[Mapserver-users] JBOX ERROR and more
Javier Castillejo Montes
jcastil1 at tragsa.es
Wed Jul 28 02:44:20 EDT 2004
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C4746E.51EB3E54
Content-Type: text/plain;
charset="iso-8859-1"
Hi Richard
I didn't find out my JVM!!! I'm at work and... maybe i cannot access to this
information.
Any way there is a thing that looks much more "interesting" ... today It's
works!!!!! I have to find out why this is happening... i mean, I cannot give
this app to my boss since it's not robust enough even more when the error
appears and disappears as a wizard.
I'll keep on looking for the answer.
If it helps ... another thign happend... when I use "jbox.lineon" nothing
happends, i mean, it doesn't work, and if i change to another app on my PC
(by alt+tab, for example) (after one or more clics on the img) and then
return i found the img grayed!!!!!
hope I made myself clear
Any Ideas?
Thanks in advance
-----Mensaje original-----
De: Richard Greenwood [mailto:rich at greenwoodmap.com]
Enviado el: martes, 27 de julio de 2004 22:21
Para: Javier Castillejo Montes
CC: mapserver-users at lists.gis.umn.edu
Asunto: Re: [Mapserver-users] JBOX ERROR and more
What Java Virtual Machine are you using? In Internet Explorer, go to
Tools, Internet Options, Advanced, and look for "Java(Sun)" and/or
"Microsoft VM".
What code gets executed by the "reset the map" click?
Regards,
Rich
Javier Castillejo Montes wrote:
> Hi!
> Well let me explain the situation... I'm using Mapserver 4.2, w2k, IE 6
> and IIS.
> I use this line to start the map...
> //[host]/script/mapserv.exe?map=[rutamapa]/FrameMapa.map&layer=penin28
&layer=autonomias&layer=CCAALabel&mode=browse&Zoom=&WhichButton=Han&ZoomAct=
> which is set at the load time and each time a press the button "reset
> the map". It doesn't matter how many times I zoom in and out, how mani
> times I drag the image... it's only happend at the load time and at the
> "reset the map" click.
> Hope this will help!
> Enviado el: martes, 27 de julio de 2004 4:03
> > Hi all!
> > I'm using jbox and it works almost perfect. Sometimes(i don't know
> when) I
> > have "Applet error. IOException PngImage" error, but I just clic
> where the
> > map is suppose to be drawn and it's appears with oput any problem...
> Does
> > anyone know how to avoid this error?
> I would love to help with any jBox problems, but you need to give us a
> better idea of when the problem occurs and the code that causes to to
> happen. For example, what browser? what Java Virtual Machine (VM)? Does
> it happen right when the pages has loaded, or after many zooms and pans?
> > I asked the next question some time ago as I couldn't solve the promen
I
> > just aboid the step, but now my boss ask me about to add this step
so...
> > here it is the question, as I couldn't solve it yet... I have a map
> country,
> > and it has been divided into small parts. Its parts should have been
> drawn
> > with different colors... as I can find differents parts in differents
> > countries I would like to know how to set for each part a color.
> You are more likely to get an answer to this question if you post it as
> a separate email with an appropriate subject.
> Regards,
> Richard Greenwood
> www.greenwoodmap.com
Richard Greenwood
Content-Type: text/html;
Content-Transfer-Encoding: quoted-printable
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<META NAME=3D"Generator" CONTENT=3D"MS Exchange Server version =
5.5.2650.12">
<TITLE>RE: [Mapserver-users] JBOX ERROR and more</TITLE>
</HEAD>
<BODY>
<P><FONT SIZE=3D2>Hi Richard </FONT>
</P>
<P><FONT SIZE=3D2>I didn't find out my JVM!!! I'm at work and... maybe =
i cannot access to this information. </FONT>
</P>
<P><FONT SIZE=3D2>Any way there is a thing that looks much more =
"interesting" ... today It's works!!!!! I have to find out =
why this is happening... i mean, I cannot give this app to my boss =
since it's not robust enough even more when the error appears and =
disappears as a wizard.</FONT></P>
<P><FONT SIZE=3D2>I'll keep on looking for the answer.</FONT>
</P>
<P><FONT SIZE=3D2>If it helps ... another thign happend... when I use =
"jbox.lineon" nothing happends, i mean, it doesn't work, and =
if i change to another app on my PC (by alt+tab, for example) (after =
one or more clics on the img) and then return i found the img =
grayed!!!!!</FONT></P>
<P><FONT SIZE=3D2>hope I made myself clear</FONT>
</P>
<P><FONT SIZE=3D2>Any Ideas?</FONT>
</P>
