkCQiHEASliQSouVt+mZpW9DTf10RGmW1biZbVNQAgZ0Dj
6IBy2ZZiGRyt8xm9CV7zJplymJzF6F3eGJkv6ZAk9TZt/iI67Mab0CmV0tmK3mVO01It2FJN5Qkx
F+YaraEt2PmU/Bae4lkdBoVQMhBLB1ADFsAClTIBQJB9JlGfCbVQEtNQrcSIMSRRNdk9EIcU4ENB
xemIAgmf7iefdbmbcfmOsAiZ2RlTELo5Grlp/KiUEuagNKmWGaqhUHmdKNGQG0lHzEJ518KeVGEa
ouEsEnADnvcwsBEbSBmUE1qhFnqKbKkS/ORPEiAC+JkqorEC++lBnMRPGbACB6ABoqIAugZDDsWh
IomTQkqXY6mVJYJVXhqkZcqiJ1Fm1wNk7MhxOHemRdqi7zandFqnL+FudpqnBUKZw0k2evqnWJEX
/ceR/oBaqESxj4aaqD8xJHiqqI4qEl32qJJqFJw2qZYqgGp1qZqKEWa2qZ46HfHzqaLqEGcScqNq
qG52qqpaaKG6qq4aL+D2qquaqrJ6qnJWq7Y6bbgqqre6q59qZ77qqT0TrJvqaMQqqcZ6rI6arIXa
GIOmqMz6p0kjWf7mZ4nanBTKkYumjoYGrQYZiyGKGNZ6rWe5lsn0cXY6aREqoZIGrXOZcKK2rAvK
m5V2rYC1rkpBnMtaappGPPLqkoukOY8ZIP9KFepZoptlcPqhaHOqW2fQGQfwgVWABr6igq9hBXt3
TAngeS7Eaz7YjQzadZjGsO+WGVZgAH3gQVnwByOE/gCxMQiiEgNAICsME4PIJIO4E7K6SLLv9nqr
VzlSUF80xVQllIWlVIhO5XtueBLHQaK0GK3SqiXf5aY3B7V66mx2QrUx1zOm+mebpkMbenTd+qiB
Zk5NC6RXN67euom6WH+tiqxs+7T10bWEhq1dunXogq5Xa7dZubWbA7cJWbUPZK9xa51W0SdE06yF
a7j2ohBQxDJ0+z8D+53Po29/0W9fNrkM2HDvZyJeprmbS0P6J5EBkLkA650Nalj+lm/wOpQZuZAK
Mj+Durii27kP5BceypN2Wbupm0wMh2Wg55wpOplm4qEi1VHv+psLN4sa14lhe7rLK45tC5P2pnXz
/ro0n4WvCHu3TukfGTe9M/O8KFq8DxG5MTG74DuKKxq4ZtIn5ae9lBuH0IuLWZe+r7O+K9J0zmS/
4Yu/pQglRcK/wou2DuaPgcq39Oi/sUiQToHACZyUcBkkdCjA/QvBuxuPKUfB6mvBBRyOWgG609ub
98rAUAG/8SsuIapMBlxADrxMJlxBEtx+GrxVDxzDATzDMFzDKOd0L4ymz7nCJdzDPjy8GIx/Qnyc
revBONTCLpy26fgURxynPwzEUBzFP8pSxPjBxhO8WOzEVOwRjGkFDuEEgAlvRmoA2rcT6bkTMVp5
PWqePTob1bLGgbV/SuIrOfC/XfzEYMyIVcAF/gbQBVjgBZz5AWUQXKJyyMLVSYZcKvoVSmxwMMf0
ASPWjfcVAIhYAfz1QhJwAbCiGm3gAggKA5gnyodoAPoVB8ckACm2Yh/zAS9AB6hMAbJsBzFAAfiZ
xi+Swu64x1/cEcvlmrslBpzJyKw1QomSGbJZAztwABKwBgxVs6UkoArFUFu6QjBQAW6AoBkwAqJc
ShnwAAtAzQQ6B75UYx60Ap0cA/+UAm3QBniwsS60wGLLxw0sAFJwfSSZEktrkeunxAwkalciTfvs
ywAdqBiqF2QyiQYNwFQi0OAXTQVtaiSMQxPdFuiXfttLTVksf0bmuvBnzwj90fFZz7880htd/q46
vMOHwcR3GJ0mfdBdcdENZMX1JtMsTNPJ+7rfKtIecU6IRtLKS2ngedIdYV2cOjhTYZUQ/Rzr1tEj
sZzi+qWixic0nIk7zdIxYU6IoU7XW8fUq9Ja/RN8OXZ/iZqDmRDOBQBSkAZpsINVgS0ximNnzMbs
6Svu2W6XOx99+542IhSnNTmqdcyuBVuyhVy3lVsG8AQcIwEf1gBwUGInRsmOTAE2C0OWMMuBSGux
9CmcYssUwFP85CuN2L3FMtRjfROXmZmb2ZlV8JmhOZqleZpsTQlykAaVwEkBoJ/8GaXLaAE1YLOl
hKQAJdwDVQLvHM+cnAG+MrS0+1GiVdQ4/g0UkTM55RO6+XvV1YmcRu19Q9zU7IplMD3dNlc3ShLB
V6lWICzUTc0gF6qIB5MwNlqzDgMxjNd3pnHGi8iNN11hFvbSb9q92K0SysIWxyhKysiMKPGMq6SI
