[Mapserver-users] Windows installation error
Justin Riggert
justinriggert at hotmail.com
Mon Jul 26 15:44:58 PDT 2004
Well that takes care of that. What is strange is that I tried putting the
lib contents into Winnt/System32 and also tried adding the lib directory
into the PATH environment variable. Both were not working for me. I must
have been doing something wrong because I tried putting the lib contents
directly into the cgi-bin directory and it works like a charm.
Thanks for the response,
Justin
>From: "Ed McNierney" <ed at topozone.com>
>To: "Justin Riggert"
><justinriggert at hotmail.com>,<mapserver-users at lists.gis.umn.edu>
>Subject: RE: [Mapserver-users] Windows installation error
>Date: Mon, 26 Jul 2004 18:09:40 -0400
>Justin -
>Make sure zlib.dll is either in the same directory as mapserv.exe or
>somewhere on the system path where it can be found.
> - Ed
>Ed McNierney
>President and Chief Mapmaker
>TopoZone.com
>-----Original Message-----
>From: mapserver-users-admin at lists.gis.umn.edu
>[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Justin
>Riggert
>Sent: Monday, July 26, 2004 5:42 PM
>To: mapserver-users at lists.gis.umn.edu
>Subject: [Mapserver-users] Windows installation error
>I am installing MapServer 4.2.0 onto windows and am running into the
>same error on both XP and Win2K. Here are my installation steps:
>1) Install Apache 1.3.31 in default location (C:\Program Files\Apache
>Group\Apache). I am using localhost as the server and domain names.
>2) Unzip the MapServer 4.2 binary package. Copy the proj directory into
>C:, copy mapserv.exe into the Apache cgi-bin directory, and add the lib
>directory to the sysem PATH. Also tried adding bin directory to system
>PATH.
>When I use the following URL in both IE and Netscape -
>http://localhost/cgi-bin/mapserv.exe?
>I get a "500 Internal Server Error" in the browser, and Apache error log
>says "Premature end of script headers: c:/program files/apache
>group/apache/cgi-bin/mapserv.exe"
>If I try mapserv -v from the command line I successfully get the version
>number and some other information. Is there anyhting obvious on what is
>going on here?
>Thanks for the help,
>Justin
>_________________________________________________________________
>Don't just search. Find. Check out the new MSN Search!
>http://search.msn.click-url.com/go/onm00200636ave/direct/01/
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Express yourself instantly with MSN Messenger! Download today - it's FREE!
http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
More information about the MapServer-users
