[Mapserver-users] Changing Colors in Map !!
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Jul 21 08:08:23 EDT 2004
Hi Satyajit,
Since the problem is that you are overflowing the browser lookup table
there is not guarantee that this method will work. When I did this I
have a few colors that were changing so I only used the dummy layers to
protect them.
I also notice that you have a RASTER layer. It is possible that this is
the layer that is using up all the colors. Try adding the following to
any RASTER type LAYER
PROCESSING "COLOR_MATCH_THRESHOLD=3"
http://lists.gis.umn.edu/pipermail/mapserver-dev/2003-February/000177.html
and see if that helps.
Satyajit wrote:
> Hi Steve and Andy,
> I tried Steve's method of adding dummy layers to my map file.
> But I don't see any significant improvement in the "changing color"
> problem. My map still behaves the same. I am using a lot of colors in my
> map. Since I have some 39 layers in my map, there are more than 40
> unique colors used in the map (outline colors also count). Do I have to
> use these 40 colors in the dummy layers i.e. 40 dummy layers have to be
> created ?? I tried using only 10 dummy layers with only one class in
> each of them. Will my problem be solved if I use a single dummy layer
> with 40 classes added in it ?
> The legend problem has been solved. As Steve used HTML legend stuff, I
> am also using a HTML legend stuff. Hence I have control over the legend.
> I can choose which layers to be shown in the legend.
> I am attaching my map file with this mail. The part of map file which
> Steve has given in his mail ( which is also in the bug list at this
> place http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=306) seems to be
> of a different version. When I tried to copy the same to my map file it
> didn't work. I just added a "Style" object in my "Class" object with
> only a color entity in it. Please have a look at the map file.
> Waiting for your replies.
> Regards
> ~sat.
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of ANDY
> CANFIELD
> Sent: Monday, July 19, 2004 6:50 PM
> To: woodbri at swoodbridge.com; satyajit.gantayat at aurovision.com
> Cc: girish.shewale at aurovision.com; mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Changing Colors in Map !!
> Yes, I believe there is a way to do what you want. I have a legend on
> the
> side of my maps that I generate on the fly by looping through the layers
> of
> the map and adding each layer to the legend as the loop progresses as
> check
> boxes with the layer name so the user can turn off or on the layers.
> This allows the legend to be dynamic so no matter what the layers are in
> any
> map I always get a uniformly formatted legend with no code changes.
> I have a cosmetic layer much like the layer you are describing that I
> use to
> copy for placing geocoded points on the map. The users are geocoding
> from
> multiple text files so I want different colored points for each file so
> they
> can compare the results of the files. That's why I use copies of that
> cosmetic layer so I can use it's symbols and only have to change the
> color.
> I don't want the users to have access to these cosmetic layer copies
> that
> are created on the fly. So I make that the first layer and my loop
> through
> the layers starts at layer 1 rather than layer 0 so the first layer
> never
> shows up in the legend. You could do the same thing with as many
> cosmetic or
> contruction layers as you wanted just be sure to start your loop one
> beyond
> the last "invisible" layer.
>>From: Stephen Woodbridge <woodbri at swoodbridge.com>
>>To: Satyajit <satyajit.gantayat at aurovision.com>
>>CC: Girish <girish.shewale at aurovision.com>, MapServer List
>><mapserver-users at lists.gis.umn.edu>
>>Date: Mon, 19 Jul 2004 08:16:59 -0400
>>You raise a good issue. I don't usually display legends, but have used
>>HTML
>>Legend stuff that allows you a lot of control over your legends and I
> think
>>you can eliminate layers on a named basis. which might work for you.
>>Please add a comment to the bug referenced below about this problem. I
>>hope
>>that the developers will tackle this problem but it helps to have a
>>complete picture of the problem and issues and their work arounds.
>>-Steve W
>>Satyajit wrote:
>>>Hi Steve,
>>> Thanks a lot for the info. I have not tried your method yet but
>>>shall try it very soon. And let you know the result. I have a question
>>>in my mind though. When we add a dummy layer in our map and add
>>>classes to it ( to preserve the colors ..as you said), the layer will
>>>be shown in the legend in the browser. That dummy layer in the legend
>>>might confuse the end user as that layer's features won't be easily
>>>visible in the map and of course that layer doesn't have much meaning
>>>to it. Is there any way by which I can add that layer in my map file
>>>with all the classes but still make it invisible in the legend ?
>>>Thanks a lot again steve. Shall get back to you after modifying my map
>>>file.
>>>~sat
>>>Stephen Woodbridge wrote:
>>>>I think I may have created a feature and inserted a one pixel dot on
>>>>the map that gets covers by later layers. Play with it and if you
>>>>have a problem let me know and I can dig through old mapfiles and
>>>>find out
>>>how
>>>>I did it.
>>>Here are some examples of preserving the colors in a symbol that were
>>>changing. The big problem with this approach is that it uses up a lot
> of
>>>layers, so you might try using one layer with lots of classes, but I'm
>>>not
>>>sure it that will work.
>>>The bug for this problem is:
>>>I just updated it with this information.
>>>## dummy layer to protect symbol colors from changing
>>> LAYER
>>> NAME "color_symbol"
>>> STATUS DEFAULT
>>> TYPE point
>>> TRANSFORM false
>>> FEATURE
>>> POINTS
>>> 1 1
>>> END
>>> END
>>> CLASS
>>> SYMBOL "color_symbol"
>>> COLOR 0 0 0
>>> END
>>> END
>>>## protect other colors
>>> LAYER
>>> NAME blue
>>> STATUS DEFAULT
>>> TYPE point
>>> TRANSFORM false
>>> FEATURE
>>> POINTS
>>> 1 1
>>> END
>>> END
>>> CLASS
>>> COLOR 0 0 255
>>> END
>>> END
>>> LAYER
>>> NAME green
>>> STATUS DEFAULT
>>> TYPE point
>>> TRANSFORM false
>>> FEATURE
>>> POINTS
>>> 1 1
>>> END
>>> END
>>> CLASS
>>> COLOR 8 206 107
>>> END
>>> END
> Satyajit wrote :
> Dear Users,
> Thanks a million to all the users who gave me their valuable
> suggestions while building site. Without the help of this group it would
> have been impossible for me to build such a nice site ( I hope you too
> find it nice). Though my map is smoothly running, I have a strange
> problem in my hands. The data layers in my map are changing colors while
> browsing through them. The change in color happens randomly at some zoom
> levels. At times the colors of the data layer match with the colors in
> the map. You can check out this site http://203.199.114.111/newham/ .
> Normally the data is shown in the color specified in the map file. But
> when I try to zoom in the data layers seem to take the colors of
> different other data layers. And it create a whole lot of confusion. I
> can't really find any reason for this.
> Any ideas ?
> Sat
> Sr. Specialist - GIS