<P><FONT SIZE=3D2>Thanks in advance</FONT>
</P>
<BR>
<P><FONT SIZE=3D2>-----Mensaje original-----</FONT>
<BR><FONT SIZE=3D2>De: Richard Greenwood [<A =
HREF=3D"mailto:rich at greenwoodmap.com">mailto:rich at greenwoodmap.com</A>]<=
/FONT>
<BR><FONT SIZE=3D2>Enviado el: martes, 27 de julio de 2004 22:21</FONT>
<BR><FONT SIZE=3D2>Para: Javier Castillejo Montes</FONT>
<BR><FONT SIZE=3D2>CC: mapserver-users at lists.gis.umn.edu</FONT>
<BR><FONT SIZE=3D2>Asunto: Re: [Mapserver-users] JBOX ERROR and =
more</FONT>
</P>
<BR>
<P><FONT SIZE=3D2>What Java Virtual Machine are you using? In Internet =
Explorer, go to </FONT>
<BR><FONT SIZE=3D2>Tools, Internet Options, Advanced, and look for =
"Java(Sun)" and/or </FONT>
<BR><FONT SIZE=3D2>"Microsoft VM".</FONT>
</P>
<P><FONT SIZE=3D2>What code gets executed by the "reset the =
map" click?</FONT>
</P>
<P><FONT SIZE=3D2>Regards,</FONT>
<BR><FONT SIZE=3D2>Rich</FONT>
</P>
<BR>
<P><FONT SIZE=3D2>Javier Castillejo Montes wrote:</FONT>
</P>
<P><FONT SIZE=3D2>> Hi!</FONT>
<BR><FONT SIZE=3D2>> Well let me explain the situation... I'm using =
Mapserver 4.2, w2k, IE 6 </FONT>
<BR><FONT SIZE=3D2>> and IIS.</FONT>
<BR><FONT SIZE=3D2>> </FONT>
<BR><FONT SIZE=3D2>> I use this line to start the map...</FONT>
<BR><FONT SIZE=3D2>> =
</FONT>
//[host]/script/mapserv.exe?map=3D[rutamapa]/FrameMapa.map&layer=3Dp=
enin28 </FONT>
</FONT>
&layer=3Dautonomias&layer=3DCCAALabel&mode=3Dbrowse&Zoom=
=3D&WhichButton=3DHan&ZoomAct=3D</FONT>
<BR><FONT SIZE=3D2>> which is set at the load time and each time a =
press the button "reset </FONT>
<BR><FONT SIZE=3D2>> the map". It doesn't matter how many =
times I zoom in and out, how mani </FONT>
<BR><FONT SIZE=3D2>> times I drag the image... it's only happend at =
the load time and at the </FONT>
<BR><FONT SIZE=3D2>> "reset the map" click.</FONT>
<BR><FONT SIZE=3D2>> Hope this will help!</FONT>
<BR><FONT SIZE=3D2>> -----Mensaje original-----</FONT>
<BR><FONT SIZE=3D2>> De: Richard Greenwood [<A =
/FONT>
<BR><FONT SIZE=3D2>> Enviado el: martes, 27 de julio de 2004 =
4:03</FONT>
<BR><FONT SIZE=3D2>> Para: Javier Castillejo Montes</FONT>
<BR><FONT SIZE=3D2>> CC: mapserver-users at lists.gis.umn.edu</FONT>
<BR><FONT SIZE=3D2>> Asunto: Re: [Mapserver-users] JBOX ERROR and =
more</FONT>
<BR><FONT SIZE=3D2>> Javier Castillejo Montes wrote:</FONT>
<BR><FONT SIZE=3D2>> > Hi all!</FONT>
<BR><FONT SIZE=3D2>> ></FONT>
<BR><FONT SIZE=3D2>> > I'm using jbox and it works almost =
perfect. Sometimes(i don't know </FONT>
<BR><FONT SIZE=3D2>> when) I</FONT>
<BR><FONT SIZE=3D2>> > have "Applet error. IOException =
PngImage" error, but I just clic </FONT>
<BR><FONT SIZE=3D2>> where the</FONT>
<BR><FONT SIZE=3D2>> > map is suppose to be drawn and it's =
appears with oput any problem... </FONT>
<BR><FONT SIZE=3D2>> Does</FONT>
<BR><FONT SIZE=3D2>> > anyone know how to avoid this =
error?</FONT>
<BR><FONT SIZE=3D2>> I would love to help with any jBox problems, =
but you need to give us a</FONT>
<BR><FONT SIZE=3D2>> better idea of when the problem occurs and the =
code that causes to to</FONT>
<BR><FONT SIZE=3D2>> happen. For example, what browser? what Java =
Virtual Machine (VM)? Does</FONT>
<BR><FONT SIZE=3D2>> it happen right when the pages has loaded, or =
after many zooms and pans?</FONT>
<BR><FONT SIZE=3D2>> > I asked the next question some time =
ago as I couldn't solve the promen I</FONT>
<BR><FONT SIZE=3D2>> > just aboid the step, but now my boss =
ask me about to add this step so...</FONT>
<BR><FONT SIZE=3D2>> > here it is the question, as I =
couldn't solve it yet... I have a map </FONT>
<BR><FONT SIZE=3D2>> country,</FONT>
<BR><FONT SIZE=3D2>> > and it has been divided into small =
parts. Its parts should have been </FONT>
<BR><FONT SIZE=3D2>> drawn</FONT>
<BR><FONT SIZE=3D2>> > with different colors... as I can =
find differents parts in differents</FONT>
<BR><FONT SIZE=3D2>> > countries I would like to know how =
to set for each part a color.</FONT>
<BR><FONT SIZE=3D2>> You are more likely to get an answer to this =
question if you post it as</FONT>
<BR><FONT SIZE=3D2>> a separate email with an appropriate =
subject.</FONT>
<BR><FONT SIZE=3D2>> Regards,</FONT>
<BR><FONT SIZE=3D2>> -- </FONT>
<BR><FONT SIZE=3D2>> Richard Greenwood</FONT>
<BR><FONT SIZE=3D2>> www.greenwoodmap.com</FONT>
</P>
<BR>
<P><FONT SIZE=3D2>-- </FONT>
<BR><FONT SIZE=3D2>Richard Greenwood</FONT>
<BR><FONT SIZE=3D2>www.greenwoodmap.com</FONT>
</P>
</BODY>
</HTML>
------_=_NextPart_001_01C4746E.51EB3E54--
