[Mapserver-users] more on: Logical expressions in CLASS EXPRESSION
Stefanie Weykam
sweykam at teleline.es
Mon Jul 26 13:01:37 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_0000_01C47342.FA4DB950
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: 7bit
Thanks Gerry and Norbert,
I can't see the difference in syntax ore anything that I have left out.
OK, CLASSITEM or no CLASSITEM doesn't matter as long as the field name is
specified in the EXPRESSION - class doesn't show up anyway (it does, though,
in the legend!)
If I use EXPRESSION '1' for one class and EXPRESSION ([Riq50] >2) for the
other, one shows up and the other doesn't.
Problem is not due to any error in MapScript, as I get the same results (say
no results) doing it with MapServer directly. No difference between
MapServer 4.0.1. and 4.2 either....
What else can be wrong??
Couple of days ago, somebody mentioned that his query didn't appear in the
map but in the legend - what was the reason in the end?
Stefanie
Content-Type: application/ms-tnef;
name="winmail.dat"
Content-Transfer-Encoding: base64
Content-Disposition: attachment;
filename="winmail.dat"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------=_NextPart_000_0000_01C47342.FA4DB950--
