[Mapserver-users] unclear on the concept
Joel Gwynn
joelman at joelman.com
Fri Jul 23 09:56:44 EDT 2004
it's a point layer
Lowell Filak wrote:
>Doesn't $so need to be MS_SHAPE_LINE instead of MS_SHAPE_POINT ?
>Lowell
>The following message was sent by Joel Gwynn <joelman at joelman.com> on
>Fri, 23 Jul 2004 00:26:20 -0400.
>>The shapeindex numbers I'm getting don't seem to correspond to any
>>values in my "cities" table. Even so, I would hope that I could
>>retrieve all the feature info from the mapserver object without opening
>>up a separate database connection. Is this not so?
>>I'm just having trouble finding the specific syntax to get information
>>about individual points on a point layer. Here's what I would think
>>might work, but of course it's not.
>> my $so = new mapscript::shapeObj($mapscript::MS_SHAPE_POINT);
>>if(my $r = $city_layer->queryByPoint($map, $boston,
>>$mapscript::MS_MULTIPLE,10)){
>> print "no results.\n";
>>}else{
>> my $i = 0;
>> print "status: $r\n";
>> while(my $rc = $city_layer->getResult($i)){
>> my $si = $rc->{shapeindex};
>> $r = $city_layer->getShape($so, 0, $si);
>> print "getShape: $r\n";
>> my $point = new mapscript::pointObj();
>> $point = $so->get(0);
>> print $point->{x}.' '.$point->{y}
>>What really obvious syntax am I missing?
>>Thanks,
>>Joel
>>Lowell Filak wrote:
>>>I don't know postgis but I would suspect that the query you want to do
>>>could be done directly in postgis.
>>>Excluding that as a possibility, the shapeindexes you receive back
>>>should be the sequential number of the shape/attribute record as they
>>>occur in the postgres table. You should be able to retrieve the shape
>>>into a shapeObj via $layer->getShape($shape, 0, $si).
>>>HTH
>>>Lowell
>>>Wed, 21 Jul 2004 23:43:20 -0400.
>>>>Perhaps I'm going about this the wrong way. I'm using perl mapscript,
>>>>and I've got a postgis points layer and I want to get some points, say
>>>>within a certain radius of Boston:
>>>>my $map = new mapscript::mapObj("$map_path/world_cities.map");
>>>>my $boston = new mapscript::pointObj(-71.1029968261719, 42.375);
>>>>my $city_layer = $map->getLayer(1);
>>>>}else{
>>>> my $i = 0;
>>>> print "shapeindex: $si\n";
>>>> $i++;
>>>>This prints out a bunch of shapeindex numbers. What are those numbers?
>>>>They don't seem to show up in my cities table in the database. Can I
>>>>use the mapscript object to access the points?
>>>>_______________________________________________
>>>>Mapserver-users mailing list
>>>>Mapserver-users at lists.gis.umn.edu
>>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