/ZV7/S2mMqei2X3BBF7gKyGGwLd7AVBryvdTQUWGRZW0QOXcAXC2eGmOCgyuKRx092uiGL4f34WJ
2x3gz/3X0isfokPjA0zh6NjdN/weYPvdtejjepzaeyrk5qSQQBfWRk7PQO50FKxjX70i5WXTWP3k
6E2/n8W/VH5ySB7j4Pvl88vlXZ6+I9qPDv29eCu+42vDZz7mVfeTZXXlXr7iFo7jdxUf/m38d9Gi
EnTMEvONozoKGzG6pd1p4+xr5r/7Hhj2h5Jcs4TIGpecyZsMAy8WYzOGzugMQ3T94mYq4CVCleRx
pNHM6QNVUAc1oNacElNapVeapT5a4/Lrz2ve6I2kVTnMvTfOIqSOR2S6waHe61aundQUZMKu6BUe
5Q997G3ay8r+4+TNJmju5uB963ZOmc5LxH297MyeIjHyoiec5cRe7F+V1X2xaNau076+52WerdEO
5d/+IegO77zu7dNOJS6t5Xje4+We7HSSllWutbUu6hc0NmvSkmp+xfG+5RcE7SWp8Aa/7ruek9vh
OxR5ou9u75El7nkFPGqEwL+O7wzf/u0cL2noYpJgzqXRXfLsfRsfufI6O+wnT9XvovG27vItL+EM
PZMCn/M8b/Jwyu5+5e4LH/R4iMTh/iYSP/H9nuggmpOHOxgjL+06X/Asz1c7ib7fg/NHP/P8zsFV
LaiwO6TBsd42n/U7r/YDn6ZG/+8UD/BgX0aH9YsjPO7kPvc1XfdhuvFHSfN/z916OZ9+P/RC77SJ
xpQ///V6f++Bn49dv/jVa72A//iHT/CCD+O4PonIK/ZQ3/j1vhIq/+bK0+I7I8VA36FsntIWNK22
q/rTSfqMi/RiDft9n9CzT/uhf+GS//KcS+RwX/V437ugv/tT4vVE//o1n/nxdO4O/t/6w1/4cur8
Hcztlm/807/6rK87KT7ems8RHdjAz1+50X8sQij6FjGBFXiBBpCBBrCBmdGBEsuXBjCCkYQEkHCY
mUF2H7gFBjD/AAEAgBMDBwQSPIAEiROBDR0CEBBA4kSKFS1exJhR40QBHTd+BBlS5EiREUme/GgS
5UqWLQOo/PhQ5syHBgQAsJIDIcJDXhA5Ifjh0aEvBQcWRFI0yx8DHwqaafrIQNRDSI4avKpQCU2B
Hl1+3QgT7FiyIcWWLYlW7dizGbm+fahEIZMjR7DuqeKIScMkWu0K/CuQCRImB/5u6YJFEpK+SLYC
sDs3MFyIHduuPXkZ8+avmjlT/vT8WTRokZRNn0ad+vQArqFHY3T9WnbG2Jxrz157W/Vu3r25DgA+
8zbul8SNpzxOOrls3b6dP0cNXLpMr8thW8cucTjm7dlRNoceXrxD6eUddp+N3ntZ9ezX2y49Xj70
8vUbVn+vPf/x9mT776ctvvkGJPC/j4BjyUAAM8NOwQWVA4lACedzEKPyVqrwQZAyxFBD/wScMMTe
OLSovgG+8/A1EhlMsTMQRYQRtRUnMhFBkmZsEcLkcHwPvBh/pAy/0STQIQEQXjihoAkkkKCEDDSI
wIAIIiLSyBdCYBKGiqI8QCIuE0jggRw14tGsMVvyEUg1hSvTIpsCmADKpgy4/kCFgnboQIYHInpz
giGaImKHBCji0suCwFzgzOusazO7NNeE9D7iFgCzAQQQ6LKBBBoIQgIhGiguAEo3RUABRBEYVCJM
K8VUUTItgzVWWWe1rENXWYwwUl0lfbDRFsv0tSKYaCW2WGOPfXRXNYNF8Va1gCWO2bRCUnZXaW90
9tnPrr12wxer/VHI/LoFEFrcyCVzJHAhFbfH75Cltddto91vuHWXRdfMbF+CF9l5z61X3XvDTTHf
9drkNuBvB57QYOT2ZUu0hMcVmGERa5UXYrAQppfihS0e8L9+iw3LIi4pqAADCZ6MkmUDSGhyySZb
ziADCSaQqIQYLpDAAhkMpUgAh4I8OBRM4zgG2GNqQYbR4O2+JPoDD0Ag+gAEuEySTjudcuqAJLsM
YKoGbDAAgwa4/DLMoyXu2N2PmaYQ3e5alcjUBBigu1VMNW3Aar8DoDuABkBlwGrAu1zVaIkIYM7c
9BReGu6LyXUYJQIuZ47t9CrXMSbJL97R1ctHV/HfpA+u+HMJ2x2Nc5FGh7110x93O3LVV+fvTNh3
13yzbl3XT6SAAAA7
Content-Type: image/gif; name="in.gif"
Content-Disposition: attachment; filename="in.gif"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--=__Part1435A4EF.0__=--
