[Mapserver-users] Help Requested: Easy "gen2shp" application
on RH Linux
Ken Waters
Ken.Waters at noaa.gov
Wed Jul 28 02:12:01 EDT 2004
Hi Gerry,
I may have not done a makelib step. I did the others, though. Per
someone else on the list who also helped me off-line, I did the
/etc/ld.so.conf and ldconfig step. Still something awry, it appears. I
may take you up on the Friday offer (I'll be out of the office
Thursday). I probably just need to have a little hand-holding through
the process.
Thanks,
Ken
Gerry Creager n5jxs wrote:
> After you compiled shapelib and did a makelib, and did make install,
> did you add the appropriate lib location to /etc/ld.so.conf? And then
> run /sbin/ldconfig? Both should be done using 'sudo' or as root.
> I'll be back from the Dallas AMS meeting tomorrow night and available
> Thurs/Fri to help if you still need it.
> gerry
> Ken Waters wrote:
>> Hi All,
>> I'm looking for a simple way to convert "gen" format text files into
>> shapefiles on the RH Linux platform. To date I have been running a
>> public domain Windows program (gen2shp) that I found on the Web.
>> However, I need to move this application to a Linux box and this is
>> where I have been having problems. This Linux box will not be
>> running Apache and
>> Mapserver, so I am not interested in trying to set up a full install
>> on it. I simply want to have the ability to easily create shapefiles
>> from text files without all the other overhead. Here's what I've
>> tried so far, without success:
>> - Tryed to compile gen2shp.c from http://www.intevation.de/~jan/gen2shp
>> RESULT: Found I had to download shapelib and compile that package
>> and was successful with that. However, was unable to successfully
>> compile gen2shp.c as it didn't seem to be linking the required
>> shapefil.h library. Could not figure out what I was doing wrong.
>> - Looked for Linux binaries of gen2shp
>> RESULT: Only found the Windows binaries which I already have and
>> use. Are there some available somewhere that I don't know about, or
>> possibly a suitable alternative?
>> - Downloaded mapserver-4.2.1
>> RESULT: A bit overwhelmed as it's much more than I need for this
>> machine and will require lots of pre-building of libraries and such
>> that will not be used in the long run. My experience with mapserver
>> has been only with Windows using the binaries. I did not find
>> binaries for Linux.
>> So, are there any suggestions for how I can proceed? Perhaps I need
>> to pursue further one of the options above that I tried.
>> Thanks much!
>> Ken
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
