[Mapserver-users] Labeling question
Steve Lime
steve.lime at dnr.state.mn.us
Tue Jul 27 14:02:14 EDT 2004
You can't label points if you don't draw them. Try changing your TYPE
to
ANNOTATION.
Steve
>>> "Zamil Murji" <Zamil.Murji at divestco.com> 7/27/2004 10:35:54 AM >>>
Hello,
I tried the TEXT option for a class, but it doesn't do anything. Here
is the offending layer:
LAYER
NAME "rasterlogs"
TYPE point
STATUS off
MAXSCALE 800000
CONNECTIONTYPE postgis
CONNECTION "user=idc dbname=idc host=idcmap port=5432"
DATA "the_geom from main_well1"
FILTER "raster_log = 'Y'"
CLASSITEM uwi
CLASS
# COLOR 255 0 0
# SYMBOL 6
# SIZE 11
TEXT "5"
LABEL
COLOR 0 0 0
TYPE TRUETYPE
FONT wells
FORCE on
SIZE 12
POSITION cc
MAXSIZE 12
MINSIZE 12
END
END
PROJECTION
"init=epsg:4269"
END
END
If I comment the TEXT and LABEL and uncomment the symbol then
everything works fine. Right now it is bringing back a blank image.
Any thoughts?
Zamil
-----Original Message-----
From: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
Sent: Monday, July 26, 2004 11:11 PM
To: Zamil Murji; mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Labeling question
There is a TEXT option for a class that sets a static label to be used
for all features in that class. That way you don't need a labelitem.
Steve
>>> "Zamil Murji" <Zamil.Murji at divestco.com> 07/26/04 4:52 PM >>>
Hello list,
I am currently using a symbol to display a postgis layer. I want to
give
the user the ability to display any character from a special font file
that we have. Is there a way to force a layer to display a certain
character.
I know you can do LABELITEM and give it a column in the db to
reference
for the character (this works btw), but I want to write it into the
map
file so that it is easy to change. I also don't want to have 500000
redundant rows because if I have to change that character then I have
to
write an update function instead of just changing the .map file.
Any ideas?
Zamil
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
