[Mapserver-users] JBOX ERROR and more
    Richard Greenwood
    rich at greenwoodmap.com
    Tue Jul 27 13:20:36 PDT 2004
What Java Virtual Machine are you using? In Internet Explorer, go to
Tools, Internet Options, Advanced, and look for "Java(Sun)" and/or
"Microsoft VM".
What code gets executed by the "reset the map" click?
Regards,
Rich
Javier Castillejo Montes wrote:
> Hi!
> Well let me explain the situation... I'm using Mapserver 4.2, w2k, IE 6
> and IIS.
> I use this line to start the map...
> //[host]/script/mapserv.exe?map=[rutamapa]/FrameMapa.map&layer=penin28
> &layer=autonomias&layer=CCAALabel&mode=browse&Zoom=&WhichButton=Han&ZoomAct=
> which is set at the load time and each time a press the button "reset
> the map". It doesn't matter  how many times I zoom in and out, how mani
> times I drag the image... it's only happend at the load time and at the
> "reset the map" click.
> Hope this will help!
> -----Mensaje original-----
> De: Richard Greenwood [mailto:rich at greenwoodmap.com]
> Enviado el: martes, 27 de julio de 2004 4:03
> Para: Javier Castillejo Montes
> CC: mapserver-users at lists.gis.umn.edu
> Asunto: Re: [Mapserver-users] JBOX ERROR and more
>  > Hi all!
>  > I'm using jbox and it works almost perfect. Sometimes(i don't know
> when) I
>  > have "Applet error. IOException PngImage" error, but I just clic
> where the
>  > map is suppose to be drawn and it's appears with oput any problem...
> Does
>  > anyone know how to avoid this error?
> I would love to help with any jBox problems, but you need to give us a
> better idea of when the problem occurs and the code that causes to to
> happen. For example, what browser? what Java Virtual Machine (VM)? Does
> it happen right when the pages has loaded, or after many zooms and pans?
>  > I asked the next question some time ago as I couldn't solve the promen I
>  > just aboid the step, but now my boss ask me about to add this step so...
>  > here it is the question, as I couldn't solve it yet... I have a map
> country,
>  > and it has been divided into small parts. Its parts should have been
> drawn
>  > with different colors... as I can find differents parts in differents
>  > countries I would like to know how to set for each part a color.
> You are more likely to get an answer to this question if you post it as
> a separate email with an appropriate subject.
> Regards,
> Richard Greenwood
> www.greenwoodmap.com
Richard Greenwood
More information about the MapServer-users
