[Mapserver-users] HELP {Scanned}
Siki Zoltan
siki at agt.bme.hu
Mon Jul 26 19:48:55 EDT 2004
Something strange happend to you.
1st
Check wheather mapserv refere to libpngxx.so. Use the ldd command
ldd mapserv
You will get a long list of shared libraries used by mapserv.
2nd
Try to force to configure png format --with-png=DIR
You can see all the swithes of configure with
./configure --help
Bye
Zoltan
On Mon, 26 Jul 2004, GONZALEZ, Jose A. wrote:
> Zoltan,
> Still no luck. The ./configure command lists yes for all PNG related
> data. The only thing I don't have installed is jpeg support. Would
> that have anything to do with it? Thanks for all your help I appreciate
> it. - Joe
> -----Original Message-----
> From: Siki Zoltan [mailto:siki at agt.bme.hu]
> Sent: Saturday, July 24, 2004 5:45 PM
> To: GONZALEZ, Jose A.
> Subject: RE: [Mapserver-users] HELP {Scanned}
> Hi,
> You should check the output of the ./configure command.
> There should be lines about PNG like:
> checking where PNG is installed...
> checking for png_init_io in -lpng... yes
> using linpng from system libs.
> If you have "no" in the second row then the pnglib installation is not
> correct. Check the installation giude of mapserver.
> Bye
> Zoltan
> On Thu, 22 Jul 2004, GONZALEZ, Jose A. wrote:
> > Hello Again,
> > Now the config script says its finding all the libraries including the
> > new GD lib but when I run the cmd -v I still get OUTPUT=WBMP. I'm
> > guessing it needs to say OUTPUT=PNG? Any Ideas? Is there a way to
> > change the default OUTPUT?
> > -Joe
> > Sent: Thursday, July 22, 2004 11:52 AM
> > Hi,
> > > Zoltan,
> > > Sorry I figure it out. I used ./mapserv -v. That seemed to do the
> > > trick. This is what I get:
> > > MapServer version 4.2.1 OUTPUT=WBMP SUPPORTS=FREETYPE INPUT=EPPL7
> > > INPUT=SHAPEFILE
> > > Does this mean I only have .bmp support? How do I get it to
> > > configure
> > > with PNG support? I did compile and install GD, zlib and libpng.
> > > So
> > > I figured that the mapserver would configure itself to these
> > > libraries.
> > Yes you have only bmp support.
> > I see you use linux, then it is not enough to install the png lib, but
> > the mapserver make/configure must find it. You may need change the
> > LD_LIBRARY path that configure can find it. First run ./configure and
> > check the output. It will propably say libpng not found. There were
> > mails about it on the list, check the archive.
> > Bye Zoltan
> > > -Joe
> > > Sent: Thursday, July 22, 2004 3:58 AM
> > > Cc: mapserver-users at lists.gis.umn.edu
> > > Subject: Re: [Mapserver-users] HELP {Scanned}
> > > Hi,
> > > Check wheather PNG output is supported on your istallation. Run
> > > mapserv -v command to see the supported input and output. If you
> cant
> > > see OUTPUT=PNG then you should install the neccessary libs for png
> and
> > > reconfigure/compile mapserver or change the IMAGETYPE in your map
> > > file
> > > to one of the supperted formats (GIF, JPG, ...).
> > > Bye
> > > Zoltan
> > > On Wed, 21 Jul 2004, GONZALEZ, Jose A. wrote:
> > > > I need help with a new setup of mapserver. I have installed all
> > > > the components and can't seem to run the demo file. I keep
> > > > getting g
> > the
> > > > error:
> > > > msPostMapParseOutputFormatSetup(): General error message. Unable
> > > > to select IMAGETYPE 'PNG'.
> > > > I've searched all the archives and can't find any solution.
> > > > Please let me know if you have seen this error before and have a
> > > > solution
> > for
> > > > it. Thanks - Joe
