[Mapserver-users] How to get X and Y pixel coordinates with JavaScript
Jan Hartmann
j.l.h.hartmann at uva.nl
Wed Jul 21 11:27:24 EDT 2004
Merlos wrote:
> Maybe someone can help me. I was wondering if when an user clicks on the
> image that is on an <input type="image"> element it is possible to capture
> the X and Y coordinates before the submission is done. I mean:
> <script type="text/javascript">
> function formSubmit() {
> //Here get the X and Y coords in pixels... Is it possible? How?
> <form name="apatruyando" action="JavaScript:formSubmit()">
> <input type="image" src="image_url.png" />
> </form>
Hi Merlos,
The following works for IE5.5 and up and Netscape6/Mozilla. Not sure
about others.
function getCrd(e) {
if (document.all) {
X = e.clientX + document.body.scrolLeft
Y = e.clientY + document.body.scrolTop
} else {
X = e.clientX + window.scrollX
Y = e.clientY + window.scrollY
... ///anything else you want to do
If you have an image defined as:
<img src=ïmage_url.png id=myImgId>
you can assign this function to it by:
var myImg = document.getElementById("myImgId")
myImg.onmousedown = getCrd //NB *without* parentheses
Now every time you click somewhere in the image, the function will
compute the coordinates of the click and execute everything else. You
don't need to encapsulate the image in a form this way.
This way, the coordinate is computed from the top left corner of the
page, even if the page is scrolled. If you want the coordinate relative
to the image, regardless where this is on the screen, you need to
compute the top left corner of the image:
var node = myImg
var left = node.offsetLeft
var top = node.offsetTop
while (node.parentNode) {
node = node.parentNode
if (node.offsetLeft) {
left = left + node.offsetLeft
top = top + offsetTop
Hope this helps,
Jan
